How hard to hit a drag radial - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 03-31-2012, 10:55 PM   #1
MIKE FROM SM
Member
Pullin gears
MIKE FROM SM's Avatar
Default How hard to hit a drag radial
I just switched to a Hoosier 275/60 on my 3250lb Camaro. It is a BB N2O car. i am running 17.5 psi on a 10" wheel. If you look at the video, the tires wrinkle quite a bit and then is spins a little bit out. Do you think it needed more power where it spun or less?
http://www.youtube.com/watch?v=bjSUt...bbAUAAAAAAAAAA
MIKE FROM SM is offline   Reply With Quote
Old 03-31-2012, 11:31 PM   #2
scott foxwell
scott foxwell's Avatar
Default Re: How hard to hit a drag radial
Mike, it looks like it unloads when th front end hits the ground, like the rear gets light...maybe less rebound damping on the rears or a little more compression on the front?
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 04-01-2012, 12:21 AM   #3
MIKE FROM SM
Member
Pullin gears
It actually starts to spin while the front is in the air. It just smokes a lot more when the front tires hit the ground.
Old 04-01-2012, 01:04 AM   #4
qscamaro
Member
Pullin gears
qscamaro's Avatar
i never ran radials but id say may just a little more front end travel?? not very much front tire drop? just a old 28 10.5 slick tire guess lol
qscamaro is offline   Reply With Quote
Old 04-01-2012, 01:57 AM   #5
scott foxwell
Quote:
Well that's telling you something...
You're right...in slow mo you can see it start spining as soon as the front starts to drop.
Custom cams
423 391 7774
Old 04-01-2012, 02:11 AM   #6
luv2xlr8
luv2xlr8's Avatar
subscribing
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 04-01-2012, 02:16 AM   #7
CutlassRacer
X275!
CutlassRacer's Avatar
Are you using a progressive unit?
If so, I would give it more power a few tenths before it starts to spin.
Kevin
78 Cutlass Turbo Olds Project
FlatOut Racing - 91 Nissan 300ZX & 240SX & Lexus SC300 CHUMPCAR Endurance Racers
Want to race for 2 hours at a time? Contact me about road racing car rentals!
KSR Performance & Fabrication
Dealer for: TRZ, AFCO, Holley EFI, Hooker Headers, PST, and many more!
CutlassRacer is offline   Reply With Quote
Old 04-01-2012, 10:38 AM   #8
qscamaro
Member
Pullin gears
qscamaro's Avatar
yea to keep that front end up a little longer ang higher
Old 04-01-2012, 10:51 AM   #9
slow3rdgen
slow3rdgen's Avatar
Im curious why it only smokes the left tire?
slow3rdgen is offline   Reply With Quote
Old 04-01-2012, 12:35 PM   #10
kgiblin
Member
Pullin gears
It needs more air go up to 19 or 20 and tighten rear ext and comp a touch. And you should be good.
KG
kgiblin is offline   Reply With Quote
Old 04-01-2012, 01:36 PM   #11
CutlassRacer
X275!
It may need a little bit more air pressure, but I do not think it needs 19! You can watch the wrinkles in the sidewall go away and then it starts to spin, while the front tires are still in the air. Adding a little bit of power in that area should keep the tire planted better. If it tries to wheelie, tighten up the front extension a click or two, then take some travel out if it still wants to wheelie.
Kevin
Old 04-01-2012, 01:50 PM   #12
kgiblin
Member
Pullin gears
Exactly the reason you see the wrinkles go away is because the tread of the tire is now wadded up and then shakes and spins. More air! I run 18 to 21 in our leaf spring car. It 60s pretty good.
It also extends rear shock to quickly imo.
KG
Old 04-01-2012, 02:52 PM   #13
z289sec
z289sec's Avatar
Two questions:
1. What kind of rear shocks and spring? Where are the rear shocks set at on rebound and compression?
2. Are you using a progressive, if so...what's the ramp look like?
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 04-01-2012, 03:12 PM   #14
MIKE FROM SM
Member
Pullin gears
I thought I might need more air; I never see drag radials wrinkle like that. The car has split monos with cal tracs, strange doubles in the back full stiff on comp 5 clicks from full loose on ext. Front has afco doubles with about 7 clicks on ext and a bunch on comp. The progressive is flat for a few tenths and starts ramping up. I also have some launch retard that is in fairly quickly. The engine makes a ton of torque and the car is high geared.
Old 04-01-2012, 06:22 PM   #15
z289sec
z289sec's Avatar
You are going to have to tighten up the extension some, also check for binding in the rear....sure doesn't look to have much travel. Just to give you an idea, even with a small block in my car, I run QA1 doubles on the rear that have been revalved. 24 settings total on each side. I run my rebound (extension) at 14 off of loose on a decent track 18 off of loose on a good tight track, with about 4-5 clicks more on compression. This slows the extension of the rear shock, and keeps it from slamming the tire into the track, which will also give the sidewall a false low pressure look on launch. Not to say that you don't need more air...but it will amplify the wrinkling.
On to the fronts, I run the AFCO BNC doubles on the front of mine and had to send them back to AFCO and have them revalved. They now have their Pro-Mod valving. And remember, I'm just running a small block. Tight is your friend with a radial.....unless you want to run the limiters, which I don't like to do. I run all the travel in my front end, and control it with the shocks.
One other thing you can do on the progressive is to back up the ramp around three to four numbers on the initial ramp to bring the front end back down sooner and gentler. Say leave on 25% down to 22% for .3-.4 or wherever you converter tugs the motor back down, then you can start pouring the cold to it.
Hope this helps some.
RTCTTFMF!!!!
Just about done
Thanks to:
