Will this work- Intake system - Yellow Bullet Forums
Old 03-27-2012, 11:44 PM   #1
Greggy2belly
Pre-Staged
Default Will this work- Intake system
Finally making progress on my car, just wanted YB's opinion as I ran into a little hiccup.
The car is a 1994 impala ss, 383 LT1. Going carb'd and distributor, but not sure on the intake. Car will see a 200 shot, but this is the picture of the intake. It fits under the stock hood, but the insulation under the hood does make contact. If I have to I will buy a cowl hood, however I'd rather spend that $500 elsewhere on the car
Greggy2belly is offline   Reply With Quote
Old 03-28-2012, 09:02 AM   #2
charliep
Member
Pullin gears
Default Re: Will this work- Intake system
You could do better with a drop base for the air cleaner.
charliep is offline   Reply With Quote
Old 03-28-2012, 10:30 AM   #3
Greggy2belly
Pre-Staged
Quote:
Yea messed around with a couple today. Foud a 1.75 drop and a 2" filter will work with a 14" intake
Old 03-29-2012, 02:14 PM   #4
4thHorseman
Burnout box
4thHorseman's Avatar
I did this same thing in 2003 on a afr 210 headed 383ci LT1 in my former drag car - a '93 Formula. I picked up a bunch of ET switching over to a victor and an 850cfm dp from a ported LT4 intake and green top (48# ?) injectors. I epoxied the center manifold holes on the Victor and redrilled them for the Vortec style bolt placement. Capped off the water outlet and dizzy. I ran LS1 style coils with a conversion kit and capped the timing cover for the missing Opti.
Good luck.
'69 Mustang Mach 1
552ci @ 13:1 w/ P-51's, C6 & Nos
Out in the southwest desert
4thHorseman is offline   Reply With Quote
Old 03-29-2012, 03:28 PM   #5
98mmNotch
Pre-Staged
i would try the k&n top, check in summit for part number KNN-66-140
98mmNotch is offline   Reply With Quote
Resources saved on this page: MySQL 1.15%
