PRO STOCK PONTIAC HEAD - Yellow Bullet Forums
Old 03-18-2012, 09:21 PM   #1
BOSSFORD
Default PRO STOCK PONTIAC HEAD
LAST 3 NUMS ON THE HEAD ARE 386
LOOKING FOR ONE? PAIR?
__________________________________
SELLING BOSS 302 ,BOSS 351 BOSS 429,AND SCJ CJ PARTS
BUY SELL TRADE FORD PARTS
or Complete engines, can dyno or test run
BOSSFORD is offline   Reply With Quote
Old 03-19-2012, 01:43 PM   #2
P/S
Pre-Staged
Default Re: PRO STOCK PONTIAC HEAD
The 386 castings are the small intake port version, the 454427 castings are the one's that we used in P/S. The exhaust ports are the same in both heads, the smaller heads are the same externaly as the 427's so the could be used with extra porting (more $$) are you looking for 4.840 or 4.900 bore center? The Brodix "Big Duke" casting is a copy of the Pontiac so you might want to check those out and I could possibly find you an actual set that we ran when I was working at the Rod Shop, they would be ported to that era's configuration and would be 4.840 b.c.
P/S is offline   Reply With Quote
Old 03-19-2012, 01:52 PM   #3
BIG MATT
Spooled up
The 427 intake ports are very close together ...needs a different intake.. I have 2 new 386 castings with seats and guides ....you can have them for $1500.00...jimmy 919-781-5700 9-5
BIG MATT is offline   Reply With Quote
Old 03-19-2012, 03:01 PM   #4
BIG MATT
Spooled up
Quote:
PS these are 15 degree heads
Old 03-19-2012, 03:04 PM   #5
Shoedoos
do the 386 castings take the same Jesel/T&D valvetrain components as the 427 castings?
Shoedoos is offline   Reply With Quote
Old 03-19-2012, 03:26 PM   #6
ty_ty13
ty_ty13's Avatar
my buddy had to change the stand heights/geometry to get his working right...
2002 camaro for sale. runs 4.30s
http://www.racingjunk.com/Complete-R...aro-4.30s.html
ty_ty13 is offline   Reply With Quote
Old 03-19-2012, 03:40 PM   #7
P/S
Pre-Staged
Quote:
Yes
Old 03-19-2012, 03:46 PM   #8
P/S
Pre-Staged
Quote:
You always have to mess with stand heights to get the geometry correct due to different valve-pushrod lengths ect. Remember, in racing there's no such thing as a bolt on part.
Old 03-19-2012, 03:54 PM   #9
P/S
Pre-Staged
Quote:
Originally Posted by P/S View Post
Yes
Like I said, both heads are the same except for the intake port size, one is a #454386 and the other is a #454427. The first versions were 18 degree and were changed to 15 degree in about 1994. I know this only because I designed the head in 1985 while I was at The Rod Shop.
Dale
Old 03-19-2012, 04:39 PM   #10
BOSSFORD
PMS SENT
Old 03-19-2012, 08:13 PM   #11
nosnerd
SomeWhat Jaded
nosnerd's Avatar
DALE EICKE??????
curious
"IGNORANCE SHOULD BE FUCKIN' PAINFUL"
522/798hp + NOS/I.S plate
Doin' it on 315's at full weight, ladies
*ULTRA PERFORMANCE and FABRICATION *
www.DandDPerformance.ca
nosnerd is offline   Reply With Quote
Old 03-19-2012, 08:20 PM   #12
levers
levers's Avatar
i have the 386,s that the casting epd uses , because there is less welding to fill everything up , to change the head to make it better.
levers is offline   Reply With Quote
Old 03-19-2012, 09:27 PM   #13
P/S
Pre-Staged
Quote:
Originally Posted by nosnerd View Post
DALE EICKE??????
curious
Yes Sir
Old 03-20-2012, 09:37 PM   #14
nosnerd
SomeWhat Jaded
nosnerd's Avatar
Very pleased to 'meet' you sir..i wish i could pick your brain...lol
Old 03-20-2012, 10:14 PM   #15
Mark Kasperan
Mark Kasperan's Avatar
Yes Sir
That's cool!
Exceptional Motorsports
Mark Kasperan is offline   Reply With Quote
Resources saved on this page: MySQL 1.00%
