Feeding oil to my turbo (BBC) - Yellow Bullet Forums
Old 06-17-2012, 03:38 PM   #1
Turbo 70 Camaro
Turbo 70 Camaro's Avatar
Default Feeding oil to my turbo (BBC)
Did the search thing and nothing conclusive, can I use the front port on the drivers side or the one next to it on the side of the block to feed my turbo. Having some clearance issues so looking at every option.
Also if I tee it and hook up my oil pressure gauge is it gonna take oil volume away from the line going to the turbo or use a dedicated port for it (which one). I will be running -4 to both the turbo and gauge.
Any other options or recommendations would be great, this is a standard BBC.
Thanks,
Jake.
70 Camaro RS 454 BB, 91mm, Fast efi, tial..................... in progress
Build video: http://www.youtube.com/watch?v=GKAzWDc0wKg
Build pics(slow)http://www.nastyz28.com/forum/showthread.php?t=187740
03 Dodge 3500 SRW 4x4(http://www.thecarlisuspension.com/do...ominator3.html)
Turbo 70 Camaro is offline   Reply With Quote
Old 06-17-2012, 03:52 PM   #2
luv2xlr8
luv2xlr8's Avatar
Default Re: Feeding oil to my turbo (BBC)
not sure on a chevy but my sbf has two -4 lines one for gauge one for turbo coming out of one 1/2" npt hole in the driverside front. gauge wont take away volume because it just dead heads the oil to the guage. not like its flowing ect
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 06-17-2012, 05:59 PM   #3
prost63vette
prost63vette's Avatar
that will work just fine. what turbos you running?
Pimp Daddy Troy 4.19 @ 176 mph / 6.54 at 204 400ci sbc on 10.5 tires and KAM Efi system ,Hughes performance
prost63vette is offline   Reply With Quote
Old 06-17-2012, 06:41 PM   #4
Turbo 70 Camaro
Quote:
91 Garret thumper done by Precision years ago. Do you guys know what size the fitting would be, I think the front port is 1/4" npt not totally sure and what size is the one on the side of the block next to the front port and above oil filter.
I'll prob feed the turbo with front or side port and feed the gauge above oil filter port yes or no ?
Old 06-17-2012, 08:01 PM   #5
vance hewitt
vance hewitt's Avatar
I would feed the turbo straight above the filter..... its filtered oil and rite off the pump....... the other ports are feeding the engine requirements....... i would use those for the gauge...
soon to be 481x twin promod 88's
mikes glide
7.75 @ 192.71
at 3610 lbs and dieting as we speak
my m1 tank on leaf springs
as per dustin bradford
vance hewitt is offline   Reply With Quote
Old 06-18-2012, 09:39 AM   #6
MEAN_SBC
TURBOBULLET.COM BITCHES!
MEAN_SBC's Avatar
Quote:
That's the port I use as well. The feed is on a T with the oil pressure sensor on the other end of the T.
Brant Campbell
Worlds Fastest MPH Car on 275's
6.92@212.09
2011 PSCA XDR/TT5 Champion
2011 PSCA Sin City Shootout Champion
Thanks To The Following:
MEAN_SBC is offline   Reply With Quote
Old 06-18-2012, 03:18 PM   #7
bbcpoweredz28
Spooled up
Quote:
Would you care to share a pic of how you have this setup?
Could you tee into the filtered feed for a twin setup or use one port for each turbo?
84 Z28. New build underway thanks to:
PARacing, Holley, Weld Wheels, Mickey Thompson, LJMS, Strange, ThePowderShed
bbcpoweredz28 is offline   Reply With Quote
Old 06-18-2012, 03:43 PM   #8
MEAN_SBC
MEAN_SBC's Avatar
You could tee into it for both. I don't have a pic, but I'll take one of the fitting this evening.
Brant Campbell
6.92@212.09
Old 06-18-2012, 07:41 PM   #9
Turbo 70 Camaro
Thanks a bunch guys, so I'll just feed the turbo from above the filter and the gauge from the front port. Now the question is what size are the fittings ? 3/8 npt, 1/4" npt or 1/8" npt.
One other thing the feed line is gonna be kind of long using the port above the filter and my turbo is behind the pass headlight, is the -4 line gonna be adequate for that length. I'm guessing 5 feet or so.
Old 06-18-2012, 08:38 PM   #10
vance hewitt
I would run a -6 up towards the core support then you could neck it down if need be....... or just put a restrictor in the fitting.....a -4 mite be fine...... I do see the length kinda long though......shit now ya got me second guessing it.....lol
mikes glide
7.75 @ 192.71
Old 06-19-2012, 08:40 PM   #11
camaroman9
Member
Pullin gears
camaroman9's Avatar
Mine is an sbc, but I used the 1/8npt port right above the timing cover with a -4 feed.
New build on the way!
Thanks to our 2015 sponsors!
http://www.timsbodyandglass.com
Bentune Performance & Fabrication
C&R Transmission (417)736-2191
http://youtu.be/Ga7uyN23mmY
http://youtu.be/hqT7CQQ92Ew
camaroman9 is offline   Reply With Quote
Old 06-20-2012, 01:59 AM   #12
Turbo 70 Camaro
Thanks guys, Reed said to feed it with a -6 all the way, he said that my particular turbo needs all the oil it can get and he said no restrictor. Hope this helps others during search
Old 06-23-2012, 09:30 PM   #13
Turbo 70 Camaro
Well for the life of me I cannot get the plug out above the oil filter, I think I stripped it and I dont think I want to try and drill it out and use an E-Z out while engine still in car.
Can I use something like this block one port and feed the turbo this way ? Running out of options guys.
22-542 - BBC REMOTE OIL COOLER SANDWICH ADAPTER (22-542)
This Chevy BBC Remote Oil Cooler Sandwich Adapter is used up to Mark IV. It provides an in and out port for installing an oil cooler. It mounts between the oil filter and block, replacing the stock bypass and bolting into the mounting holes left after the bypass is removed. The filter is lowered only 1-1/2". Oil ports are 1/2" N.P.T. Comes complete with O-Rings and hardware.
Old 06-23-2012, 09:36 PM   #14
Turbo 70 Camaro
Or
22-560 - BBC OIL INPUT SANDWICH ADAPTER (22-560)
This BBC Oil Input Adapter and Bypass Eliminator, Mark IV, provide two 1/2" N.P.T. oil input ports, one before filtration (for an external oil pump) and one after filtration (for an Accusump). It mounts between the oil filter and block and bolts into the mounting holes left after the bypass is removed. Removing the stock bypass allows the engine to receive filtered oil all the time. The filter is lowered only 1-1/2". Comes with hardware and O-Rings.
Which one to use if this is the way to go for me.
Old 06-23-2012, 11:01 PM   #15
vance hewitt
instead of doing it that way, why not just put a remote filter on it? to answer your question, yes you could do it that way, but if I'm seeing that adapter rite, you would need to complete the cooler circuit. it looks like all of the oil is pushed thru the cooler then back to the filter......
mikes glide
7.75 @ 192.71
