598 BBC ? on conventional heads - Yellow Bullet Forums
Old 07-27-2012, 07:44 AM   #1
onebadsb2
Burnout box
Default 598 BBC ? on conventional heads
Wanting to build it over the winter but dont know what heads to go with. Was looking an rfd victors bes head hunters an sniper x I just heard about this sr20 heads but dont know where to go find out about them. Its gonna be a truck pulling engine I want it around 14 to 1 an would like to see 1100 hp. Thanks for your opinions.
onebadsb2 is offline   Reply With Quote
Old 07-27-2012, 07:56 AM   #2
kirt70camaro
kirt70camaro's Avatar
Default Re: 598 BBC ? on conventional heads
http://www.slickrickheads.com/
kirt70camaro is offline   Reply With Quote
Old 07-27-2012, 08:14 AM   #3
E-SQUARED ENGINEERING
Member
Pullin gears
E-SQUARED ENGINEERING's Avatar
Quote:
I would try the RFD RR heads.
Give Curtis a call.
E-SQUARED ENGINEERING is offline   Reply With Quote
Old 07-27-2012, 08:16 AM   #4
mreese903
Spooled up
mreese903's Avatar
headhunter BP395MC
1968 CAMARO SS BBC N2O
mreese903 is offline   Reply With Quote
Old 07-27-2012, 09:15 AM   #5
tirenick
My 565ci made 990hp. 13.5 to 1, nitrous motor. Went with the RFD Victors, not his double throw down ones either. Cost was hardly any more then a "box" set of heads. Curtis will set you up to meet your goal and his after sale service is second to none!!!!
tirenick is offline   Reply With Quote
Old 07-27-2012, 09:26 AM   #6
onebadsb2
Burnout box
Quote:
Yea I've heard that about him.I heard bes is getting big power from there hh I dont know any one that deals with them tho.
Old 07-27-2012, 09:40 AM   #7
RCM Racing engines
RCM Racing engines's Avatar
You can't gowrongwithTony @ BES, He is One of the best in the country...............
Slick rick Maiser is a good one also, The new SR20 head he design is a Bad as head....
With a fresh start, that's the route i'd go.....20* head............= Big Power, your 598 likely would see over 1200hp, if built right
Just an old' Mennonite..........
RCM Racing engines is offline   Reply With Quote
Old 07-27-2012, 09:46 AM   #8
Chad Speier
Chad Speier's Avatar
Sweet, truck pulling rules that allow aluminum heads!!
VFactor NATION
SRH Speier Racing Heads
785.623.0963
Chad Speier is offline   Reply With Quote
Old 07-27-2012, 09:51 AM   #9
cboggs
cboggs's Avatar
I build a raised runner conventional in valve angles to
meet rules packages that will go 535 / 355 and has been
killer on the pull stuff. Small fast ports, ..
completely custom, ..
That's the most serious pull head I know of, ..
Curtis
Race Flow Development
http://www.raceflowdevelopment.com
757-222-9717
WD- Brodix-Dart-Edelbrock
cboggs is offline   Reply With Quote
Old 07-27-2012, 10:44 AM   #10
Headman
Launchin
1100 hp with a 598 will be a walk in the park, with several different non custom heads.
I do believe if I was building an engine from scratch, and didn't have a valve angle rule, my SR20 would be the obvious choice. It's now on "on the shelf" head, Diamond is in the process of offering several different shelf pistons for it, and T&D is super quick with the rocker system, if they don't have them on the shelf.
If going with a custom head, hard to go wrong with a set from RFD, Darin Morgan, BES, or myself.
I don't like to boast about flow #'s, but I have a set I was working on for Larry Pearce's TPSA engine that I was going to run this year, until the class decided to take a "mini vacation".
These went over 550 cfm on both the left and right port, and I had only just began to tune on them.
For comparison, the heads on Rick Cowger's TPSA engine that holds the ET record flow 515.
There's some pretty serious stuff out there for conventional bbc engines, even though some say it's a little silly to use conventional heads. lol
Rick McConathy
SlickRickheads.com
Naiser Racing Components
Headman is offline   Reply With Quote
Old 07-27-2012, 10:56 AM   #11
onebadsb2
Burnout box
Wow those r some wicked flow #s from both you guys. I dont have a valve angle rule just says conventional style heads no prostock stuff.
Old 07-27-2012, 11:07 AM   #12
z289sec
z289sec's Avatar
I was gonna mention not to forget Darrin over at Reher-Morrison...but Rick already did.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 07-27-2012, 07:40 PM   #13
onebadsb2
Burnout box
What kinda power are u guys seeing with the off the shelf sr20?
Old 07-27-2012, 08:30 PM   #14
stinkythings.com
stinkythings.com's Avatar
WOW ! I had no idea that much power was available from conventional heads.
STINKYTHINGS.COM
ASS KICKIN CAR AIR FRESHENERS
Life Stinks... We Can Help !!
stinkythings.com is offline   Reply With Quote
Old 07-27-2012, 09:43 PM   #15
darrell67
Spooled up
a properly built 598 can make 1200+hp with sr20 heads
darrell67 is offline   Reply With Quote
