Bump box is the shit!!!!!! - Yellow Bullet Forums
Old 05-27-2012, 12:43 AM   #1
schwiplarkin
Launchin
schwiplarkin's Avatar
Default Bump box is the shit!!!!!!
I just wanted to give mad props to Davis Technology and Joe O @ hyperaktive for this bad ass product.. Like a lot of you I have had issues trying to get my car to spool at the line... for the last month and a half I have embarrassed my self by trying to foot brake into the beams.. I was successful a couple of times but just couldnt get it consistantly.. well I talked to Joe and ordered the bump box from him... tried it at the track today and couldnt believe how easy it is to stage now!!!! Just light the first bulb,hit the trans brake, get to the limiter and hit the bump button,,, goes right to the second bulb at target boost!!!! If you guys have been struggling like I have been do your self a fovor and call joe!! I had mine in three days.......Do it!!!!
It's not that turbos are the best,,,,,,it's just that the best choose to use them....
schwiplarkin is offline   Reply With Quote
Old 05-27-2012, 01:01 AM   #2
luv2xlr8
luv2xlr8's Avatar
Default Re: Bump box is the shit!!!!!!
what problems were you having foot braking before going in?? did you have enough brake pressure???
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 05-27-2012, 01:02 AM   #3
Shum
How much does one of those units cost?
TUNED BY BLUECAT
99 Z28- 347- Turbo - E85
Shum is offline   Reply With Quote
Old 05-27-2012, 09:05 AM   #4
boostedbowtie
boostedbowtie's Avatar
Does it just use a PWM on the solenoid like the FAST system .
I thought NLR stopped its " creep " unit because of patents that FAST has on it already .
boostedbowtie is offline   Reply With Quote
Old 05-27-2012, 09:07 AM   #5
boostedbowtie
Quote:
Looks like $ 450 on the web site .
Old 05-27-2012, 12:11 PM   #6
91silverfox
Member
Pullin gears
91silverfox's Avatar
What does your trans temp data look like ?
91silverfox is offline   Reply With Quote
Old 05-27-2012, 03:28 PM   #7
Dave Bowman
Turbo Terror
Dave Bowman's Avatar
"bump box" is designed as a device to do whatever you decide with it.. if you choose to hook it up to the transbreak to help you stage then so be it
look at it this way.. if you take a screw driver and use it as a hammer it is still a screw driver that may work REALLY well as a hammer
2008, 2009 & 2010 WCHRA Drag Radial Champion
2007 SCSN Drag Radial Champion
Sponsors:
- Dave's Engine & Machining
- Enterprise Motorsports & Differentials
- Precision Turbo
- Chiseled Performance
- Mickey Thompson Tires
- Moran Motorsports
- Hyperaktive Performance
- Davis Technologies
Dave Bowman is offline   Reply With Quote
Old 05-27-2012, 09:17 PM   #8
Doug Paddock
its blingtiffic™
Doug Paddock's Avatar
LOL @ Dave
To Brandon I'm glad you got it sorted out!!
TVC. (Team Vertically Challenged) Honorary Member!
Special Thanks to
Justin Overkill Racecars
Krusty,Meg and Neil at PBK
Hyperaktive Tuning. Joe is the BEST!!
Josh Lindsey Best kept secret in small tire racing! Bruder Bros!
M&M Transmissions, Marty at Chance!
The "Shock Nerd" Mark Menscer Motorsports
The Grey Ghost 6.53 @ 232 SCSN 1/4 mile DR winner
El Jefe Worlds Fastest Coyote Powered Mustang 215.4 standing mile not even trying!
Doug Paddock is offline   Reply With Quote
Old 05-28-2012, 12:36 PM   #9
schwiplarkin
Launchin
Quote:
I dont log tranny temp,, my tranny cooler setup is pretty efficient/overkill, i run a single heat sync type on the way back to the trunk where i have a cooler inside my engine cooling tank..
Old 05-28-2012, 12:50 PM   #10
jon volk
jon volk's Avatar
Glide or th400? How smooth/consistent is it? Some of the xfi stuff I've seen isn't all that smooth and the car rocks like crazy.
92 325i Mtech, 4.8 LS, th400 and a small plate.
95 M3, forged L33, 7675 CEA, TH400/Gear Vendors
jon volk is online now   Reply With Quote
Old 05-28-2012, 12:59 PM   #11
Jesse Lambert
Jesse Lambert's Avatar
How does this work? What does it pulse? Do you push the button and then let go when fully staged or is it a preset "bump"?
Twin Turbo 540" Conv. BBC
4.15 @ 182 mph
Special Thanks:
Dad (Rodney Lambert)
Dave @ www.teamzmotorsports.net
Curtis Boggs @ www.raceflowdevelopment.com
Dan @ www.schoneckcomposites.com/
Joel @ www.ormebrothers.com
Rob Zarcone
Merkel Racing Engines
Hyperformance Motorsports
Competitive Wiring
Whitey's Automotive
Davis Technologies
Tyson's Automotive Machine
Seth @ BorgWarner-Airwerks
www.workturbochargers.com
Jesse Lambert is offline   Reply With Quote
Old 05-28-2012, 02:07 PM   #12
AmericanBadAss
Launchin
AmericanBadAss's Avatar
Link to said produce?
AmericanBadAss is offline   Reply With Quote
Old 05-28-2012, 03:20 PM   #13
schwiplarkin
Launchin
Quote:
You use your regular trans button on the first bulb, while holding the your trans brake you push a second momentary switch when you hit your preset limiter, which sends the pulse to your trans brake which bumps you into the second bulb..it does have to adjustment knobs for fine tuning the bump..
Old 05-28-2012, 03:24 PM   #14
Dave Bowman
Turbo Terror
i press my transbreak button and once i am on the chip i press the other button and it pulses the transbreak button hence moving the car forward till i let go of that button and i have never let go of the transbreak button so once i let go of the other button the car is on the transbreak button still.
its adjustable to allow you to pulse as fast and as long as you need for your setup to work the way you want it to.. we have made ours move as little as 1 inch a pulse cycle
Sponsors:
- Precision Turbo
- Moran Motorsports
Old 05-28-2012, 03:32 PM   #15
schwiplarkin
Launchin
Quote:
http://www.prolineracing.net/index.p...hk=1&Itemid=61
This is the only place I can find a picture of it.. but if you have any questions or want to get one give Joe a call,,(847) 321-1982
