Compression Ratio on Turbo Engine - Yellow Bullet Forums
Old 04-15-2012, 10:51 AM   #1
bvaughan
Spooled up
bvaughan's Avatar
Default Compression Ratio on Turbo Engine
What do you think is the best compression ratio for an all out turbocharged race car (drag racing). I have heard a lot of people are in the 10 to 10.5:1 range. I am running about 9.5:1 now, but I am building another engine for next year.
Paul Powell Performance for the tune
Brinkley Performance for the bullet
Jim Robinson for the glide
bvaughan is offline   Reply With Quote
Old 04-15-2012, 11:37 AM   #2
TurboII
TurboII's Avatar
Garage
Default Re: Compression Ratio on Turbo Engine
9.5-9.7 on gas and 10.5-10.7 methanol. This is a sliding scale based on cuin and turbo you are allowed to run. If boost is limited CR is usually raised some to compensate. If you have a turbo on the large side and tons of boost available then on the lower side of numbers. Other things influence the CR as well and without all the info on the setup these are just general statements and nothing specific for your setup.
TurboII is online now   Reply With Quote
Old 04-15-2012, 11:37 AM   #3
KenB
KenB's Avatar
We are at 11:1 on E85
KenB is offline   Reply With Quote
Old 04-15-2012, 11:42 AM   #4
jaidedeye
im running 9.7:1
jaidedeye is offline   Reply With Quote
Old 04-15-2012, 11:57 AM   #5
bvaughan
Spooled up
bvaughan's Avatar
Good points. I am looking to run rs275. The class is limited to 76mm turbos. I am at 408 CID now, but I am going to build something max effort around 350 CID for next year. I want to run as much boost as possible at that CID. I am guessing I could make 20-25 psi with 350cid. I want to run more compression to make up for the low boost.
Old 04-15-2012, 01:23 PM   #6
turbo c
Spooled up
I run 9.8:1 338sbf 93 with meth 19psi
turbo c is offline   Reply With Quote
Old 04-15-2012, 02:36 PM   #7
Slugg0
Spooled up
Slugg0's Avatar
Quote:
Originally Posted by bvaughan View Post
The class is limited to 76mm turbos. I am at 408 CID now, but I am going to build something max effort around 350 CID for next year. I want to run as much boost as possible at that CID. I want to run more compression to make up for the low boost.
I'm not real smart, but I'd start with the compressor map since that is the limiting factor and build based off that. You may find broader power and/or more reliability from different combos that max a particular turbo.
Slugg0 is offline   Reply With Quote
Old 04-15-2012, 05:52 PM   #8
LTLHOMER
LTLHOMER's Avatar
11:1 or more gas or alky. Compression is your friend.
'98 Mustang
5.7 HEMI, Work Turbochargers, Big Stuff 3
Hyperaktive Performance Solutions
LTLHOMER is offline   Reply With Quote
Old 04-15-2012, 06:04 PM   #9
bvaughan
Spooled up
bvaughan's Avatar
Some of the guys seem to be running big cubes 400+ with the little 76mm. They are running in the 5.30 to 5.50 range. I figure they must be making good low end torque for better 60 ft times. The class is 1/8th mile. I figure the compression could be helping build boost on the line better.
Old 04-15-2012, 07:17 PM   #10
TurboII
TurboII's Avatar
Garage
I would look at the BW 76mm that you can he with a 1.50 A/R and max the cuin for this hot side. Im guessing it may be larger than 350cuin.
Old 07-04-2012, 12:28 PM   #11
RDY4WAR
What's the max anyone has run on pump gas on here?
RDY4WAR is offline   Reply With Quote
Old 07-04-2012, 02:47 PM   #12
LilJohn
LilJohn's Avatar
Max effort limited turbo....
12:1 maybe more. Static compression means jack anyway. Its all about dynamic.
Personally seen 30psi on a motor thatll crank 200....Another person told me they put 50psi on an engine that cranks 240.....And i believe it.
As long as you arent octane limited.... More is better.
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 07-04-2012, 02:58 PM   #13
randyrw
randyrw's Avatar
I'm at 10.5-1 on our gas 509bbc at 28-29psi boost
www.leashelectronics.com Boost Leash, Pulse Leash push button staging system, Nitrous timers, wiring boards, ect...
http://sherwood-performance.smugmug.com
2000 Mustang 509BBC twin 88's Radial SHOP CAR best 4.43@175 1.19 60ft 3.02 330ft ON 275 RADIALS!! http://youtu.be/eVOGMDLzv2U
Check out my Boost Leash video http://youtu.be/4ZyLtsWalMY
randyrw is offline   Reply With Quote
Old 07-04-2012, 02:58 PM   #14
88mmRocket
88mmRocket's Avatar
Quote:
E85 is allowed in the class. I would go with 10.5:1 or so.
stock block junk
B&K Performance
Ultimate Convertor Concepts
LJMS
A veteran is someone, who at one point in his or her life, wrote a blank check made payable to the United States of America for an amount of "Up to and including my life."
Thank you for those who have served and continue to serve.
88mmRocket is online now   Reply With Quote
Old 07-04-2012, 03:01 PM   #15
mjk
Member
Pullin gears
I have seen upward of 14:1 on some pretty ridiculous cars. Of course, this narrows the tuning window quite a bit, but if it's a max effort, why not go all out? Of course this would be on methanol.
Myself, I will be building a 10 or 11:1 street motor to be run on E85. Off boost the higher compression will make the car less lazy to respond, on boost, it will just make it a handful!
My little pony - 1992 Fox 'vert - Ultra Street build in progress.
A BIG thanks to Paul Demer at JCR Chassisworks, the Team Z Motorsports crew, Matt at Darkside Motorsports, and Jon at Midwest Fox Rods. Without these stand up people and companies offering support, products, and encouragement, my build would be nothing.
mjk is offline   Reply With Quote
