dana 60 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Rearends and Differentials - Mark Williams Enterprises
Old 09-11-2012, 03:49 PM   #1
7sec.cuda
Member
Pullin gears
7sec.cuda's Avatar
Default dana 60
are all dana 60 housings the same?or does the year make a difference?not sure of the year of mine been in car 15 years . thanks for any info
7.44@185 1.10 60ft 4.71@149 1/8 3000lbs naturally aspirated Larry Morgan Hemi, torqueflite,Neverlift Chassis
http://www.youtube.com/watch?v=irUP4-c0Zjo
7sec.cuda is offline   Reply With Quote
Old 09-11-2012, 04:33 PM   #2
Turbo TA
Spooled up
Default Re: dana 60
I had two Dana 60 and there is definetly a difference on the two that I have. One is I can pick it up with the Strange S track and complete but the axles. But the other one with out the spool just the housing was heavier than the one with the posi unit and all. It must have a thicker tubing or something as I couldn't figure this one out myself.
Turbo TA is offline   Reply With Quote
Old 09-11-2012, 04:42 PM   #3
rr572
Burnout box
rr572's Avatar
Default Re: dana 60
The early ones have holed to bolt pinion snubber the ones out like later model trucks can still use same gears but housing ends have to be changed and on pinion snubber holes witch does not matter unless you are running leaf springs
rr572 is offline   Reply With Quote
Old 09-11-2012, 10:13 PM   #4
Supershafts
Supershafts's Avatar
Default Re: dana 60
There are D-60's and HD-60's which are factory 35 spl, i forget the wall of the tubes and added webbing that the other D-60's don't have, those are heavier than the car version or the D-60
LIMA , www.LIMOTORSPORTS.ORG , Fighting to bring back motorsports on long island. We Race! We Vote! ]= www.Supershafts.com =[
Supershafts is offline   Reply With Quote
Old 09-17-2012, 10:17 PM   #5
kingstone
Burnout box
Default Re: dana 60
mine is heavy as hell....
kingstone is offline   Reply With Quote
Old 10-12-2012, 09:30 PM   #6
tony dirose
Spooled up
Default Re: dana 60
all dana 60 car housing have .200 wall axle tubes all the truck housing are 3/8 thick wall axle tubes all the internals are the same all years up to the 80s after that i not sure
tony dirose is offline   Reply With Quote
Old 10-12-2012, 10:51 PM   #7
Gary Anderson
FUCKING ASSHOLE SINCE '61
Default Re: dana 60
Not sure about the Dana 60, but the Dana 70's and Dana 80's, the HD version of both are longer from thecenterline of the rearend to the rear of the center section housing.
If you were to see a regular Dana 70 or 80 next to a HD version your could see the difference.
It is about 2-3" worth!
1 ton GM and Dodge Duallys come with HD 70 and 80's.
I own an '86 GM Crew Cab Dually, it comes stock with a Dana HD 70
My son owns a '99 Dodge dually, it comes stock with a Dana HD 80
Your Pal, Gary
Gary Anderson is offline   Reply With Quote
Resources saved on this page: MySQL 2.27%
