C-clip eliminators for an 8.8" out of an Explorer? - Yellow Bullet Forums
Old 05-26-2012, 07:43 AM   #1
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Default C-clip eliminators for an 8.8" out of an Explorer?
Who makes them? Every set I've seen so far says not compatible with truck brakes.
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
Old 05-26-2012, 08:49 AM   #2
rdub79
Platinum Member
rdub79's Avatar
Default Re: C-clip eliminators for an 8.8" out of an Explorer?
Not sure if they can be used with the truck brakes, are they disc or drum?
They can be made to work with SN95 Mustang disc brakes though.
http://www.yellowbullet.com/forum/sh...d.php?t=457417
88' Junk-N-Da-Trunk
rdub79 is offline   Reply With Quote
Old 05-26-2012, 09:10 AM   #3
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Drum brakes....and I stand corrected. It's a Ranger rear end. 28 spline axles.
270-784-1534
Old 05-26-2012, 10:29 AM   #4
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Also, if worse comes to worse, can the housing ends be cut off and replaced with a Mustang style end?
270-784-1534
Old 05-26-2012, 04:03 PM   #5
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Bump.......I'm not having any luck at all. I've searched everywhere!!!!
270-784-1534
Old 05-26-2012, 04:11 PM   #6
Honk if parts fall off
Drag Week Survivor
Quote:
If you are going to cut the hosing ends off then just go with the large 9" ends, Then you can choose any brake setup you want and you won't be fooling with c-clip eliminators.
Honk if parts fall off is offline   Reply With Quote
Old 05-26-2012, 04:16 PM   #7
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Quote:
My question is would it be just as cheap to buy a damn 9" housing and do that instead? If I'm going to have to cut off housing ends, change brakes, etc....hell I already have a 3rd member for a 9" anyway.
270-784-1534
Old 05-26-2012, 04:16 PM   #8
strokerduster
Launchin
strokerduster's Avatar
i'm using an 8.8, drum brake, from a ranger. cut the housing ends off and welded torino ends on and added bolt on mounting plate for retention and press on bearing. 47" flange to flange and axles equal length. worked well. all stuff, including axles from moser..........PS
strokerduster is offline   Reply With Quote
Old 05-26-2012, 04:20 PM   #9
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Quote:
What did you have to do to the backing plate for the drum brakes to make them work?
270-784-1534
Old 05-26-2012, 04:29 PM   #10
NMRA P/S 5090
NMRA P/S 5090's Avatar
i believe the ranger is still mustang sized ends. dont hold me to this, but the 8.8 in the explorer and f150 had much bigger bearings. what year ranger rear are you using?
Jared Bemish
OVALTECH PERFORMANCE
Many Many Thanks to: M.C.R.P., UPR PRODUCTS, BULLET CAMS, PAC SPRINGS, INGRAMS MACHINE SHOP, A&G AUTO PARTS, INTELLIFAB and THE CREW !!!!!
8.2 DECK MAFIA
N/A ALL DAY BABY !!!
NMRA P/S 5090 is offline   Reply With Quote
Old 05-26-2012, 04:31 PM   #11
strokerduster
Launchin
was going to 11" drums and had everything from f150. was an easy mod and it seems to work well. less weight than 9" and it would be overkill for my app at 2100 lbs.......PS
Old 05-26-2012, 04:34 PM   #12
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Quote:
I have no idea...it was in the truck (S-10) when I got it.
270-784-1534
Old 05-26-2012, 04:36 PM   #13
strokerduster
Launchin
email address and i'll send you a photo of how it turned out......PS
Old 05-26-2012, 04:50 PM   #14
NMRA P/S 5090
both the mustang and ranger use the same 7.5 and 8.8 rears resp. , the 8.8's retain the same 9" shoe size the same national 8660s seal and 5707 bearing, as well as the ability to use the ranger axles in the stang housing. so personally i would not see why the axle end would be sized diff. however im not lookn at it. i would imagine a set of mustang elims and 9" mustang drum backing plates would go right together on that rear.
Jared Bemish
8.2 DECK MAFIA
Old 05-26-2012, 04:51 PM   #15
NMRA P/S 5090
but ive been wrong before................lol!!!!
Jared Bemish
8.2 DECK MAFIA
