Polished Ring and Pinion Gears - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 06-12-2012, 09:33 PM   #1
302man
302man's Avatar
Default Polished Ring and Pinion Gears
Has anyone found any power in having their Ring and Pinion Gears polished up ? There is a place by me that does it for $70 . I have an 8.8 in a Mustang....275 car, just looking for some more efficiency.
Thanks !
see me for TUBULAR MUSTANG BUMPERS
Parachute Bumpers for Fox Bodies
www.DonathenRacing.com
See my face book for more pictures "Tim Donathen"
87 Mustang - Drag Radial Car
ProTree Race Cars -Chassis
Simple Engine and Machine
Kurgan Motorsports - Tune
Automotion Race Cars
Mike Duke Cylinder Heads
5.27@138 so far on 275's
302man is offline   Reply With Quote
Old 06-12-2012, 09:35 PM   #2
calypso50kid
All motor wannabe
calypso50kid's Avatar
Default Re: Polished Ring and Pinion Gears
i know the prostock guys and nascar guys do it it probably wont be worth any et but it may make them last longer with the reduced friction
Feature car sept 2016 RPM magazine
http://issuu.com/rpmmag/docs/rpm16-09_webready_reduced
Drag Illustrated 30 under 30 member 2016
https://dragillustrated.com/drag-ill...-a-difference/
BK & ME
URATCHKO RACING ENGINES
SLICK RICK RACING HEADS
DRINK HARD RACING
Carbon Fiber Manufacturing
Team Racepak 2017
calypso50kid is offline   Reply With Quote
Old 06-12-2012, 09:37 PM   #3
302man
302man's Avatar
Yea, I was just wondering if it REALLY did anything. On a High HP car it might not be noticeable, but on a n/a car like factory stock...it might ???
Old 06-12-2012, 10:06 PM   #4
fiveohpatrol
fiveohpatrol's Avatar
Just fill the diff case with WD40 instead of gear oil.
-Drew
NMRA CS#1
Best of 10.13@130 stock Coyote @ 3000#
fiveohpatrol is offline   Reply With Quote
Old 06-12-2012, 10:17 PM   #5
302man
302man's Avatar
LOL.....I need it to keep the rust off of that Jackstand queen !
Old 06-12-2012, 10:33 PM   #6
ozone eater
ozone eater's Avatar
we used the micro blue process on our bearings in circle track racing. they would spin alot better, the car rolled alot easier, and that was with near 4.75" of rear stagger.
i'm mike barran and i approve this post.
yes i can, and yes we can.
ask not what mike barran can do for you but what you can do for mike barran
Follow my race team on facebook at mike barran racing
ozone eater is offline   Reply With Quote
Old 06-13-2012, 07:45 AM   #7
Bellman
Bellman's Avatar
Fill your rearend up with Royal Purple gear oil.. With their "Synerlic" technology, I have seen this stuff polish galled up bearings back to a mirror smooth finish.. Yep, I actually saw it done..
Read about Synerlic here..
http://www.royalpurple.com/synerlec/
86 Mustang GT
383 ci SBF
Garrett GTX5518r turbo
TH400 Tranny
Bellman is offline   Reply With Quote
Old 06-13-2012, 08:18 AM   #8
225digger
time to go racing yet ?
225digger's Avatar
the super stock guys run trans fluid in the rears ..... not wd40
225digger is offline   Reply With Quote
Old 06-13-2012, 08:44 AM   #9
bracket__racer
Launchin
I don't know about trans fluid but I know some run 30w synthetic oil.
bracket__racer is offline   Reply With Quote
Old 06-13-2012, 09:04 AM   #10
JThomsen
Launchin
JThomsen's Avatar
Call G-force tansmissions, they do alot of Nascar and Prostock gear sets. When I talked to Leonard Long the owner he told me that when the gears are polished and broke in on the diff dyno they were seeing good gains but i believe breaking in on the dyno was a big help also.
JThomsen is offline   Reply With Quote
Old 06-13-2012, 05:41 PM   #11
bub4481
Launchin
bub4481's Avatar
We just had our r&p polished and the berrings coated. Have not had it out yet, but befor, it took both hands and a lot of effort to turn the axel to turn the pinion. Now can turn easy with one hand. Using Redline light weight gear lube.
bub4481 is offline   Reply With Quote
Old 06-13-2012, 06:46 PM   #12
302man
302man's Avatar
The WD-40 was a joke....the joke being that my car sits more than it moves. I run the Redline Shockproof oil. I just didnt know if anyone did any "true" back to back testing.
Jeff...Williams gears are polished and I have Red Line Shock Proof (red) in his. This is the same gear oil that we found has given us good longevity in Kurgans car. We will see how it works next Wed !
Old 06-14-2012, 12:46 PM   #13
LIGHTNING
LIGHTNING's Avatar
Just get the black shit off. You can do it with a glass bead machine.
The black shit is only on there to keep it from rusting. When it comes off it is like sand.
LIGHTNING is offline   Reply With Quote
Old 06-14-2012, 01:06 PM   #14
banjo
banjo's Avatar
I I bought the used nascar gears below from http://www.roushyatesparts.com/Used-...ears-s/640.htm.
Paid $150 bucks for them, There looks to virtually no wear to them. They have been lighten and had all the latest tricks done to them. Figure for 150 bucks I will give them a try. They usually have a varety of stuff so you need to check back regularly.
Bill Simpkins
74 Nova
SBC 406
3240 pounds
1.29 sixty
6.05@110
9.85@121(bumping the rev limitor)
Speierracing heads
Jones Cam Design
FTI Converter
https://flic.kr/p/dwzk8E
banjo is offline   Reply With Quote
Old 06-14-2012, 01:24 PM   #15
rj2938
I have a liter of cola
rj2938's Avatar
Quote:
LOL!!!! Only for class elims @ Indy.
you had better square your ass away and start shitting me Tiffany cufflinks or i will definately fuck you up!
Quote:
Originally Posted by Honk if parts fall off View Post
I'd rather get ripped off for a $400 restocking fee then have a priest finger my asshole...
rj2938 is offline   Reply With Quote
