1955 Chevy wheel/tire size - Yellow Bullet Forums
Old 03-29-2012, 12:34 AM   #1
adeeos
adeeos's Avatar
Default 1955 Chevy wheel/tire size
Did several searches without success. Can some of you 55 Chevy owners let me know what is the largest wheel/tire size that you can fit with a stock/factory rear wheel tub? Does moving the leaf spring inboard effect the size of the tire that will fit?
Post pics if you got em!
Go fast on pump gas
adeeos is offline   Reply With Quote
Old 03-29-2012, 12:51 AM   #2
mike1955
Launchin
mike1955's Avatar
Default Re: 1955 Chevy wheel/tire size
I have 15x8 with 4 inch backspace with a 28-11.5 et street or 275 drag radials works very well.
mike1955 is offline   Reply With Quote
Old 03-29-2012, 01:07 AM   #3
70Underpressure
Moderater
70Underpressure's Avatar
The 55 has a narrow frame and a big wheel tub so if you In board the springs you can run a 12 inch rim with out cutting the floor. It's the easyest car to mini tub because of this. There is a kit to put the spring pockets in the frame. The stock spring location with the fender lip rolled a 275 is possible but tight. I have a 18 x 10 on mine right now with the rolled lip and I cut the rearend to make it work.
“Life’s journey is not to arrive at the grave safely, in a well preserved body, but rather to skid in sideways, totally worn out, shouting ‘Holy shit, what a ride!’”
Reality always complies with our own sensible paranoia...
70Underpressure is offline   Reply With Quote
Old 03-29-2012, 02:20 PM   #4
BobH
BobH's Avatar
Quote:
there is a fit calcuator over at TriFive.com. You can put any combo and it will kick out clearances
good luck
bobh
BobH is offline   Reply With Quote
Old 03-29-2012, 05:12 PM   #5
BobH
BobH's Avatar
try this link
http://tri-5.chevyrides.com/rear_tire.php
Old 03-29-2012, 05:41 PM   #6
55chevy383
55chevy383's Avatar
^^^This^^^ But generally a 275 is it, on an 8" rim with 4" bs.
11.22 @ 117 n/a.
55chevy383 is offline   Reply With Quote
Old 03-29-2012, 05:56 PM   #7
70Underpressure
Moderater
This is a 15 x 8" 4" Bs 28 x 10.5 MT Sportsman Pro. Stock rear length with a rolled wheel lip. They fit perfect. I had to drop the rear shackel and shock to get them off though.
That's a great link Bob....
Old 03-29-2012, 06:27 PM   #8
BobH
BobH's Avatar
No problem. Glad it helped. Nice 55
BobH
Old 03-29-2012, 08:03 PM   #9
z289sec
z289sec's Avatar
This!!! if you move the springs inboard and had the correct backspace you could get a 12 inch wide tire under it easily. But the outer fender to axle clearance will stop you from getting it under there.
Anything more than a 4.5 bs won't fit with a stock width rear and stock ride height, even if you let the air outta the tires.
I run a M/T 275 Drag radial on a 15 x 8 with 4.5 bs.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 03-29-2012, 11:20 PM   #10
adeeos
adeeos's Avatar
Thanks for the replys and thank for the link Bob, very helpful.
Go fast on pump gas
Old 03-29-2012, 11:34 PM   #11
555nova
CFH
555nova's Avatar
We have a 15x10" rim and run a 295/50/15 on our 55 chevy. We cut the front spring pockets into the frame to fit the tires. We also have to drop the rear end out completely to get the tires mounted. Pain in the ass but I think worth it.
555nova is offline   Reply With Quote
Old 04-01-2012, 06:09 PM   #12
55sedan
55sedan's Avatar
My springs are moved inboard. Mini tubbed even with the frame. 12 bolt is 58'' flange - flange. Im currently running 10'' wheels with 6 1/2'' BS. Got some Hoosier QTP 29 X 14.5 fits great with plenty room on both sides. My plans are to go to a 11''Alumastar with 7'' BS with the same tire or a 29 X 10.5w.
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 04-01-2012, 10:28 PM   #13
scotts406
Spooled up
Nice car 55sedan! Working on my 55 2dr sedan for some abuse this summer. Your video is some good motivation!
scotts406 is offline   Reply With Quote
