Mixing methanol & nitromethane - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Racing Fuels
Old 02-19-2008, 09:18 AM   #1
promachine
Pre-Staged
promachine's Avatar
Default Mixing methanol & nitromethane
Has anybody had any success mixing methanol and nitromethane at small percentages??(i.e. 90%methanol 10%nitro)What kind of power increases did you find?? any problems with heat.?
Bryan
5.71 @118 2700lbs
1.18 60ft
n/a 434 SBC alcohol injected
promachine is offline   Reply With Quote
Old 02-19-2008, 10:52 AM   #2
George Klass
George Klass's Avatar
Default
It can be "very" successful. Of couse there will be "problems with heat". Horsepower is a function of heat, the bigger the bang in the combustion chamber, the more heat is generated. When you play with nitromethane, remember, it's a slow burning fuel and you will need to dial-in more lead on the ignition. It is a different animal than running straight alky.
Drag racing in the 1960's
www.georgeklass.net
George Klass is online now   Reply With Quote
Old 02-19-2008, 06:25 PM   #3
Kevin Zaske
Eddie Haskell
Kevin Zaske's Avatar
Default
If you are going to do it, measure the mix by specific gravity with a hydrometer. Not by volume. And I would use 30%
Kevin Zaske is offline   Reply With Quote
Old 02-19-2008, 06:56 PM   #4
promachine
Pre-Staged
promachine's Avatar
Default
Any idea on the correlation of % nitro to % increase in HP?? i.e would 30% nitro get me a 10% increase in power?? Also, is 30% safe, if I use less than 30% will I not see any real increase in power??
Thanks for the input,
Bryan
5.71 @118 2700lbs
1.18 60ft
Old 02-19-2008, 07:00 PM   #5
Kevin Zaske
Eddie Haskell
Default
Never dyno'd it and never used less than 30%.
Old 02-19-2008, 07:43 PM   #6
mrdragster1970
T/S 368E
mrdragster1970's Avatar
Default
Quote:
Excellent tip. Ask me how I know.
Also as said, I don't think I would waste time, money & energy learning on less than 30%. Probably not worth the gain you would get.
50% is used by a few FED guys I've talked to. Not an expert, but I believe there is or was a big following of a 50% class.
Good luck, we want videos of you testing!!!!
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 02-20-2008, 10:25 AM   #7
Pooch565
Pooch565's Avatar
Default
If you are going to use 30 plus percent of nitro, you better have a really good ignition and bottom end. The deal with nitro is detonation. If it starts to detonate, it is not controllable. It will actually produce a high order detonation. You want to start small. 5 % will give you enough hp to generally get 7 hundredths to a tenth in the 1/4 mile. You want to richen up approximately 15% for every 5% nitro. If you are wanting to try a fuel that will produce similar results, try the M5 methanol. You should get a tenth or so over regular methanol.
Jason
Jason Rueckert
Regional Manager
VP Racing Fuels -Midwest
812 878 2026
jason@vpracingfuels.com
Pooch565 is offline   Reply With Quote
Old 02-20-2008, 10:39 AM   #8
George Klass
Default
Nitro is a strange fuel. Spill a puddle on the ground and throw a lighted match in it. Nothing happens. Spill some on your garage floor and hit it with a hammer. The hammer will disapear, along with your arm and most of your garage.
www.georgeklass.net
Old 02-20-2008, 11:41 AM   #9
mrdragster1970
T/S 368E
Default
We were stupid & knew a rich guy with a P/M. We talked him into using nitro. After we split the block on the 1st pass, we knew how not to try it.
In memory of Chris
Old 05-15-2008, 05:17 AM   #10
gt_diesel
gt_diesel's Avatar
Default
You should be able run 30% without changing any jetting at all... If you run less than 30% you would actually have to lean the motor out a bit because the weight of the Nitro is soo much more and you actually end up with more mass going in than what the engine will handle.
I ran a 383 small block chevy with a hillborn injection.. I have tried running a little bit of nitro on occation and it will definately make you go quicker.
gt_diesel is offline   Reply With Quote
Old 05-15-2008, 08:50 AM   #11
Bellman
Bellman's Avatar
Default
Many years ago I was getting advice from the late/great Elmer Trent on how to setup a drag bike to run on methanol..
After having the bike drinking meth like it was water.. I never saw the gains I expected.. At that point Elmer told me to add 10% nitro to the mix.. He garranteed I'd get the power increase I was looking for..
Unfortunately, when I went to a local Top Fuel drag boater in the area that sold nitro.. He only sold it in 55 gal drums.. And even back in those days.. The cost of a drum of nitro just about blew me away...
86 Mustang GT
383 ci SBF
Garrett GTX5518r turbo
TH400 Tranny
Bellman is offline   Reply With Quote
Old 05-15-2008, 09:11 AM   #12
Uncle Paul
Uncle Paul's Avatar
Default
Wow flash back, I ran DragBike for years and saw the late Elmer Trett many times.
As far as mixing nitro w/methanol, the best guy I know to talk to is Spud @ http://www.fuelinjectionenterprises.com/
Uncle Paul is offline   Reply With Quote
Old 05-16-2008, 08:52 AM   #13
Bellman
Bellman's Avatar
Default
Knowing Elmer is kind of showing our ages ..
That Spud site is the one to have if you're playing with nitro.. Very informative.. And interesting reading..
86 Mustang GT
383 ci SBF
TH400 Tranny
Old 05-16-2008, 12:16 PM   #14
Uncle Paul
Uncle Paul's Avatar
Default
Bellman you are correct. We are old enough to know better and young enough to remember.
Resources saved on this page: MySQL 2.11%
