Dual Chutes - how far apart to mount anchors, and can you pull just one? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 03-23-2012, 04:38 PM   #1
MichaelP
MichaelP's Avatar
Default Dual Chutes - how far apart to mount anchors, and can you pull just one?
I'm building a chassis (25.2 Chevy pickup) that will eventually need dual chutes. I was going to go ahead and install them from the start, but am wondering how far apart to mount the anchors, and at that distance is it safe to pull just one chute? I typically go to the track by myself or with my 9-year-old daughter, so having to repack both chutes every round would be a little bit of a pain.
1999 Chevy Silverado Pro Stock Diesel - under construction. LBZ Duramax, GT4202R over GT5541R, Sponsored by ISSPRO and Chris Alston's Chassisworks
1973 Vega Super-Gas car, 481" BBC
1974 Vega bracket car, 350" SBC
1973 Pontiac T/A 455
1992 GMC Typhoon
1973 Chevy Blazer with Pontiac 400
1995 F350 Crew Cab Dually - intake, exhaust, chip, injectors
2000 VW Jetta TDI - Kerma tuning, Der Chimera clutch
MichaelP is offline   Reply With Quote
Old 03-23-2012, 06:30 PM   #2
mrdragster1970
T/S 368E
mrdragster1970's Avatar
Default Re: Dual Chutes - how far apart to mount anchors, and can you pull just one?
Mine are 2" apart, which is about as close as you can get with vertical bolts.
I know plenty of guys that pin one chute. I myself have had 2 chute issues, so now I always use both every time.
Trust me it's no fun when the chute fails, especially on a short track.
When my guys bitch about packing both, I just say oops, I meant to throw one, sorry.
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 03-23-2012, 07:22 PM   #3
CurleysRacecars
Id try to get them as close to each other as possible, in the center of the car obviously. If only one comes out, or you're using only one, you dont want it pulling on the car from one or the other side. Another thing to mention is chute handles. If you use two chutes, do you use two separate handles? I just got done (10 minutes ago), switching ours from 2 individual levers to one good 1/4" thick handle. They are both using the same bolt so that the cables both move at the same rate. Anyone have input on having one or two handles?
Not hi-jacking, just thought it fit here well.
Kyle Curley
Curleys Racecars & Components
(916)-397-3465
www.curleysracecars.com
DEALER FOR:
Kinetic Engineering
Viking Performance
AFCO
Dynatech Headers
Call or message for the best pricing!
CurleysRacecars is offline   Reply With Quote
Old 03-23-2012, 07:40 PM   #4
MichaelP
MichaelP's Avatar
Not a hijack Kyle, as that was my next question!
1992 GMC Typhoon
Old 03-23-2012, 10:49 PM   #5
lota junk
Spooled up
lota junk's Avatar
we run 2 handles about 4" apart
lota junk is offline   Reply With Quote
Old 03-24-2012, 03:27 AM   #6
FRYDAY
FRYDAY's Avatar
Quote:
http://www.jerrybickel.com/parachute...jbrc2010a.html
FRYDAY is offline   Reply With Quote
Old 03-24-2012, 03:31 AM   #7
FRYDAY
FRYDAY's Avatar
http://www.jerrybickel.com/parachute...jbrc2011a.html
Resources saved on this page: MySQL 2.17%
