th400 pump restrictor?? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 06-17-2012, 04:51 PM   #1
camaroman9
Member
Pullin gears
camaroman9's Avatar
Default th400 pump restrictor??
I took my car out for the second time last night and it blew the 6an hose out of the hose end on the transmission. I was told by a few people I need to put a restrictor in the front pump to keep the line pressure down while spooling the turbo. Where can I get one of these, and is it a difficult install, or something I could do by myself in the garage? Thanks in advance for any help.
Robert
New build on the way!
Thanks to our 2015 sponsors!
http://www.timsbodyandglass.com
Bentune Performance & Fabrication
C&R Transmission (417)736-2191
http://youtu.be/Ga7uyN23mmY
http://youtu.be/hqT7CQQ92Ew
camaroman9 is offline   Reply With Quote
Old 06-17-2012, 11:56 PM   #2
Hutch
Moderator
Hutch's Avatar
Default Re: th400 pump restrictor??
You can but if you have no trans knowledge it may not be the best first attempt.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 06-18-2012, 04:57 AM   #3
benno81
Pre-Staged
u need to pull the front pump off take apart and tap the converter feed hole and insert a grub screw that has a .100 (thats what I got told ppl have diff sizes)drilled in.
so unless u have trans expieriance better take it to someone or buy a book do some net searches and learn how to do it thats how I learnt after being ripped by 2 diff trans places not many good ones here in oz
benno81 is offline   Reply With Quote
Old 06-18-2012, 10:15 AM   #4
BigLar368
BigLar368's Avatar
I had a similar problem but instead on blowing a cooler line the fluid pressure pushed my input shaft into the trans a runined the pressure plate the second time and ruined the case the first time before my trans guy figured out what was going on. My trans guy did exactly what Benno81 said except he made the orfice .150". I was lucky it did not knock out my thrust. Since the restrictor has been in I have made 10 good passes and about 100 street miles with no problems.
BigLar368 is offline   Reply With Quote
Old 06-18-2012, 10:09 PM   #5
rstyhok
Spooled up
should this be done on most or all drag racing trans (400) ?
thanks
rstyhok is offline   Reply With Quote
Old 06-18-2012, 10:19 PM   #6
Packersfan
Packersfan's Avatar
TH400 for sure and others if testing cooler circuit pressure deems it necessary.
Packersfan is offline   Reply With Quote
Old 06-19-2012, 08:16 AM   #7
rstyhok
Spooled up
what size orfice should be drilled in the plug that is installed in pump?
thanks
Old 06-19-2012, 09:00 AM   #8
Packersfan
Packersfan's Avatar
Initial size depends on input shaft being used. If it has a .125" lube hole passage in the shaft I'd start wtih a .150" restrictor. If the shaft has larger holes such as the .187" then size the restrictor to .200". OEM sizing is .265".
Old 06-20-2012, 06:50 AM   #9
BigLar368
BigLar368's Avatar
What size do you suggest if the input shaft is solid/billet?
Old 06-20-2012, 08:06 AM   #10
rstyhok
Spooled up
Quote:
my question to ?
thanks
Old 06-20-2012, 08:59 AM   #11
Packersfan
Packersfan's Avatar
If the input shaft has no provisions for flow around the bushing area you have some things to do. If it's a converter that has a bushing for the turbine hub which most do, you need to ensure there is a flow path where the bushing in the stator tube is at. TCI for one machines 4 slots in the bushing surface of their aftermarket shaft. You could also use a bushing with grooving, or remove it all together again presuming the converter has one in it.
Old 06-20-2012, 01:41 PM   #12
rstyhok
Spooled up
i did leave the bushing out of the end off the stater tube.....but do i need to install restrictor plug and drill orfice hole and if so how big should the orfice hole be?
thanks
Old 06-20-2012, 02:29 PM   #13
Packersfan
Packersfan's Avatar
I'd start with .150" and hook into the cooler line with a T fitting to check pressure with an accurate gauge.
Old 06-20-2012, 08:14 PM   #14
rstyhok
Spooled up
OK .....what or how much pressure should I be looking for and what is to much? I looped the cooler lines , also can i plug the inlet and dump the fluid back to the trans pan?
thanks
Old 06-20-2012, 08:23 PM   #15
camaroman9
Member
Pullin gears
camaroman9's Avatar
I found a guy today, that will do it cheap enough, that I'm not even going to bother trying it myself. Some things are better left to an experienced professional.
