Best door skin tools? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Auto Body and Paint
Old 09-06-2012, 09:32 PM   #1
mikes
Member
Pullin gears
mikes's Avatar
Default Best door skin tools?
Ok, been doing a ton of door skins lately and its time for me to buy some better skin tools. I've never owned a door skin hammer so we can start there. Yes I've been doing them all this time without one, so whats a good brand? Second, with all the tools that "help make the job faster" whats the best skin tool out now that doesn't ruin a skin?
mikes is offline   Reply With Quote
Old 09-07-2012, 01:15 AM   #2
Krusty
Member
Pullin gears
Krusty's Avatar
Default Re: Best door skin tools?
i have a little tool that goes on an air hammer<<<<<<has 3 different angles built into it ..works pretty nice just have to finish it up with a hammer and dolly to get it really tight what do you do to out side of skin when your done?
First Nitrous Car In The 4's On An 8.5- Peckham Mafia
Lets Go Racin, Eh!!
PKRE, Baby
BES
Connelley Racing
SRJ Racecars
OJO
ShockNerd
Mickey Thompson-Buddy
M&M Transmissions
Ross Pistons-Chris Madsen
OverKill Racecars
Krusty is offline   Reply With Quote
Old 09-07-2012, 01:32 AM   #3
jay bird 455
Pre-Staged
jay bird 455's Avatar
One trick that i do is grind the lip with a 50 grit disk before you hammer it over it makes it eaiser to fold over,Dont go crazy with the grinder you don't want to make the lip to thin I also use panel glue and a hard rubber block.A few guys at work have the shark air tool door skin tool it works ok but if you have a skin that has alot of contours you still have to go back and hammer it over.
jay bird 455 is offline   Reply With Quote
Old 09-07-2012, 08:59 AM   #4
95killerz
Spooled up
95killerz's Avatar
I use a wet sanding block and a Mac door akin hammer it's got the rectangle head, I used to use a snap on one with the round head an always ended up hit the inside of the door cause the head was to big.
99 SS Th400 4500 stall Bolt Ons, s60 w/ 4.10s
1.7 60' 12.47@108
95killerz is offline   Reply With Quote
Old 09-07-2012, 07:33 PM   #5
IIbad4u
IIbad4u's Avatar
i use one of these. works really good on the straight edges, not so much on the curves.
IIbad4u is offline   Reply With Quote
Old 09-15-2012, 02:32 AM   #6
3QTR LBS
Launchin
3QTR LBS's Avatar
This thing is amazing. Do a few and you will have it down without the need for glaze coat or even priming. Best tool I've used yet.
3QTR LBS is offline   Reply With Quote
Old 09-15-2012, 09:58 AM   #7
Krusty
Member
Pullin gears
Krusty's Avatar
can we get a little better pic
part number
Lets Go Racin, Eh!!
PKRE, Baby
BES
Connelley Racing
SRJ Racecars
OJO
ShockNerd
M&M Transmissions
OverKill Racecars
Old 09-15-2012, 01:59 PM   #8
mikes
Member
Pullin gears
mikes's Avatar
Quote:
Thats the one I hear a lot about too. BUT anything with air hammer and door skin in the same sentence makes me nervous lol. I hear it does work well though, but is it only good on straight edges? What about curves and body lines? I am good enough with a dolly and hammer that I do them with no filler, I just need to be faster.
Old 09-15-2012, 08:23 PM   #9
Krusty
Member
Pullin gears
Krusty's Avatar
faster.......thats what she said......bawahahahahahaha
Lets Go Racin, Eh!!
PKRE, Baby
BES
Connelley Racing
SRJ Racecars
OJO
ShockNerd
M&M Transmissions
OverKill Racecars
Old 09-16-2012, 12:51 AM   #10
3QTR LBS
Launchin
3QTR LBS's Avatar
Quote:
I hear ya in the "air hammer and door skin" making ya nervous. haha My first one i did with it i only needed one little spot of filler and that was only my 4th door skin EVER. Super easy to use, and literally with the pneumatic skin remover and with this tool, its seriously a 5-10 minute process off and on if you have everything set up and ready to go. Then the obvious fitting of the skin on the car. Do you guys weld your skins on? or do you glue them?
Curves is amazing, and body lines sometimes only require very little finishing with the hammer/dolly.
Heres a video i ran across to show a little about it.
http://www.youtube.com/watch?v=0pQd2L-n8Ro
heres the remover.
Old 09-30-2012, 06:47 PM   #11
3gdwrench
3gdwrench's Avatar
I learned with hammer and dolly.....I've tried the air hammer tool and still preffer the old method as you have a feel for what you are doing. Always make sure your tools are clean & burr free such as dents or divets in your dolly block or hammer(s). I like to use a flat metal file on my dolly block before every doorskin job too keep imperfections off the face of the panel. An average skin job should be hanging on the car with the glue drying in about an hour, from start to finish,no filler.
I don't like the new "make your job easy" tools as I think it's money wasted.You can do that job just as fast doing it conventional and it will be nicer.......I can see it if your doing more than 5 panels a day to save your forearms but don't want to see skinning a door become a lost art.
3gdwrench is offline   Reply With Quote
Old 10-09-2012, 07:49 PM   #12
eaf100
Burnout box
I use a small pine block and my 6 inch hard rubber sanding block
eaf100 is offline   Reply With Quote
Resources saved on this page: MySQL 2.20%
