Slowing cars reaction time - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 10-03-2012, 08:21 AM   #1
kennyb68
Burnout box
kennyb68's Avatar
Default Slowing cars reaction time
I'm having a problem slowing my car reaction time so I can leave on the flash of the last yellow bulb.
Currently I have to leave somewhere between the yellow and the green.
I have a 93 mustang with a 550 horse SBF and a powerglide with a pro brake, 180 gear, 4.30 rear gear and 28" tall rear tires, 26" tall moroso front tires.
Rear suspension is all Team Z. Car weight with me is 2700lbs.
I have the front suspension totally loose.
Launch at 4000 RPM. = 1.43 60' time.
Long Biondo trans brake button.
Front tire pressure 35psi.
Rear tire pressure 10psi.
What else can I do to slow it down?
Will staggering my front wheels help?
Ken
kennyb68 is offline   Reply With Quote
Old 10-03-2012, 08:32 AM   #2
cumminatya
Member
Pullin gears
cumminatya's Avatar
Default Re: Slowing cars reaction time
There are countless ways! longer transbrake button for one tire pressure ? this list goes on it all depends on what works for the driver
Renegade Racing Association
Davis Race Cars
Hyatt Racing Clutches
UMTR North
cumminatya is offline   Reply With Quote
Old 10-03-2012, 08:34 AM   #3
grandville455
Member
Pullin gears
grandville455's Avatar
Taller front tire would help for sure, launch 500 rpms less.
74 Grandville 4550 lbs
11.501@117.74, 1.60 60 ft
74 Firebird 3620 lbs, Full Exhaust
2016,(91 Octane, 468 Pontiac) all bests) 1.377 60 ft, 6.33@107.05 -10.024, 131.96
grandville455 is offline   Reply With Quote
Old 10-03-2012, 08:38 AM   #4
BigRicky3
BigRicky3's Avatar
Where are you staging at, deep or shallow? If I stage too deep, I'll bulb. If I just tickle the second beam, it's ok.
“We [Americans] developed the top fuel dragster, zero to three hundred thirty miles an hour in under five seconds, because we were bored. Piss us off and see what we build!”
-Christopher Titus-
BigRicky3 is offline   Reply With Quote
Old 10-03-2012, 08:47 AM   #5
kennyb68
Burnout box
kennyb68's Avatar
I shallow stage, I just tickle the second beam.
Old 10-03-2012, 09:15 AM   #6
ChuckT
Homer
ChuckT's Avatar
X2, with what you have, knock at least 5psi out of the front tires, and reduce launch rpm.
Taller front tire, knock the rear gear down to 4.11.
Sponsored by Millerstown Pic-A-Part
http://picapartyard.com/
Jones Race Car Trailers
www.jonesrv.com
ChuckT is offline   Reply With Quote
Old 10-03-2012, 09:31 AM   #7
D.Johns
Launchin
D.Johns's Avatar
How much red are you going? Is by a consistant amount? Is the track and beams consistant(even from lane to lane)?
Like cumminatya said there are countless ways of impacting R/Ts. Taller front tire, tire pressure, staggering wheels, anti-squat, launch RPM and driver are all changing the R/T.
We are fighting red lights in Scotty Bs car now on a 500 pro tree with a stick car. We changed front tires added ballast in rear to firm up some inconsistancy we saw on film and tested, made 4 passes. RT's were .003, .008, .020, .001 . Went to another track and R/Ts were all over the place (spread of .120 overall from .030 red to .087 green) and others noticed lane to lane was off also with one being tight. Red in right was green in left. Letting some air out in front helped but still was inconsistent. Maybe it's car, track or the driver having a bad day. We will see in BG this weekend.
2013 5.0 Supercharged Cobra Jet
NHRA SuperStock/Stock #3345
Like us on http://www.facebook.com/pages/Daniel...25886327426822
Huge thanks to:
Mike@BuyFordRacing
Jesse@FordRacingParts
Tony@BESRacing
D.Johns is offline   Reply With Quote
Old 10-03-2012, 09:41 AM   #8
rocketolds400
Spooled up
rocketolds400's Avatar
Bigger front tire
Less pressure in rear tires (if it can still hook)
Lower launch rpm
Throw a sandbag or two in the trunk (seemed to work for me)
Add more travel up front
rocketolds400 is offline   Reply With Quote
Old 10-03-2012, 10:06 AM   #9
D.Johns
Launchin
D.Johns's Avatar
Also what type of racing is it? Heads up, bracket, or index? I assume since you said last amber it's full tree and so assuming once again bracket? A lot of things you do to car set-up will also affect ET to some extent.
Huge thanks to:
Mike@BuyFordRacing
Tony@BESRacing
Old 10-03-2012, 10:45 AM   #10
n00b
Spooled up
Lower launch RPM. It works like a charm and you can progressively lower/raise based on track rollout/your reactions that day/anything else. Try 3500 and see what happens!
n00b is offline   Reply With Quote
Old 10-03-2012, 12:07 PM   #11
Battlestar
Battlestar's Avatar
How much front suspension travel? Get as much as you can. Get 28" tall front tires. Hell, I run the MT 29" on my wagon. Very tight fit on turns, but I'm still trying to find about .08 second. How much air in front tires? You could get some with just dropping your current tires.
United Manual Transmission Racer
2006 UMTR Points Champion
2009 UMTR Points Champion
"I get pushed outta shape and it's hard to steer, but I get rubber in all four gears"
Battlestar is offline   Reply With Quote
Old 10-03-2012, 02:10 PM   #12
grandville455
Member
Pullin gears
What's A guy do if he leaves at idle, and flashes the convertor. How does he slow it anymore? Take some air out of the front tires?
Old 10-03-2012, 03:23 PM   #13
Battlestar
Battlestar's Avatar
Yup. As long as it doesn't give you control issues down track.
Old 10-03-2012, 03:26 PM   #14
Leavinsteven
REBUILDING
Leavinsteven's Avatar
Leave later.....
http://youtu.be/5L5h8pyAG6Q
Life is Drag Racing....
Everything else is waiting.
Leavinsteven is offline   Reply With Quote
Old 10-03-2012, 05:19 PM   #15
grandville455
Member
Pullin gears
Quote:
Originally Posted by Leavinsteven View Post
Leave later.....
Nice!,lol... I like to leave tho the minute i see it flash on
