Harness Mounting Rules NHRA - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 06-10-2012, 06:27 PM   #1
frank13
frank13's Avatar
Default Harness Mounting Rules NHRA
Ok i need some clear answers....
Installing wrap around belts on the car.....have rollbar......
i know how to wrap the belt around the bar.....what i need to know is do i need to locate them somehow, do i need to cross them or just run them straight over....
Are you still able to use ybelts in NHRA?? (that question is for another friend)
Frank
frank13 is offline   Reply With Quote
Old 06-10-2012, 10:51 PM   #2
Chris Van
Chris Van's Avatar
Default Re: Harness Mounting Rules NHRA
The Y belts haven't been manufactured in a few years now and therefore any left out there would be out of date. So the answer there would be NO, the Y belts are no longer legal.
Quote:
Originally Posted by FRANKTHECRANK View Post
This is the Bullet, where you are guilty until proven innocent. That's just the way it is.
http://www.miawings.com/
Chris Van is offline   Reply With Quote
Old 06-11-2012, 12:16 AM   #3
bdr82z28
Brewmaster
bdr82z28's Avatar
Wrap arounds need some sort of stop to keep them from sliding on the bar.
bdr82z28 is offline   Reply With Quote
Old 06-11-2012, 12:38 AM   #4
Mi.5.0Fred
Mi.5.0Fred's Avatar
Quote:
Such as ?
No one wants the Lead Trophy, but everyone wants the Titanium Hall Pass.
I have gone through the traps upside down and on fire, but I have never seen Elvis at 1000 feet.
Mi.5.0Fred is offline   Reply With Quote
Old 06-11-2012, 12:57 AM   #5
luv2xlr8
luv2xlr8's Avatar
frank as far as the V for chris's ride
http://www.jegs.com/i/G-FORCE/471/60...rentProductId=
its what im using right now. still good to use but i wouldnt recommend it. i sit far back in my ride now and the v was actually on the inside of the seat so i had to mount them and wrap them. i find that if you make the belts super tight and the v style dig into you neck a bit. i will be changing when they are out of date
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 06-11-2012, 03:09 AM   #6
ordinary builder
to limit the side movement of a wrap around belt ...all that you have to do is to make a large C shaped piece that will guide and contain the belt....on each side....
ordinary builder is offline   Reply With Quote
Old 06-11-2012, 07:34 AM   #7
Honk if parts fall off
Drag Week Survivor
Simple fix, buy two aluminum shaft collars, that will sto the movement.
NHRA rule book states Y harness is no longer legal.
Honk if parts fall off is offline   Reply With Quote
Old 06-11-2012, 11:47 AM   #8
Run to Rund
When I designed the 6 point for my car, I placed the cross bar so it is within the 4" down that NHRA allows, keeps the seat back from collapsing, and ran the vertical tubes for the head rest 6" apart so the shoulder belts are retained between them. thus, I didn't have to add weight with a lot of other stuff to serve purposes the main structure could do.
Run to Rund is offline   Reply With Quote
Old 06-11-2012, 12:44 PM   #9
frank13
frank13's Avatar
os, so the seat brace im making has two mounting points to the crossbar...just keep the belts in there....that works for me two
birds one stone!
Old 06-11-2012, 12:44 PM   #10
Chris Van
Chris Van's Avatar
That's what I thought too but I was just going from memory and didn't look it up to be sure. I didn't think the Y type harness had been legal for a couple years now???
Old 06-13-2012, 03:10 PM   #11
TwoFast4Lv
Nitrous Junky
TwoFast4Lv's Avatar
Here is how I did mine
Ellis Groo
Speed Secrets.
SSEFI.Com
360-217-8150
18 Degree's topped with Nitro Daves Custom System and enough Juice to see how strong a LTx block is!
I KNOW I can't spell...Get over it!
TwoFast4Lv is offline   Reply With Quote
Old 06-25-2012, 10:17 PM   #12
Mi.5.0Fred
Mi.5.0Fred's Avatar
Thanks for the replies. I was hoping to put the new harness in my brothers Malibu this week and do some T&T. I don't think I will make it, but he wants to T&T his S-10 before he puts the blower back on.
Resources saved on this page: MySQL 1.09%
