Re-splining axles - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 10-03-2012, 12:01 AM   #1
Fast57
Burnout box
Default Re-splining axles
Anyone know of a shop around Atlanta or west georgia that can respline axles?
Fast57 is offline   Reply With Quote
Old 10-03-2012, 12:05 AM   #2
CameronVic
Wayyyyy more left in it!
CameronVic's Avatar
Default Re: Re-splining axles
Find the newbie thread! What are you crazy!?
CameronVic is offline   Reply With Quote
Old 10-03-2012, 12:15 AM   #3
wideopen231
wideopen231's Avatar
Have a set never had balls to run them. Axles are not super cheap but neither is new car. Resplined axle and any real horsepower is asking for meeting with the wall.
Only the stupid know too much to learn something new
Re-electing obama is like shooting the right foot because it did not hurt enough when you shot the left foot
D.I.L.L.I.G.A.F.
Chris McBride
wideopen231 is offline   Reply With Quote
Old 10-03-2012, 01:12 AM   #4
JBoone
JBoone's Avatar
I will warn you on this, lots of guys respline axles in a milling machine with an index fixture. Its hard to get the correct cut in the spline. There should be very little movement from spool to axle. Best to send them where they came from unless its an oem deal. If you just need an inch or 2 off an have a moser or strange with excess spline cut them off in a chop saw an dress the end with a file. Most axles have 4 to 5 inches of spline at the end. rule of thumb if you axle is 1 1/4 you need an 1 1/4 in the spool
JBoone is offline   Reply With Quote
Old 10-03-2012, 02:30 AM   #5
MCM
MCM's Avatar
Send em to Moser. Cheap, quick turnaround, and they'll be done right.
Mike M.
MCM is offline   Reply With Quote
Old 10-03-2012, 02:32 AM   #6
ordinary builder
not all / every axle can be resplined
not all splines are the same
the shop that made the axles should do the work or else failure can happen....
dont screw around with a "stock" axle....
ordinary builder is offline   Reply With Quote
Old 10-03-2012, 03:24 AM   #7
MCM
MCM's Avatar
Some great points:
Moser will honestly tell you what can/cannot be done.
Mike M.
Old 10-03-2012, 08:09 AM   #8
Al Hagle
Spooled up
Al Hagle's Avatar
I had a pair of OEM axles resplined. They lasted 7 runs untill I twisted one end off. On a 11.30 car.
Al Hagle is offline   Reply With Quote
Old 10-03-2012, 10:52 AM   #9
Hutch
Moderator
Hutch's Avatar
Many places can cut splines but not many can put the case hardening back into the new splined area and there lies the problem with resplining. There are many companies that now have cheap street axles and I would suggest that before resplining old axles if proper race axles are not in the budget.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 10-03-2012, 05:27 PM   #10
Fast57
Burnout box
Well Cameronvic I quess you just have to beat someone up and tell them nothing dude, it was just a simple question and I got some senseable answers from most everyone but you . I really can not afford new shorter axles right now and I am not making massive HP right now either, that was the reason for asking this question so please feel free to fall off the earth if you can't or won't give a decent answer sir !!!! No reason to be a jerk.
Old 10-03-2012, 10:00 PM   #11
Fast57
Burnout box
Thanks guys that had positive answers/comments, the axles a new currie enterprises performance axles from a brand new never run 9 inch that was supposed to be in a 1969 Mustang. I am putting it in my 57 Fairlane and it is a pretty good bit wider than the 57 stock rear housing and we were thinking of narrowing the thing to start with. Currie said the axles would take 750 HP and that they could do the re spline but shipping form the east coast to California aint gonna be cheap round trip thats why I was asking for closer/east coast service.I am not actually new to this stuff just rusty like the old ford and never had a reason til now to narrow a rear end, just wanting to get some tire under my 460 powered 57 Fairlane street car. Like I said thanks to those that replied to the positive and sorry about the last post I know everone does not want to see other people talk about others here, thats not what I am here for, just some info/help.
Old 10-04-2012, 06:56 AM   #12
nuclearcobra
nuclearcobra's Avatar
As MCM said moser is your best bet.
nuclearcobra is offline   Reply With Quote
Old 10-04-2012, 08:30 PM   #13
ordinary builder
You probalby should not
but maybe you can answer the "ability" to respline the axles by someone
if you read and look / observe at what I say..
pull out both axles and LOOK at where the spline area length ENDS..
if the round unsplined area where the spline ends at is SMALLER than the area that the splines are..
then obviously, the shank shaft area is not large enough to cut a new longer spline..
many many STOCK axles are typically smaller in diameter just beyond where the spline ends....
this is because on an original ford production car axle,
the splines are FORMED rather than being CUT....
currie could have used ANYTHING....
they are known at one time to respline stock axles when shorter over all length is employed..
we have no way to know what type is actually in what you got.
Old 10-04-2012, 10:46 PM   #14
Fast57
Burnout box
The axles are large enough in diameter to respline and I called Moser today and they said it would be NO problem to do. they said that the whole length of the shaft would be hard enough and not be a problem since the diameter is the same for the majority of the shaft till it gets close to the bearing. and the splines will not be cut through the hardened layer of the axle shaft. one final note reasonably priced service too.
Resources saved on this page: MySQL 2.02%
