250 shot - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 09-06-2012, 04:50 PM   #1
Qkdragster
Qkdragster's Avatar
Default 250 shot
what would be a good setup for a 200 or 250 shot . with a NOS brand pro race fogger ...??
jetting ??..... 4 spread or 6 spread ?? what sizes .........
flowing fuel pressure with q16 ?.......
timing pulled out ??? ... very efficient Big Chief head 15.7 compression...
632 BBC .....dragster ....
thanks
Qkdragster is offline   Reply With Quote
Old 09-06-2012, 04:58 PM   #2
Qkdragster
Qkdragster's Avatar
Default Re: 250 shot
I guess when I said timing pulled out , I should have noted we usually run 33 degrees total timing naturally aspirated ....
87cc chambers ...
Old 09-06-2012, 05:13 PM   #3
onefast68
onefast68's Avatar
i can give an example of what i have tried..i will say start with the smaller tune and pull a little extra timing and read plugs..i do not run q16...
my 632 with 18 degree heads,nitrous cam ect...this tune works excellent and is a small kit to me....26n 20f...i pull down to 22degrees..5.5psi through a 73jet.
68 camaro..3300lbs........
big duke 632 with 2 kits ..
4.95 at 145.8 ................
onefast68 is offline   Reply With Quote
Old 09-06-2012, 10:08 PM   #4
Induction-Solutions
Moderator
Induction-Solutions's Avatar
Pro Race has two nozzle options. The 90 degree will require more spread then the annulars, especially as the tunes get larger.
For 225-250 you can start with a .028N and a .022F at around 5.5 PSI and work from there. Maybe start around 18-20 degrees going down track and read plugs from there. -10 plug. If you want closer tunes and more specific numbers flowing the system can get you better tunes and more accurate HP info.. Thanks, SJ
Steve Johnson
www.InductionSolutions.com
http://www.facebook.com/#!/pages/Ind...06171102739096
815-341-8853 Cell
352-593-5900 Parts/Shop
NOSMAN1@aol.com
Induction-Solutions is offline   Reply With Quote
Old 09-06-2012, 10:20 PM   #5
Qkdragster
Qkdragster's Avatar
thanks 68 and Steve. I will send my Hogan intake over the winter when the engine is down , we will be using the spray next season alot more ..and it has the 90 degree soft plume nozzles ..
Old 09-07-2012, 02:52 PM   #6
Induction-Solutions
Moderator
Quote:
That would be great. That way we can get you real close and help you tune as well.. Thanks, SJ
Steve Johnson
815-341-8853 Cell
NOSMAN1@aol.com
Old 10-16-2012, 03:26 PM   #7
Pantydropper
Member
Pullin gears
Pantydropper's Avatar
Location: Texas. Where it's said it rains BULLETS on race day
Garage
Steve, I have what I think is the older NOS (Sportsman Fogger) with 90* nozzles. Do you have an upgraded Pill Spread Chart that you would suggest?
The Reason I ask is that the old one as far as I can tell has a 4 spread with running more fuel than Nitrous. I had 28 N 32 F 5.5psi @ 11* out with 22 total timing on C-23
I tried that and the motor is muddy when purging it. I flipped the pills and it sounded great. Any Ideas on which direction to go?
I would like to run a 250 kit for starters and step it up to 350, then a 400 kit. Any help will be greatly appriciated.
BTW this is an all aluminum 605 cu.in. Mopar with 2-4 carbs sheet metal intake, Powerglide in an Ex-pro stock truck that weights 2400 with my fat ass in it.
You can fix a car, but ya can't fix Stupid.
Pantydropper is offline   Reply With Quote
Resources saved on this page: MySQL 2.17%
