Th400 rear servo leak - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 09-04-2012, 08:08 PM   #1
alkynova
Pre-Staged
Default Th400 rear servo leak
I air checked my rear servo after I rebuild my transmission. I sanded the servo cover to make sure it's flat and put on a new metal seal. It still leaks. I torque the bolts to 18 ft pounds as my manual said. Is there any trick I can do to seal this up. I have some copper head gasket spray I was thinking of using but don't know if that would be bad. Looking for suggestions. Thanks
alkynova is offline   Reply With Quote
Old 09-04-2012, 09:33 PM   #2
chris718
Default Re: Th400 rear servo leak
Is the case flat?Is the cover fully decked flat on a true parrallell surface?Did you use coarse paper?If so it may be flat but have dips in between the flat surface.Some air will leak but very little.How much is leaking?Big blast of air?
Cristoforos Kokkonis,GM automatic transmission specialist.
chris718 is offline   Reply With Quote
Old 09-04-2012, 10:00 PM   #3
alkynova
Pre-Staged
Quote:
It's leaking in a few spots between the bolts. I can see very little bubbles
And can feel air breeze. I I'll check the casing to see if it's flat. I sanded it with 150 grid lightly. I can't see any deep groves or anything
Old 09-04-2012, 10:02 PM   #4
E.R. Racing
E.R. Racing's Avatar
Does the band apply with light air pressure? What you're seeing is most likely normal.
I support our troops, do you?
E.R. Racing is offline   Reply With Quote
Old 09-04-2012, 10:23 PM   #5
stuarta
Sanding yes, but is it flat?
Sand it on a piece of glass and use coarser paper.
Journeyman, transmission builder for many many years.
stuarta is offline   Reply With Quote
Old 09-04-2012, 11:26 PM   #6
alkynova
Pre-Staged
Quote:
It sounds like it is. I can see the shaft budged a cunt hair as I apply air
Old 09-04-2012, 11:30 PM   #7
alkynova
Pre-Staged
what's coarser should I use? I
Old 09-05-2012, 12:51 AM   #8
Hutch
Moderator
Hutch's Avatar
Sand it agressively on a machined flat surface. Apparently the surface you sanded your cover on was not flat. Install a new steel gasket and its over (no sealers are used here). Small leaks are no concern but if done properly will not be there.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is online now   Reply With Quote
Old 09-05-2012, 01:00 AM   #9
stuarta
60-80 grit.
Old 09-05-2012, 01:01 AM   #10
stuarta
blonde red or black?
Old 09-06-2012, 08:10 PM   #11
clubby
Launchin
clubby's Avatar
Garage
i am suprised no one makes a biller servo and new biller cover ??
Transmissions are the greatest forgotten part of
Any race car
clubby is offline   Reply With Quote
