Street cam recommendation, Vortec SBC - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 06-26-2012, 11:57 PM   #1
Eman85
Default Street cam recommendation, Vortec SBC
Putting together a budget street SBC with a set of Vortec heads. Heads have 1.6 self aligning rockers on them. motor is a flat top piston simple motor for a street car. Looking at a budget hydraulic flat tappet cam. Any suggestions?
Eman85 is offline   Reply With Quote
Old 06-27-2012, 09:57 AM   #2
Stockey-Yockey302
SBF TTFMF
Garage
Default Re: Street cam recommendation, Vortec SBC
I can't comment on the "budget" part, but I know Cam King on here has a lottttttt of experience with forced air induction cams. Call him up or several others on here.
Stockey-Yockey302 is offline   Reply With Quote
Old 07-17-2012, 04:42 AM   #3
fullmonte383
Member
Pullin gears
fullmonte383's Avatar
call john at bullet cams!
"W.O.T TIL' YOU SEE GOD, THEN BRAKE"
fullmonte383 is offline   Reply With Quote
Old 07-17-2012, 04:58 AM   #4
Blue Knight
Blue Knight's Avatar
I've had luck with the elgin. 480 .480 cam that pretty much taps out a vortec head without putting in threaded rocker arm studs.. anything more than that you run into coil bind also the heads stop flowing at. 500 lift anyways.
Blue Knight is offline   Reply With Quote
Old 07-17-2012, 05:09 AM   #5
Blue Knight
Make sure you've got the late 90's heads and not the junk tbi heads.
That cam with 4.11's, air gap, and a 150 shot had those cobra mustang guys wondering wtf was up..
Old 07-17-2012, 12:18 PM   #6
Stockey-Yockey302
SBF TTFMF
Garage
Sorry...When I commented I read the title wrong. I figured you meant a vortech supercharger....Not the heads.
CamKing is still a great choice.
Old 07-17-2012, 08:06 PM   #7
NITROUS NOVA
Member
Pullin gears
X2 camking, If on a tite buget the elgin or howards cams both have kits cam an lifters for under $150.00, in 480 lift deal, depending on the rest of your combo, gears, exh, trans ect, I think the howard cam is on a 108 lobe, an the elgin on a 112 lobe sep.
NITROUS NOVA is offline   Reply With Quote
Old 07-20-2012, 11:22 AM   #8
trmnatr
Butch
trmnatr's Avatar
This is an EXCELLENT street/strip cam with descent gearing and stall converter. It will have a "Choppy" idle, rev up fast and provide a lot of torque for a street car. Will pull hard to 6000rpm, use an RPM Air Gap
Camshaft part #110591
Grind # H-228/3200-2S-6
284/290 @.020" tappet lift
228/234 @.050" tappet lift
139/144 @.200" tappet lift
.480"/.494" lift with 1.5's
.512"/.527" lift with 1.6's
106 lobe center
PM for pricing if interested,,,
trmnatr is offline   Reply With Quote
Old 07-20-2012, 11:51 AM   #9
94-6spd
94-6spd's Avatar
I used the XE 268 from Comp Cams. I did have screw in studs put in though. Ran great for what it was. I think around 400 hp at the time.
94-6spd is offline   Reply With Quote
Old 07-20-2012, 12:02 PM   #10
94-6spd
94-6spd's Avatar
I based my engine around the Humble Pie article that Car Craft did a while back.
Part 1:
http://www.carcraft.com/techarticles...h/viewall.html
Part 2:
http://www.carcraft.com/techarticles...e/viewall.html
Old 07-23-2012, 10:44 AM   #11
CamKing
CamKing's Avatar
Part# H70330-71330-108 is as big as you want to go.
280/284 @Seat
224/228 @.050"
.528"/.528" Valve Lift w/1.6 rockers
108 LSA
Mike Jones
Jones Cam Designs
Denver, NC 28037 704-489-2449
http://jonescams.com
jonescams@bellsouth.net
CamKing is offline   Reply With Quote
Resources saved on this page: MySQL 1.08%
