2005 gmc 2500 won't go into 4 wheel drive. - Yellow Bullet Forums
Old 07-07-2012, 09:59 PM   #1
555nova
CFH
555nova's Avatar
Default 2005 gmc 2500 won't go into 4 wheel drive.
Like the title says my 3/4 ton duramax won't engauge 4 wheel drive. The selector on the dash lights up when you push the button and I can hear a soft grinding like its trying to engauge. No dummy lights on the cluster light up either. Any body have this issue before?
555nova is offline   Reply With Quote
Old 07-07-2012, 10:03 PM   #2
lurker
Default Re: 2005 gmc 2500 won't go into 4 wheel drive.
the light won't light untill the axle is engaged. when was the last time you changed your front rear fluid?
lurker is offline   Reply With Quote
Old 07-07-2012, 10:04 PM   #3
NOS455
NOS455's Avatar
Garage
sounds like the actuator in the frt. diff ..remove it and put it in 4 wheel drive and see if it works...if it does it may be further inside ..there is a fork with a ring on it that engages when the actuator pushes it ..that could be the problem of the actuator is good ...good luck
NOS455 is offline   Reply With Quote
Old 07-07-2012, 10:06 PM   #4
555nova
CFH
555nova's Avatar
I changed the fluid about 15,000 miles ago.
Old 07-07-2012, 10:07 PM   #5
lurker
its either dirty or the actuater is bad.
Old 07-07-2012, 10:12 PM   #6
555nova
CFH
555nova's Avatar
Having dirty fluid could cause the 4wd not to in gauge?
Old 07-07-2012, 10:14 PM   #7
lurker
I had one so gummed up it couln't push on it.
Old 07-07-2012, 10:19 PM   #8
555nova
CFH
555nova's Avatar
Thanks guys.
What's it take to change out the solenoid? I'm going on vacation next week and need my truck to pull my boat to the lake.
Old 07-07-2012, 10:21 PM   #9
SeanSS
Member
Pullin gears
SeanSS's Avatar
Alright, i can repeat it i guess.
Disconnect the actuator and try manually engaging the 4 wheel drive.
If you can get it into 4 wheel drive you may have an actuator problem.
71 Chevelle
588" Reher-Morrison
SeanSS is offline   Reply With Quote
Old 07-07-2012, 10:21 PM   #10
lurker
book time is 1/2 hour. easy job (if its the actuater)
Old 07-08-2012, 06:33 AM   #11
chubod
chubod's Avatar
If it's an auto 4wd the transfer case module in the dash could be fuct, get one from a wrecker and also easy to change!
chubod is offline   Reply With Quote
Old 07-08-2012, 06:46 AM   #12
laford1986
Member
Pullin gears
WOW what a surprise....POS
laford1986 is offline   Reply With Quote
Old 07-08-2012, 10:36 AM   #13
555nova
CFH
555nova's Avatar
Quote:
Thanks for your input cockbreath, it's the first problem I've had with a truck that has 100,000 miles on it. IMO that's a pretty dependable rig. If it were a ford I would have had to replace multiple turbos, head gaskets ect....
Old 07-08-2012, 05:30 PM   #14
Chebby
Chebby's Avatar
Quote:
true !! .. I could just IMAGINE the crap an 05 6.0 ford f250 would be replacing , but HEY ... some guys ENJOY repairing shit all day long.
Check the actuator !
Chebby is offline   Reply With Quote
Old 07-08-2012, 05:45 PM   #15
hoffmansgold
99 out of 100 has this problem
Quote:
hoffmansgold is offline   Reply With Quote
