Semi truck air suspension - Yellow Bullet Forums
Old 07-18-2012, 01:28 PM   #1
MT BUICKNUT
Member
Pullin gears
MT BUICKNUT's Avatar
Default Semi truck air suspension
Is there way to decrease the amount of pressure to the air bags? Does the height sensor adjust the presure? I need to decrease the pressure some on my truck when I pull my race trailer.
Thanks Rick
Rick Starkey
Buick Goin Fast With Class
MT BUICKNUT is offline   Reply With Quote
Old 07-18-2012, 01:32 PM   #2
longstroke
Huge Member
longstroke's Avatar
Default Re: Semi truck air suspension
increasing or decreasing pressure will change the ride height.
The leveling valve adds and removes air to keep it at the right height.
The only way to increase or decrease the pressure in the bags and keep the same height would be change the weight on them.
longstroke is offline   Reply With Quote
Old 07-18-2012, 02:00 PM   #3
comp670
comp670's Avatar
The leveling valve does this automaticly. If you change the adjustment and raise or lower the truck you will mess up all the driveshaft and u-joint angles..
NHRA Comp Elim B/A 670.
comp670 is offline   Reply With Quote
Old 07-18-2012, 02:08 PM   #4
shaker
Member
Pullin gears
shaker's Avatar
Quote:
What he said... is the truck riding bad? Why do you feel you need to change it?
shaker is offline   Reply With Quote
Old 07-18-2012, 02:11 PM   #5
natesomer
natesomer's Avatar
Does it mess up the u joint angles when the suspension moves threw its range of motion? If you let air out of bags or add air, its still within its range of motion. Then the u joints will be fine. No way to really soften the air bags without changing ride height. It ride hight needs to be changed just move load leveler valve. Should have a bit of adjustment on it.
natesomer is offline   Reply With Quote
Old 07-18-2012, 06:31 PM   #6
fatwax
fatwax's Avatar
Quote:
of course the trucks height will change going over bumps etc but the truck will spend most of its time at the correct level going down the road
Eric W.
fatwax is offline   Reply With Quote
Old 07-18-2012, 07:32 PM   #7
225digger
time to go racing yet ?
225digger's Avatar
dont mess with ride hieght ... it will ruin that rear shaft joints pretty darn quick
225digger is offline   Reply With Quote
Old 07-18-2012, 07:37 PM   #8
streetglyde
streetglyde's Avatar
^^^^^^^^^^^CORRECT !
streetglyde is offline   Reply With Quote
Old 07-18-2012, 07:40 PM   #9
streetglyde
If you are concerned about height lower 5th wheel... saddles can be changed ,whats the issue anyways why do you need to lower truck ?
Old 07-18-2012, 11:55 PM   #10
MT BUICKNUT
Member
Pullin gears
Just thinking of softening the bags to get less hit to the gooseneck trailer. Ride height is ok.
Thanks Rick
Rick Starkey
Old 07-19-2012, 12:13 AM   #11
LilJohn
LilJohn's Avatar
Want it to ride softer.... Move the bag further from the axle centerline. Will take less pressure to maintain a given height.
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 07-19-2012, 12:35 AM   #12
MT BUICKNUT
Member
Pullin gears
Moving the bag ain't going to happen, it has 8 bags.
Thanks Rick
Rick Starkey
Old 07-19-2012, 12:41 AM   #13
MXS67454
Spooled up
lower tire pressure. tire mfgs have charts on line.. weight vs speed. no need to run 100 psi when 60 will do.....
I have nothing of value to contribute, but that won't stop me.
MXS67454 is offline   Reply With Quote
Old 07-19-2012, 12:58 AM   #14
LilJohn
LilJohn's Avatar
8 bag Kenworth suspension...
Theres only one fix for that... Bigger supply lines to the bags so it can move more air.
888-583-4408
LJMSJohn@gmail.com
Old 07-19-2012, 01:06 AM   #15
Oilpatch Boys
Big asses save lives...
Oilpatch Boys's Avatar
............lol , basically Chalmers rubber block with air lines going to em...... Neway for air ride ftw....
Quote:
Originally Posted by Mark O'Neal View Post
No Irishman is ever so drunk that he can not hold onto a blade of grass and not fall off the face of the Earth.
Oilpatch Boys is offline   Reply With Quote
