Best Brake, shear, and bead roller - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 04-11-2012, 01:01 AM   #1
9secondlx
9secondlx's Avatar
Default Best Brake, shear, and bead roller
Looking to purchase a sheet metal brake, shear, and bead roller, I have looked at mitler brother and baleigh, was just wondering if there was anything else I should look into.
Looking to start doing tin work, wings etc.
As always any help is appreciated.
Only want to buy this stuff once.
9secondlx is offline   Reply With Quote
Old 04-11-2012, 08:05 AM   #2
JCRVETTE
JCRVETTE's Avatar
Default Re: Best Brake, shear, and bead roller
We have the Mitler bros alum frame power beadroller, a 52" Pexto stomp shear, a generic no name 4' box and pan brake, and a 10' 14ga brake from Engage machinery. I am very pleased with all of it. Mitler bros makes the best bead rollers hands down. They will also make custom dies for you if you supply them a rough drawing. I also believe pexto makes the best shear, and Tennsmith is the best brakes you can buy. Check craigs list for barely used stuff. The high end stuff will last forever if it was taken care of and there are many good deals to be had for used that are still in perfect shape. A 50 yr old pexto or tennsmith will work better, last longer than a Chinese knock off from new. A little cleaning and a coat of paint goes along way for 70% discount off new.
Paul @ JCR Chassisworks Weirsdale, Fl. 352-821-FAST (3278 )
follow us on FACEBOOK
www.jcrchassisworks.com
JCR Upper and Lower Mustang Torque Box Install and 25.3 New Edge Build
A few JCR build threads - Click links below
Top Sportsman Plymouth Duster
'06 GTO Street/strip Car with Solid Rear Axle
1st Gen Camaro Flush Lexan
JCRVETTE is offline   Reply With Quote
Old 04-11-2012, 09:12 AM   #3
CurleysRacecars
Mittler Bros roller. Id go with Pexto/Tennsmith or other American made equipment for the shear and brake. Just my opinion...
Kyle Curley
Curleys Racecars & Components
(916)-397-3465
www.curleysracecars.com
DEALER FOR:
Kinetic Engineering
Viking Performance
AFCO
Dynatech Headers
Call or message for the best pricing!
CurleysRacecars is offline   Reply With Quote
Old 04-11-2012, 09:16 AM   #4
Defender Chassis
Spooled up
Defender Chassis's Avatar
Quote:
^^^^^Good advice....
I have a Pexto (Peck, Stow & Wilcox) 52" gap shear. I paid $600 but it had been sitting unused for several years. It cleaned up well and works fine. New its going for $16,000 from TrickTools.com. I also have a Chicago, Dress & Krump 8' 16ga brake I gave $600 for. Not sure of the new price but its a nice piece and is still sold today. I also have the biggest bead roller that Mitller sells and I like and recommend it as well. Not sure of your budget but I would recomend staying away from anything imported. I have had a 52" imported stomp shear and I was never able to get it to cut right or get bthe clamp to keep the material from shifting. I also had a 5' brake and a 48" box & pan brake that was imported. They have both been replaced by the Chicago 8' and a Tennsmith 4' B&P for similar reasons for replacing the stomp shear. My advice is get the good stuff now and spend your time working not working on your equipment.
Defender Chassis is offline   Reply With Quote
Old 04-11-2012, 09:21 AM   #5
ojh
ojh's Avatar
ProTools down in florida make a very nice power bead roller, i've had mine for 20(?)yrs and regularly do 16ga steel with it. I have enco shear and it serves my needs although it struggles with .090 aluminum and 16ga steel - i believe the same machine from pexto would just whack thru it. My brake is 4' whitney, 14ga, there is the odd time when i wish i had larger but the shop space is the problem (i'd love to have that 10' 14ga machine the poster above has, that has got to be a bad sob - hydraulic?).
There is another bender for lighter gage metal, magnetic so there isn't an upper deck to clamp the metal. Set the metal in the brake and engage the magnet, it can't move and bend away. It is the tits for close bending complicated shapes for brackets etc. Have a looksee at them, baliegh might have one.
A small shrinker stretcher ought to be on your list as well, don't bother with engilsh wheel for drag race cars.
ojh is offline   Reply With Quote
Old 04-11-2012, 10:24 PM   #6
9secondlx
9secondlx's Avatar
thanks for all the reply's guys keep em coming, doing some searching now but nothing in the local craigslist. was wondering about the baliegh 3 in one, anybody have any input on it, atleast for the shear and brake?
Old 04-11-2012, 10:41 PM   #7
Defender Chassis
Spooled up
I have never seen one of the 3-1 machines that was not imported and a POS.
Old 04-12-2012, 08:03 AM   #8
JCRVETTE
JCRVETTE's Avatar
Quote:
X2
Old 04-12-2012, 02:43 PM   #9
MichaelP
MichaelP's Avatar
Just one data point, but here at work we have a 4' powered shear that literally runs all day long. It makes between 500,000 and 1,000,000 cuts a year. It's an old Wysong unit built in NC.
1999 Chevy Silverado Pro Stock Diesel - under construction. LBZ Duramax, GT4202R over GT5541R, Sponsored by ISSPRO and Chris Alston's Chassisworks
1973 Vega Super-Gas car, 481" BBC
1974 Vega bracket car, 350" SBC
1973 Pontiac T/A 455
1992 GMC Typhoon
1973 Chevy Blazer with Pontiac 400
1995 F350 Crew Cab Dually - intake, exhaust, chip, injectors
2000 VW Jetta TDI - Kerma tuning, Der Chimera clutch
MichaelP is offline   Reply With Quote
Resources saved on this page: MySQL 2.22%
