just another ls1 s10 blazer swap... with a turbo - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 05-09-2012, 11:00 AM   #1
BigRicky3
BigRicky3's Avatar
Default just another ls1 s10 blazer swap... with a turbo
Hey folks, I just signed up to show off what Iíve been working on.
This is my 1996 Blazer Iíve had since high school. It popped a head gasket in the 4.3 a few years back, and things got a bit out of hand when I went to fix it.
Here are the drive train specs:
2003 5.3 Tahoe short block (60k miles)
used LS6 cam/ new AC Delco lifters
Trickflow pushrods
LS1 heads/ Trickflow springs and some mild bowl work
LS1 intake (filled egr & painted w/ Duplicolor wheel paint)
SLP oil pump
Trickflow timing chain
H2 (ďstreet rodĒ) oil pan from Pace Parts
Current Performance motor mounts
Escalade water pump
Misc. ARP fasteners (rods, heads, intake)
Nothing special or exotic (most of it is used crap that other people didnít want or need). Iím hoping the turbo & boost will compensate for not having a bunch of aftermarket stuff, and Iíve seen that proven on here a few times over.
I had the blazer 4L60E rebuilt by a local trans guru. He put in a Sonax sun gear, extra clutches, shift kit, and only he knows what else. He also sold me on a new stock 700R4 torque converter out of an 80's Z28. With this combination, it should stall around 2200-2400, and work well with the LS6 cam & 3.73 gears. I bolted it to the engine with an Advance Adaptors kit, #712500A.
The rear is going to be a narrowed 8.8 from an exploder with Moser axles & stock 3.73 gears, and caltracs.
Now on with some pictures:
And after some elbow grease & cash:
BigRicky3 is offline   Reply With Quote
Old 05-09-2012, 03:36 PM   #2
sandmann120
sandmann120's Avatar
Default Re: just another ls1 s10 blazer swap... with a turbo
What are you going to do for headers?
Remember when sex was safe, and racing was dangerous?
sandmann120 is offline   Reply With Quote
Old 05-09-2012, 04:22 PM   #3
BigRicky3
BigRicky3's Avatar
Here's some more pictures.
Custom stainless coil covers:
Here's a bracket I designed, and had a friend water jet. The big slots are so I can clock the compressor housing almost 360*. It's still in mock up stage, I'll end up painting it or polishing it.
Old 05-09-2012, 04:26 PM   #4
BigRicky3
BigRicky3's Avatar
Quote:
I'm going to use a modified 98 camaro manifold on the right side, and something along these lines for the drives side:
I made this up in SW to figure out proportions, and a material list. The final result is going to look a little different.
Old 05-10-2012, 01:35 PM   #5
fenton06
fenton06's Avatar
I hope that little 90* isn't your wastegate position, that won't work very well. Also, why did you choose to mount the turbo the way you did? Why not mount by the flange on the exhaust housing?
Benjamin Fenton - ┌П┐(◣_◢)┌П┐
fenton06 is offline   Reply With Quote
Old 05-10-2012, 02:00 PM   #6
BigRicky3
BigRicky3's Avatar
Quote:
Youíre not the first one to mention my thought on the waste gate placement. Could you (or anyone) please elaborate with a reason? Suggestions? Where did you put yours? Thanks in advance for the edumacation.
As far as the bracket goes, I wanted to have more support for the heavy turbo than just the log manifold. The pictures donít really show well, but there arenít any real strong place to mount the flange to the engine block, and not have a very cumbersome bracket. The placement also makes it super easy to clock the turbine flange, and dial in where the pipe is routing. I donít have much room to spareÖ
Old 05-10-2012, 09:34 PM   #7
BAD BOB
Member
Pullin gears
BAD BOB's Avatar
in your drawing i would rotate it around to the front of that manifold so it gets direct exhaust flow into it. with it to the side of the exhaust flow it may not control the boost too well bc the exhaust will bypass that port.
BAD BOB is offline   Reply With Quote
Old 05-11-2012, 08:48 AM   #8
BigRicky3
BigRicky3's Avatar
Version 2.0.
Critique at willÖ
Old 05-11-2012, 05:29 PM   #9
brian_rs/ss
Burnout box
brian_rs/ss's Avatar
my buddy has a 6.0 h/c/nitrous blazer that was done on the cheap. thing is pretty serious for the money invested. i always loved blazers for the way they leave.
i got some video of it a while back on motor. ran a 7.0 and he's still working out the tune and some gremlins on the bottle.
http://www.youtube.com/watch?v=Pko8TzWSdkg
hope that motivates you.
brian_rs/ss is offline   Reply With Quote
Old 05-11-2012, 06:30 PM   #10
2baditsnotachev
2baditsnotachev's Avatar
Your wastegate angle is still no good. Imagine your exhaust as water flow and you want it to flow very easily into the wastegate. Your tube is at 90į to they direction of flow. I would move the wastegate tube down into that radius so the wastegate is more inline with the main log of the manifold. Basically imagine your log continued straight and place the opening for the wastegate there
2baditsnotachev is offline   Reply With Quote
Old 05-11-2012, 08:12 PM   #11
deadhorse66
deadhorse66's Avatar
Much better. You're still going to have the #1 cylinder blowing into the turbine unregulated, but it might still work ok. Just like said above, move that wastegate flange down on the log until it makes a smooth merge, and you'll be much better off.
deadhorse66: head wrench for tim99ws6, small turbo/275 radial
Special Thanks to our sponsors:
MidWest Chassis
AEIcnc
Cage Rage Chassis
Race Wire Solutions
Ace Racing Transmissions
deadhorse66 is offline   Reply With Quote
Old 05-11-2012, 08:21 PM   #12
BigRicky3
BigRicky3's Avatar
That's sweet, what's he hot for gears & trans? Is he leaving off the footbrake, or transbrake?
Thanks for the help with the manifold design, guys. Its a nice luxury to build it all electronically before striking an arc.
Any more input is welcome.
Also, further "motivation" may be contributed via paypal
Old 05-14-2012, 08:45 AM   #13
BigRicky3
BigRicky3's Avatar
I understand now what youíre saying about moving it down, to have a more strait shot (and about the flow into the wastegate in general). It may end up being that way, but, I think it would interfere with the power steering pump if put there.
I do think this will clear (and provide some regulation for cylinder one):
New can of worms....
Where to put the Left & right bank O2 sensors? I see the "kits" have them in the back of manifolds (close to where they would be from the factory). I donít think I like that, as they would both be reading (in my case) the right bank, and not the left. I'm thinking back of the manifold on the right bank, and the front of the manifold on the left bank.
Any thoughts?
I am putting a wideband in the down pipe.
I am also running a factory "old" computor, from around 2002
Old 05-14-2012, 08:34 PM   #14
2baditsnotachev
That's much better I would still try to to more of a radius into the main log but if you run a large wastegate that should work fine.
Old 05-14-2012, 09:18 PM   #15
LS1NOVA
LS1NOVA's Avatar
You could tune it open loop and ditch the 02 sensors all together.
www.One-guys-garage.com
LS1NOVA is offline   Reply With Quote
Resources saved on this page: MySQL 0.99%
