turbo 400 wont shift - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 04-17-2012, 12:57 PM   #1
hellbound
Member
Pullin gears
hellbound's Avatar
Default turbo 400 wont shift
Put a turbo 400 in sons nova and it worked fine for like 2 months then it just stopped going into 3rd? it stays in 2nd and no matter how high u take rpms up it will not shift ...
any Ideas what i need to look for check ?
we now have it out of car
HELLBOUND
my chevelle build
hellbound is offline   Reply With Quote
Old 04-17-2012, 01:44 PM   #2
JBoone
JBoone's Avatar
Default Re: turbo 400 wont shift
Does it make the 1-2 shift. Maybe something to do with the detent silnoid leaking by
JBoone is offline   Reply With Quote
Old 04-17-2012, 01:50 PM   #3
hellbound
Member
Pullin gears
hellbound's Avatar
Yes shifts fine just won't go to third. i even took shift cable off and put in 3rd but only goes 1-2
HELLBOUND
my chevelle build
Old 04-17-2012, 01:59 PM   #4
JBoone
JBoone's Avatar
I think it is the detent. Do you have another 400 setting around Drop the pan an swap it or make a block off plate.
Old 04-17-2012, 02:02 PM   #5
hellbound
Member
Pullin gears
hellbound's Avatar
I do. but what do i need to do to the detent ? it has the electric switch i think cause it didn't have cable hookup to carbon
HELLBOUND
my chevelle build
Old 04-17-2012, 02:11 PM   #6
JBoone
JBoone's Avatar
If its un hooked it wont down shift(passing gear) I have seen the valve go bad an that make the transmission stay in second(passing gear) When u open that port on the valve body your in second. block the port of on u should get the up shift back
Old 04-17-2012, 02:16 PM   #7
JBoone
JBoone's Avatar
Also i busted a roller clutch one time in a 400 that was supose to have a sprag in it. But i thing it just had low when the roller clutch let go
Old 04-17-2012, 02:18 PM   #8
hellbound
Member
Pullin gears
hellbound's Avatar
Well it doesn't have cable to carb but does have a electric hookup on linkage side near rear of trans that i hooked nothing to ? so i am not sure what your saying to do ?
HELLBOUND
my chevelle build
Old 04-17-2012, 02:32 PM   #9
JBoone
JBoone's Avatar
Swap out the silnoid valve in side the pan the valve is leaking through. Drop the pan take out two small bolts unplug an put it a different one. Or block it of with flat bar. Yours is most likely bad. Stuck open. Its like its trying to down shift all the time. It happens had it happen on a freshs trans
Old 04-17-2012, 07:08 PM   #10
Hutch
Moderator
Hutch's Avatar
Take it apart and check the high clutch and sealing rings. The first stage of repair should be inspecting the internals while its out.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Resources saved on this page: MySQL 1.09%
