Methanol Air Fuel?????? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 07-07-2012, 01:29 PM   #1
Insane_Crew
Insane_Crew's Avatar
Default Methanol Air Fuel??????
I realize that sensor placement, header design, and sensor type have a big effect on the readings but what range should the A/F be in for mechanically injected methanol? We're seeing 11.3- 11.8 in high gear. Thanks in advance.
We don't suffer from INSANITY.................. We enjoy every second of it!
Originally posted by: redwhite
Quote:
You must be the mother phuckin man come easter time. You're like a hard boiled Einstein!
Quote:
Originally Posted by Dalpilot View Post
Yes, I love performance mods and bolt ons on everythinng I drive hard.
Insane_Crew is offline   Reply With Quote
Old 07-07-2012, 02:52 PM   #2
Matt Hill
On the roller...
Matt Hill's Avatar
Default Re: Methanol Air Fuel??????
What wideband are you using? Do you have the option to just use lambda output?
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter.
-Ernest Hemingway
Matt Hill is offline   Reply With Quote
Old 07-07-2012, 03:05 PM   #3
str8liner
Quote:
My car runs best on the gas scale at 11.5 or so. If I try to lean it out it will slow up.
They like to be fat as hell off the line and then lean it out downtrack.
Planning on putting a mechanical high speed on mine here shortly.
str8liner is offline   Reply With Quote
Old 07-07-2012, 03:49 PM   #4
Insane_Crew
Thanks for the answers. The O2 are bosch sensors and I don't believe we have a means to use lambda. We are monitoring them as part of the RPM data logger set up we installed.
Old 07-07-2012, 04:18 PM   #5
Honk if parts fall off
Drag Week Survivor
I just tune in lambda. Air fuel ratio is just a multipier of Lambda. I look for .79-.82 on the lamnda scale.
11.3 = .76
11.8= .80
Are you using any sort of high speed bleed?
Honk if parts fall off is offline   Reply With Quote
Old 07-07-2012, 04:24 PM   #6
Insane_Crew
Quote:
11.3 = .76
11.8= .80
No hi speed bleed on it and we can't display lambda. By what you're saying though we're in the right neighborhood though????
Old 07-09-2012, 05:29 PM   #7
ADAMSVEGA
e85 & injection guru
ADAMSVEGA's Avatar
yelp !!!! untill you start force feeding that pig injected likes .77-.82 lamda so your good .mine starts leaner a tad till shift then creeps rich up top. seems to trade off bottom for top with small weather change .it move 10.288 @3650 DA to 10.271at #3100ft gas cars went .04 +faster
http://www.yellowbullet.com/forum/image.php?type=sigpic&userid=28924&dateline=126169  0598
2012 pro street champion
best beers
http://roundguysbrewery.com/
http://freewillbrewing.com/
http://www.prismbeer.com/
FIRST EVER YELLOWBULLET NATIONALS WINNER!!!!!
and runner up YB2....
e-85ttfmf
I Cor. 9 24
ADAMSVEGA is offline   Reply With Quote
Old 07-10-2012, 12:08 AM   #8
69427
69427's Avatar
Quote:
Originally Posted by ADAMSVEGA View Post
injected likes .77-.82 lamda so your good.
Hum, with M5 we have been running .850 lambda and the plugs still look a little rich. I have pulled a couple of .020 shims out of the hi-speed to keep it from richening more in the upper rpm's.
Have any of you run M5 and compared the lambda readings with regular methanol?
BurnsFamilyRacing
1.30 6.14 @ 111.11 @ #3350
427 BBC by S&S Speed Center, AFD, Enderle MFI by Spud Miller
Sepanek Racing T400, Dynamic converter, Autoweld, Dick Fords Body Shop
69427 is offline   Reply With Quote
Old 07-10-2012, 12:17 AM   #9
Insane_Crew
Thanks for all the input guys. I guess I should give a little more on the system. Its a Ron's Terminator mechanical set up that we got new from James and Scott at KillerRons.com this spring. We finally have it all together and let me tell you... They shipped it with a range of main jets. We put the mid range pill in it, made some dyno pulls changing up and down and ended up right in the middle. With no other changes except a manifold to accept the nozzles we saw 100 more ft/lbs of torque and 40 more hp than the same set up on 114 octane race fuel. I'm beginning to like this alky stuff.
Old 07-22-2012, 09:58 PM   #10
Insane_Crew
Ok so going over the data from some passes we made the last time out and something is funny.... In the last 1/2 second of the pass #8 EGT starts going cold. The O2 on that side doesn't seem to change though yet #8 drops off by nearly 300 degrees. Any suggestions???
Old 07-22-2012, 10:26 PM   #11
Lucky3
Launchin
Lucky3's Avatar
I run the same Toilet Bowl and also use the RPM Data Recording System and have for several years. Randy at RPM can fix you up with the proper A/F sensors for Methanol and add the channel to your data recorder.
The proper stoic A/F ratio for methanol is 8.5 (Lean) - 4.5 (Rich) with 5.7 being perfect but each motor has it's own fuel demand curve. My sbc runs best @ around 5.1.
Give Randy a call and he can fix you up !
Lucky3 is offline   Reply With Quote
Old 07-22-2012, 11:01 PM   #12
Insane_Crew
Thanks I'll call him.
Resources saved on this page: MySQL 2.20%
