hood scoop what's it worth - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 10-14-2012, 04:20 PM   #1
ernie's 5oh
ernie's 5oh's Avatar
Garage
Default hood scoop what's it worth
Never ran one, always cowl, run runs high 7's at 17x mph how much would I gain in a sbf 412ci spraying 32in the first and 30 in the second? Car weighs 2855
450 sbf for 2014 holley efi
IS 2 stage fogger
best 60' 1.12
Best 1/8 4.84@145.85
Best 1/4 7.55@181.76
Thanks to:
PSP
Sam Vincent
Monte Smith
Steve Johnsons
ernie's 5oh is offline   Reply With Quote
Old 10-14-2012, 05:25 PM   #2
scot9055
scot9055's Avatar
Default Re: hood scoop what's it worth
probably loose cause you can't see the tree. I dont recommend one they are a lot of fucking trouble!!
scot9055 is offline   Reply With Quote
Old 10-14-2012, 07:15 PM   #3
ernie's 5oh
Garage
Ok thanks for the input
IS 2 stage fogger
best 60' 1.12
Thanks to:
PSP
Sam Vincent
Monte Smith
Steve Johnsons
Old 10-14-2012, 07:45 PM   #4
spray power
We built a lexan scoop on ours, picked up a lot of motor but very little on spray.... With the lexan you have no problems seeing thru it... Good luck..
Auston Pasquith
ACP Performance & Custom Fabrication
Hot Springs, AR.
Custom manifold porting/EFI conversions
Dealer for:
Induction Solutions/ Woody's Pluming/Jerry Bickel Race Cars/RJ Race Cars/Race Parts Solutions/Hyperformance/BTE-Memphis Performance/Strange Eng./FAST Fuel Injection/Schoneck Composites and more!
spray power is offline   Reply With Quote
Old 10-14-2012, 09:20 PM   #5
Seattle_Mike
Seattle_Mike's Avatar
You can use an $8 plastic prism from any RV store also to see around the scoop. Simply hang it from the halo bar...works great.
68 Camaro ProMod - 848ci - M&M 3 Speed
www.yvonnelucasracing.com
Seattle_Mike is offline   Reply With Quote
Old 10-14-2012, 09:32 PM   #6
ernie's 5oh
Garage
Nice cool tip
IS 2 stage fogger
best 60' 1.12
Thanks to:
PSP
Sam Vincent
Monte Smith
Steve Johnsons
Old 10-14-2012, 09:55 PM   #7
jmillhellboy
Member
Pullin gears
jmillhellboy's Avatar
Quote:
You just look at that instead of actual light?
jmillhellboy is offline   Reply With Quote
Old 10-14-2012, 11:11 PM   #8
anubisani
Member
Pullin gears
anubisani's Avatar
Quote:
X2 I USE A LEXAN ALSO BCS I CLDNT SEE THE TREE WITH THE SCOOP
RUN WHAT YOU BRUNG
anubisani is offline   Reply With Quote
Old 10-15-2012, 01:49 AM   #9
Seattle_Mike
Quote:
I don't drive the car but my wife does and yes, she just looks at the prism...takes a little getting used to but she says it does what it's upposed to.
Old 10-15-2012, 02:40 AM   #10
BSmiff
BSmiff's Avatar
Quote:
Lexan scoop picks us up very little in the 1/8th but no back to back testing. Maybe a couple mph. Remember when on nitrous you're supplying your own oxygen directly into the combustion chambers making the air coming into the carb less important. That being said, all those nitrous pro mods have scoops for a reason. Lexan scoop is just best option for vision purposes.
Quote:
Originally Posted by Dragzilla View Post
Folks that dyno and Internet race are quite often wrong when it comes to real world results.... You can't BS your way down the track.
Quote:
Originally Posted by Moparchris440 View Post
using a Mcdonalds spork saw away at your wrist until you bleed out
BSmiff is offline   Reply With Quote
Old 10-15-2012, 08:51 AM   #11
5ohhh
5ohhh's Avatar
same conditions with a lexan and a cowl that was RIGHT on top of the carb I saw 0 difference on my X275 car.
5ohhh is offline   Reply With Quote
Old 10-15-2012, 10:04 AM   #12
krold
krold's Avatar
i heard the same with or with out scoop .....but makes better fire ball when it comes out scoop
Smoke
check us out on Facebook dkr motorsports
dan kroll x 407
krold is offline   Reply With Quote
Old 10-15-2012, 10:42 AM   #13
Drag Chevette
Drag Chevette's Avatar
Pro stock type scoop was worth 3mph on a 11 second car over the cowl hood.
Drag Chevette is offline   Reply With Quote
Old 10-15-2012, 11:20 AM   #14
Seattle_Mike
With a scoop that is sealed, you are pressurizing the air coming into the scoop, especially down track.
Old 10-15-2012, 01:22 PM   #15
Suprslow50
Launchin
Suprslow50's Avatar
A good buddy of mine recently replaced his cowl with Don Burtons complete front end and hood scoop, and then had it sealed to the carb. The combo is a sbf, two kits, runs 7.9x at 174 and picked up 4-5 mph by switching hoods. It wasn't a back to back test, but it picked up 4-5 mph over his best mph ever, so I would have to say it helps a little.
Suprslow50 is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
