Build or Buy 565/572 BBC? - Yellow Bullet Forums
Old 08-27-2012, 01:46 PM   #1
T&S Racing
Spooled up
T&S Racing's Avatar
Default Build or Buy 565/572 BBC?
Looking into pricing on a 565 or 572 BBC.... Trying to figure out if I should buy an off the shelf engine from reputable builder Steve Schmidt, Sunset Racecraft, etc.. or if building it would save me a significant amount of coin?
It would have to be N/A, make 960hp-1000hp, basically a solid SC/SG bracket motor that could stand 150-200 passes without worrying too much about it. I would be putting it in a car that would weight no more than 2300lbs with driver.
I see the online deals and they seem priced well compared to when I put together a price list for a build. Is 13-15K way too much for the type of motor I'm looking for? What are your thoughts YB?
1963 Split Window Corvette
T&S Racing is offline   Reply With Quote
Old 08-27-2012, 02:00 PM   #2
Matt Compton
Matt Compton's Avatar
Default Re: Build or Buy 565/572 BBC?
I say find a local builder to help with getting parts and machine work. You assemble it, keep a local guy employed and have the satisfaction of it being your build.
Matt Compton is offline   Reply With Quote
Old 08-27-2012, 02:31 PM   #3
G-String
Member
Pullin gears
G-String's Avatar
You MIGHT be able to buy the Parts for 13-15K>But,IF you want top of the Line stuff,better get some more change together!
I went with Dart Block,Callies Crank & Rods,J&E Pistons,Custom Valve-Train,All Jesel,New Profilers,Jesel Belt,MSD Frt.Drive,Williams Oil pan & V/Covers,and the List goes on,..........But you can see it Top Quality parts!
I did all the Assembly,and 15K wont cover my stuff!
But theres always EAGLE,....?
Later
G
G-String is offline   Reply With Quote
Old 08-27-2012, 02:53 PM   #4
Real McCoy
Real McCoy's Avatar
When I was looking around I found those less than 15 grand motors didn't have any decent parts on them. You want 1000 REAL HP and low maintenance you need some decent parts to work with. The labor to machine and assemble a motor is going to be the same basically no matter who does it so parts are what you pay for. You want a steel pan and cast oil pump, timing chain, rocker arms and stud girdles, a distributor ignition and collector vacuum system you get it for cheap. Like G String I bought all my parts from a local builder who's my friend who gave me better prices than I could ever get and he made a couple bucks but my parts were about 17 grand for a real 1025 HP 565 that runs numbers to support the dyno sheets.
2010 PTRA 5.30 Index Champion
Real McCoy is offline   Reply With Quote
Old 08-27-2012, 04:40 PM   #5
T&S Racing
Spooled up
T&S Racing's Avatar
Thanks gentlemen and the advice is very much appreciated. I definitely want good parts.
Old 08-27-2012, 07:58 PM   #6
aukai
Mike
aukai's Avatar
Check your PM
Mike Lewis street 572 with Holley EFI
http://www.lewisracingengines.com/
Marcella Manifolds
UDHarold, .456 x 1.8/1.7
GF5R,3 pedals
Menscer Motorsports
http://menscerms.com/
Ultra Carbon
http://www.ultra-carbon.com/
R2C Filters
http://www.r2cperformance.com/
aukai is offline   Reply With Quote
Old 08-27-2012, 09:17 PM   #7
SS_Sean
SS_Sean's Avatar
Quote:
Originally Posted by aukai View Post
Check your PM
I know what he said in PM.....call Mike Lewis.... Do it.
1978 Chevy Malibu
540, Rons Toilet, BTE PG, 25.5B/backhalf
8.89@150mph, 1.30 60'
SS_Sean is offline   Reply With Quote
Old 08-27-2012, 09:36 PM   #8
GoodFella
Doing Work
Steve Schmidt competition engines. Excellent engines and a 1 year warranty that they DO stand behind.
http://www.trickchassis.com/
GoodFella is offline   Reply With Quote
Old 08-27-2012, 10:39 PM   #9
ALL MOTOR BANANA
Spooled up
ALL MOTOR BANANA's Avatar
take a look at Reher Morrison or Sonnys...not much more money than a mail order type engine
hold my beer and watch this
ALL MOTOR BANANA is offline   Reply With Quote
Old 08-27-2012, 10:49 PM   #10
DaBu
Member
Pullin gears
DaBu's Avatar
Quote:
I have a 235" swing arm Trick Chassis dragster PG transmission 1.8 first with a 4:11 rear gear, 33.5x16.5x16. It has a 584 Steve Schmidt engine that makes 1100hp @7600 and 845tq@ 6200. My converter that i currently have goes to 4560rpm on the wood. It's safe to say its a "little" off. What company do you recommend? Should a proper converter go to 6200 on the brake? or should it go to 5800 and flash to 6200?
The car went
60 1.13
330 3.185
660 4.90 @ 143
Have you picked it up any?
DaBu is offline   Reply With Quote
Old 08-27-2012, 10:54 PM   #11
G-Code
Not Hillary 2016
G-Code's Avatar
Quote:
if I was a Chevy guy.....
http://www.rehermorrison.com/rmEngines.htm
G
Today is the First day of the rest of your life. Make a difference
"My job is not to represent the world, my job is to represent the United States of America " DJT 2-28-2017
58.3% of Statistics are made up.
G-Code is offline   Reply With Quote
Old 08-27-2012, 11:21 PM   #12
harrytd1977
Spooled up
I have a 584 ssre killer james motor for sale for 14ka carb to pan that makes 1050hp on a tight dyno runs 7 teens on motor
harrytd1977 is offline   Reply With Quote
Old 08-27-2012, 11:34 PM   #13
JBoone
JBoone's Avatar
If I were going to buy an engine it would be from reher or suncoast. If you are wanting to build one . Find someone that is a PBM dealer an work a deal with them. I would say you could do a 565 Intake to pan(profiler heads an intake) for less then 10000 not counting machine work.
JBoone is offline   Reply With Quote
Old 08-28-2012, 02:03 AM   #14
scott foxwell
scott foxwell's Avatar
I'll build one for ya but it won't be cheap.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 08-28-2012, 04:17 AM   #15
SS_Sean
SS_Sean's Avatar
Quote:
I picked up a PBM merlin III block, eagle rotating assembly and pistons of my choice, plus bearings for $3000. I did the whole thing for under $10k. (including machine work and assembly, but minus the carb.) Mine is no 1100hp motor, but I think you could get to your goal by going that route...
1978 Chevy Malibu
