How much should engine tilt back in car when installed? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 07-01-2012, 10:05 PM   #1
streetknight2
streetknight2's Avatar
Default How much should engine tilt back in car when installed?
I'm putting a 6.0 LS engine in a Fox body Mustang. I have the AJE K member with correct engine mounts. I'm trying to use the stock Mustang Transmission cross member and have everything lined up where it will bolt in.
However, it appears the engine is tilting back too far. I placed a protractor on the intake and it has 6 degrees of fall toward the back of the car. How much should it have? I put a 1/2" shim in between the transmission cross member and the mount. That got me to 3-4 degrees.
Just wanna make sure I'm ok before I get too far along with the build.
TIA
streetknight2 is offline   Reply With Quote
Old 07-01-2012, 10:11 PM   #2
luv2xlr8
luv2xlr8's Avatar
Default Re: How much should engine tilt back in car when installed?
mine is at 4* in my fox body. my drive line is damn near strait all the way back. make sure if using a carb intake that it isnt tilted forward and throwing your reading off ect. i like to go off a valve cover
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 07-01-2012, 10:16 PM   #3
streetknight2
Thanks for the info. I'll check on the valve cover also. It just looks like it has too much "eyeballing" lol You can kinda tell from the pic of the mount it's got a small gap on one side at the top, this is where the engine is tilting down.
Old 07-01-2012, 10:58 PM   #4
Comax Racing
Comax Racing's Avatar
I usually put the rear of the engine 2 deg up in chassis I build.
Comax Racing is offline   Reply With Quote
Old 07-01-2012, 11:04 PM   #5
streetknight2
Quote:
Meaning the balancer of the engine should be angled toward the ground, correct? Sorry I'm a dumb ass when it comes to this stuff.
Old 07-01-2012, 11:33 PM   #6
john@dyno
Launchin
john@dyno's Avatar
It all depends on ride height.....line up the crank to the pinion at ride height..
john@dyno is offline   Reply With Quote
Old 07-01-2012, 11:40 PM   #7
mopwr2004a
mopwr2004a's Avatar
there are a couple of factors involved depending on your combo. ride height, HP, are some
www.lowslungchassis.com
mopwr2004a is offline   Reply With Quote
Old 07-02-2012, 08:17 AM   #8
coyote52
coyote52's Avatar
Quote:
Exact......hard to do in most cases of stock cars , but that is the best.....crank straight in line with pinion.
coyote52 is offline   Reply With Quote
Old 07-02-2012, 09:08 AM   #9
streetknight2
Thanks guys. It just seemed extreme. The car should make around 450 RWHP on motor.
Old 07-03-2012, 01:24 AM   #10
540IROC
Member
Pullin gears
540IROC's Avatar
If you can adjust the angle, the crank centerline and tranny output shaft should be pointed at the diff pinion. The engine could be pointed up or down to achieve this depending where the pinion is located in the chassis.
540IROC is offline   Reply With Quote
Resources saved on this page: MySQL 2.20%
