Best way to fix MINOR antifreeze leak - Yellow Bullet Forums
Old 05-19-2012, 07:03 PM   #1
Greg O
Member
Pullin gears
Greg O's Avatar
Default Best way to fix MINOR antifreeze leak
Got my new Dart Little M combo together and I have a very small coolant leak that I can't trace down. When I say small I mean I will have 1 or 2 drops of coolant on the garage floor after driving it. There will be a drop on the flat pad by the oil filter.
I have tried and tried to track it down using clean paper towels, etc. and I can't find a trail. I assume maybe one of the rear freeze plugs? But the towel always comes out dry when I wipe around the back of the block.
Anyway, with something this minor I am hoping one of the "fixes in a bottle" work rather than pull the motor.
What is a good one that will work if I already have antifreeze in there? I have seen:
GM seal tablets
Blue Devil
morosso ceramic
K&W block sealer
Thanks!
69 Camaro, 3450 Lb. street car
406, 9:1, pump gas, AIS meth
D1SC~10psi.
1.319 60', 5.988 at 115
Greg O is offline   Reply With Quote
Old 05-19-2012, 07:08 PM   #2
MassD
Member
Pullin gears
Default Re: Best way to fix MINOR antifreeze leak
I personally have used the acdelco seal tablets and they worked really well for me. And i used them on an all original 67 chevelle that was leaking through the manifold and it stopped the leak right away.
MassD is offline   Reply With Quote
Old 05-19-2012, 09:00 PM   #3
187z
187z's Avatar
GM seal tabs.
187z is offline   Reply With Quote
Old 05-19-2012, 09:10 PM   #4
69chicken
69chicken's Avatar
Bars leak always stops head studs leaking on stock block builds for us budget guys.
69chicken is offline   Reply With Quote
Old 05-20-2012, 03:20 AM   #5
bdr82z28
Brewmaster
bdr82z28's Avatar
Bars leak fixed a freeze plug for me that was between the block and trans on an import engine, took care of the leaky studs too on the sbc.
bdr82z28 is offline   Reply With Quote
Old 05-20-2012, 10:53 AM   #6
NPS Nova
NPS Nova's Avatar
For a "good size" leak, I use Irontight. To me it always seals well. It did do better then the GM tabs, but the tabs you can just keep around.
Also for a leak like your talking, about 1/2 - 3/4 teaspoon of common black pepper, YES OFF THE KITCHEN TABLE black pepper into a warm rad will stop that leak.
Whatever, just bring it.
NPS Nova is offline   Reply With Quote
Old 05-20-2012, 12:33 PM   #7
JBradley500
Moderator
I honestly think you should keep looking for the leak.
JBradley500 is offline   Reply With Quote
Old 05-20-2012, 02:20 PM   #8
bones427
bones427's Avatar
Barsleak here used it for freeze plug leak and stud leaks before.
70 camaro bbc 511,Canfield 310 heads, 2700 lbs 8.77/152 5.58/124 1/8, 71 scamp 10.99- 100 shot 11.68 n/a V's House of Horsepower. Scott Foxwell. Chris Straub,Total Seal.Callies. BME. C.U.D.R,A.
bones427 is offline   Reply With Quote
Old 05-20-2012, 03:04 PM   #9
Greg O
Member
Pullin gears
Greg O's Avatar
Quote:
I agree, but I am thinking it is one of the rear freeze plugs and it's not worth the effort of pulling the motor back out IMO. It's not coming from any other source that I can easily see. Not from the heads, radiator hoses, water pump, intake....nothing. It's just one drop alway on the flat pad right beside the oil filter.
The only knock I have seen on the GM pills is they may hurt the water pump. Is that true?
D1SC~10psi.
Old 05-20-2012, 03:39 PM   #10
mc0311grunt
Car ramrod
mc0311grunt's Avatar
Pepper.
For those who fought for it freedom has a taste the protected will never know
mc0311grunt is offline   Reply With Quote
Old 05-20-2012, 07:19 PM   #11
MassD
Member
Pullin gears
Ive used pepper in between rounds to stop a leak, and it might still be in there haha!! Going 4 years now and still running stron.
Old 05-24-2012, 06:38 PM   #12
nxtruck
Member
Pullin gears
nxtruck's Avatar
Quote:
X2. Bars Leak has helped me out more than a few times.
nxtruck is offline   Reply With Quote
Old 05-25-2012, 12:01 AM   #13
NAnova
Put some tracer dye in the radiator, put a black light on it. Should help you see where its coming from.
petro cooling system sealant is mostly what we use in a pinch and it works great.
NAnova is offline   Reply With Quote
Old 05-25-2012, 01:22 AM   #14
OldRusty
OldRusty's Avatar
Instead of pepper I use franks red hot... I put that shit on everything. Jk
I have used the tablets also with luck. But like someone already suggested put uv tracer die in it and a blacklight you WILL see where its coming from.
Chris Matheny
OldRusty is offline   Reply With Quote
Old 05-25-2012, 01:37 AM   #15
dragula1971
K&W block sealer
dragula1971 is offline   Reply With Quote
