Strange Misfire with MSD 7730...... - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 08-06-2012, 09:26 PM   #1
lun40119
I like IceCream
lun40119's Avatar
Default Strange Misfire with MSD 7730......
I just finished hooking up the 7730 piggy-backed on my Mallory Hifire 6 box and Unilite Distributor. I am looking for the ability to add timing while in the converter at launch, and ramp it out as rpms get over 8000rpm. The launch retard was another factor.
Before ordering I talked to 2 separate techs at MSD to make sure it would work. Both had the same story. It will work fine.....On the 4 pin connector, Orange to B+, Red to Ing from Mallor box, White to Green Trigger from Mallory box, Black to ground. From the 7730 to the Distributor, it was white to ground, red to red, and the brown wire on the Unilite to ground.
Car fires up fine cold, and I ran it through some timing checks. As the motor starts to get warmed up, I noticed a very intermittent misfire. Worse at lower rpms.
Here is a video of what it is doing..........any thoughts or input would be greatly appreciated.
http://www.youtube.com/watch?v=p4CbQnfd358&feature=youtu.be
Jake
Team Clueless
Optimize the Compromise...
Quote:
Originally Posted by Chris Uratchko View Post
Hell no, big blocks are for dump trucks!!!
lun40119 is offline   Reply With Quote
Old 08-06-2012, 09:33 PM   #2
lun40119
I like IceCream
lun40119's Avatar
Default Re: Strange Misfire with MSD 7730......
Quote:
Before ordering I talked to 2 separate techs at MSD to make sure it would work. Both had the same story. It will work fine.....On the 4 pin connector, Orange to B+, Red to Ing from Mallor box, White to Green Trigger from Mallory box, Black to ground. From the 7730 to the Distributor, it was white to GREEN, red to red, and the brown wire on the Unilite to ground.
OOPS.
Jake
Team Clueless
Old 08-07-2012, 11:36 AM   #3
texas racer
texas racer's Avatar
how much timing are you taking out ?
and did we check rotor phasing ?
texas racer is offline   Reply With Quote
Old 08-07-2012, 11:45 AM   #4
lun40119
I like IceCream
lun40119's Avatar
47 is the base........I pulled 7 to let it idle.....12 to start it. No I didn't check rotor phasing. We have been bouncing it around in teh NA section also. The thought is lots of fuel/timing through the converter to get it to hit the converter, and then pull it out down track above 7500-8000-8500.
I talked to Joe at MSD, and he said that when the grid retards the timing it is causing the rotor in my unilite to be out of phase. He suggested the 85501 with rotor 84211.
This would be alot easier if I had a crank trigger. Ill be installing one this winter when funds are available. We have been spending money like the obama's lately for Drag Week........
Jake
Team Clueless
Old 08-07-2012, 01:18 PM   #5
texas racer
still need to see those files....i have all the engineers here at my
desk waiting on you!
Old 08-07-2012, 01:23 PM   #6
lun40119
I like IceCream
lun40119's Avatar
Perfect......you want a screen shot of the general setup right? I will get them for you when I am at home. I am at work until 4 or so Central.
This is my first trip into MSD land..........and I am pretty slow. Did I mention the software is pretty confusing too.......I can't even figure out how to get it to record?
Jake
Team Clueless
Old 08-07-2012, 01:24 PM   #7
lun40119
I like IceCream
lun40119's Avatar
Have them look at her til this afternoon.........I promise Ill get the data!!!
Jake
Team Clueless
Old 08-07-2012, 01:31 PM   #8
texas racer
all that did was make more of a crowd around the moniter!
(dry hump)
p/m me a daytime phone number ...and i'll call ya .
Old 08-07-2012, 01:34 PM   #9
lun40119
I like IceCream
lun40119's Avatar
PM sent......... Thanks fella!!!
Jake
Team Clueless
Old 08-07-2012, 03:01 PM   #10
369dragster
Member
Pullin gears
369dragster's Avatar
It almost sounds like the coil wire is arcing out on something.Did you try disconnecting the tach and try it?
Ken
369dragster is offline   Reply With Quote
Old 08-07-2012, 03:15 PM   #11
lun40119
I like IceCream
lun40119's Avatar
Quote:
I did not try that.
Jake
Team Clueless
Old 08-07-2012, 05:58 PM   #12
lun40119
I like IceCream
lun40119's Avatar
What files exactly are you looking for?
Here are the settings...
Jake
Team Clueless
Old 08-07-2012, 07:18 PM   #13
lun40119
I like IceCream
lun40119's Avatar
This is my first trip around the block with ANY MSD PRODUCT................and it makes me want to light the M'fkn car on fire!!!
Jake
Team Clueless
Old 08-08-2012, 08:12 AM   #14
lun40119
I like IceCream
lun40119's Avatar
I was on the phone with Joe in tech last night.....he walked me through turning on the data logger........still isn't working. I also have a "Cam Sync" error, with the individual cylinder timing function turned off....
Jake
Team Clueless
Old 08-08-2012, 10:22 AM   #15
texas racer
even if that was on..it would not effect anything...( only if you were doing i.c.t)
we need data from a quick run...
under msd re-view ...
is the lap top currently with you or at home?
