Calibrating/Adjusting Tire Pressure Guage? - Yellow Bullet Forums
Old 07-22-2012, 07:40 PM   #1
Topfun99
Topfun99's Avatar
Location: Orlando, then Alamogordo, NM, Manchester, TN and back to Orlando!!!!
Default Calibrating/Adjusting Tire Pressure Guage?
I was suspicious of my 0-30 tire pressure gauge so I tested it with another calibrated guage and it was off enough that I either need to get a new gauge or open this one up and adjust it.
Anyone know if a liquid filled tire pressure gauge can be readjusted or is it just time to get a new guage?
Racing Means You Are Probably Just As Poor Making $80K A Year As When You Made $5K.
NMRA 2010, 2012, 2013, 2016 Bradenton True Street Winner
NMRA 2013, 2014, 2016 Bradenton Shootout Winner - 2016 Average 8.323
Thanks to:
TURBO BY GARRETT
HALTECH (Using New Elite ECU)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - RoadTripRacer@aol.com
Topfun99 is offline   Reply With Quote
Old 07-22-2012, 08:40 PM   #2
t-bird racer
t-bird racer's Avatar
Default Re: Calibrating/Adjusting Tire Pressure Guage?
Probably isn't serviceable these days. Most stuff they force you to spend the money on a new one.
t-bird racer is offline   Reply With Quote
Old 07-22-2012, 09:09 PM   #3
SlickVic
SlickVic's Avatar
It doesn't need to match another gauge, you use a tire gauge as a reference. If your says 10 lbs and mine says 20 lbs, but you set your tire to your gauge at 10 lbs every pass and it works then your setting the tires the same every time. Even if mine says your using 20lbs as long as its works for your setup it doesn't matter what they really are. A better test would be to measure your tires with both gauges. Let air out, and then refill. Use your gauge to set them back to the original psi that you read with your gauge. Then check with the 2nd gauge. As long as they both read the same reading before changing tire pressure then you know your gauge is going back to the same spot at whatever PSI it might be. AND liquid filled gauges are temperature sensitive, i don't run any liquid filled gauges.
slickvic@slickvicracing.com
www.slickvicracing.com
302-786-1078
Necksgen REV, HANS, and Simpson Hybrids available!
Carrying all your safety items, engine components, chassis pieces, wheels, tires, and custom fabrication of any part, big or small!! Contact me for all our current specials!!
SlickVic is offline   Reply With Quote
Old 07-22-2012, 09:10 PM   #4
IMSHOT
TEAM RACECAR
IMSHOT's Avatar
Does it zero?...You may need to vent it if it is a liquid filled...Its not uncommon.
Baller on a budget..........
IMSHOT is offline   Reply With Quote
Old 07-22-2012, 09:12 PM   #5
JHaleyH374
Bracket racer
JHaleyH374's Avatar
You said the magic words...LIQUID FILLED.
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
Old 07-22-2012, 09:13 PM   #6
DewRonInc
DewRonInc's Avatar
I have a digital and a analog, I set digital to analog and all is good, as stated above all is well as long as you use same guage time after time as long as it is consistant.....Liquid filled isn't.....
Fears Racing Components
DewRonInc is offline   Reply With Quote
Old 07-22-2012, 09:15 PM   #7
cmccarthy
Tellin' it like it is
cmccarthy's Avatar
As long as it's consistent and it's the only gauge you ever use, the reading is irrelevant. Find the indicated tire pressure that works, and always use that gauge.
Charles
BAITTFMF
cmccarthy is offline   Reply With Quote
Old 07-22-2012, 10:26 PM   #8
Sparkz
Burnout box
Sparkz's Avatar
Find a bunch of friends and test everyones gadge on a tank ( tire will go down so big tank) and average everyones find most that are close,,
then fill a tire / tank to what you like and psi / bar u use and use a sharpie marker and make a line to correct you fav gadge,,
but i might also get new one but keep old friend for when in a fix or bind,
Hope we gave ya some ideas
Sparkz
Sparkz is offline   Reply With Quote
Old 07-23-2012, 06:10 PM   #9
IMSHOT
TEAM RACECAR
IMSHOT's Avatar
Did you vent the gauge yet?
Resources saved on this page: MySQL 1.12%
