Spare tire wall mount - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Trailers
Trailers Talk about trailers, upgrades, goodies and towing
Old 04-14-2012, 12:57 PM   #1
Louie L
Louie L's Avatar
Default Spare tire wall mount
I made this spare tire mount out of scrap i had in the garage. Im wondering if its any good. I would like to mount it high on the wall off the floor and would hate for it to crash on the trunk of my car. Opinions on any modifications that it needs like a longer base? The wheel and tire weighs 44 lbs.
Made my own because most of the stuff out for sale is no better than what I have built. Any opinion on what fasteners it needs for mounting to the square tubing in the walls?
Louie L is offline   Reply With Quote
Old 04-14-2012, 06:42 PM   #2
Louie L
Louie L's Avatar
Default Re: Spare tire wall mount
I went ahead and installed it. Its very sturdy... so it stays
Old 04-30-2012, 10:28 PM   #3
stage20
did you just mount it through the wood wall, or is it anchored into the steel stud as well? im scared to put my tire on the wall, though id like to. i just load and unload it with the car. its still easy to get to if i need it.
TJ
88 iroc-z/28 408 LSx
all the good stuff.
05 2500HD 6.0L
one hauls, one hauls @$$!
CHP May 2011 feature
http://www.chevyhiperformance.com/fe...aro/index.html
stage20 is offline   Reply With Quote
Old 05-01-2012, 04:41 PM   #4
Louie L
Louie L's Avatar
Its mounted to the steel wall stud. I tolk the trailer on a trip last Saturday, 2 hour drive thing hadnt moved. I got tired of it being in the way on the floor.
Old 05-01-2012, 06:24 PM   #5
Eman85
I've seen a lot mounted like that but it still scares me. What type of bolts/screw did you attach it with? The studs in most walls aren't square tubing. Most are basically stop sign posts looking made from stramped sheet metal.
Eman85 is offline   Reply With Quote
Old 05-01-2012, 09:54 PM   #6
stage20
Quote:
some are very thin on the economy trailers. i want to say .030. i think the ones in my pace are .060 or .090. a few #10 or #12 self drilling screws should hold a couple hundred pounds, IMO. but that once instance is what i keep thinking about.
TJ
all the good stuff.
05 2500HD 6.0L
Old 05-02-2012, 08:09 AM   #7
Eman85
I have a Pace but the idea of hanging a 16" steel wheel and tire on that trailer wall just don't seem natural to me. mine had the spare bolted outside to the frt. with 3/8" bolts thru the wall with aluminum diamond plate inside and out and I didn't think that the wall was strong enough for that.
Old 05-02-2012, 09:07 AM   #8
gf20295
i would lengthen and widen the rear support piece you are anchoring to the wall studs....the haulmark bracket is twice as wide and is as tall as the spare tire...it also has a wider gromet to enforce the bolt/hold-down mechanism.
i moved mine off the wall to the floor ...rather be safe than sorry
gf20295 is offline   Reply With Quote
Old 05-02-2012, 03:43 PM   #9
SS-396
Member
Pullin gears
I mounted my bracket to the wall behind the trailer tire tubs, and the tire rests on the floor also. A lot of dead weight on the wall to come crashing down on anything inside the trailer...
SS-396 is offline   Reply With Quote
Old 05-03-2012, 12:12 PM   #10
bigsix
Member
Pullin gears
bigsix's Avatar
Quote:
I did exactly the same thing for the same reason. There's alot of bounce at the back end of the trailer and I couldn't live with myself if it ever broke loose and damaged my car or bikes.
1969 camaro, pump gas 540"bbc, Jerico, 9", street car.
1967 SS/RS camaro, pump gas efi 620"bbc, t-400, 9", project car.
bigsix is offline   Reply With Quote
Old 05-03-2012, 01:07 PM   #11
Louie L
Louie L's Avatar
In gonna attach a SS cable and loop to the wheel and top roof stud. If it comes off, it will hang there and not damage the car.
Old 05-03-2012, 06:58 PM   #12
stage20
Quote:
now you are giving me ideas. i would use an old black seatbelt or a black ratchet strap for looks.
TJ
all the good stuff.
05 2500HD 6.0L
Resources saved on this page: MySQL 1.06%
