Wiring trans brake Please help - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 03-26-2012, 10:20 PM   #1
tommyd2006
Launchin
Default Wiring trans brake Please help
I have a pro brake and I'm trying to figure out how to wire it up with my delay box so that I don't haft to wait on the delay to get reverse do I run 2 trans brake buttons if so how do I keep the reverse button from back feeding to the delay box and still trig. The delay?
tommyd2006 is offline   Reply With Quote
Old 03-26-2012, 10:24 PM   #2
tommyd2006
Launchin
Default Re: Wiring trans brake Please help
Also what's your alls opinion on the best-fastest trans brake button on the market iv tried a few and I Always go back to the basic big red buttons
Old 03-27-2012, 08:39 AM   #3
Uncle Paul
Uncle Paul's Avatar
For reverse put a bottom on or near the shifter and by-pass your delay box.
For the fastest button use one with a controlled throw.
I'm your Huckleberry,,,,
http://www.northernchateau.com/
Uncle Paul is offline   Reply With Quote
Old 03-27-2012, 10:12 AM   #4
Hammertime
Hammertime's Avatar
Run a wire to one side of a btton to the wire going to transbrake terminal on the delay box, the other side of the button to 12v .. its direct this way to the solenoid. I suggest it on a push button but you can use it on a toggle .. but if you do leave that toggle on for a long time .. its going to burn up the wiring and solenoid on trans.
www.apdracing.com
Hammertime is offline   Reply With Quote
Old 03-27-2012, 10:26 AM   #5
mrdragster1970
T/S 368E
mrdragster1970's Avatar
I drilled a hole in my over head box and wired a switch to the brake.
After the burnout, flip the switch and go, no having to hold a button.
My delay box uses a ground signal, so there is no interference with the safety circuit.
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 03-27-2012, 10:35 PM   #6
tommyd2006
Launchin
Thanks guys I went to Jegs and picked up a new mega 450 and a large adjustible button so I will read the instructions and start this project shortly
Old 03-27-2012, 11:40 PM   #7
mrdragster1970
T/S 368E
That's a nice box, and even though it's been out a while, I'm sure it'll have everything you need!!
In memory of Chris
Resources saved on this page: MySQL 2.33%
