Valve Train/Cam Design - Page 2 - Yellow Bullet Forums
Old 03-18-2012, 04:49 PM   #16
shawns engines
shawns engines's Avatar
Default Re: Valve Train/Cam Design
Quote:
Originally Posted by OldRusty View Post
Wouldn't a higher ratio help the valve spring keep the lifters on the cam by multiplying its pressure for more control? Kind of a catch 22 question.
Yes it would. Question, does the rocker have enough pivot length to move the pushrod cup far enough away from the fulcrum so energy from the pushrod rotates the rocker, rather then try and rip it out of the head.
Also with a higher ratio rocker every slight movement from the lifter/pushrod is transfered to the valve. Do we have large enough core sizes, base circles, lobes to allow them to be ground percise enough for a proper valve path with a high ratio rocker.
NMCA NA10.5
421 CI SB2.2 2016 - 8.67 @ 157
500 CI DRCE 2017 -
shawns engines is offline   Reply With Quote
Old 03-18-2012, 04:52 PM   #17
scott foxwell
scott foxwell's Avatar
Quote:
Originally Posted by shawns engines View Post
Dont agree. They make rev kits if you just wanna keep the lifter on the cam. Prostock valvetrains design the system so the lifter leaves the cam over the nose for more lift and keep pressure off the nose of the cam.
Valve springs job is to make the valve change directions. Do we really want to have the same valve path for the entire rpm band?
Rev kits are not valve springs. Valve springs are valve springs. PS valve trains aren't the only ones incorporating controlled loft, but IMO that's an entirely different conversation. Ideally, any lifter should see zero presure over the nose if everything is designed correctly.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 03-18-2012, 04:53 PM   #18
OldRusty
OldRusty's Avatar
Quote:
Originally Posted by scott foxwell View Post
It would seem that way, but 150# with a 2:1 rocker would essentially be the same as 200# with 1.5:1. The lifter needs X amount of pressure to stay on the lobe, whether it's from a 2:1 rocker, or 1.5:1. By using rocker ratio you can lighten the spring (mass) and your lifter acceleration on the lobe can be less and more easily controlled. That's one school of thought.
This is why spring RATE becomes more important with the higher ratio stuff since it produces more lift and accelerates the valve faster and still has to control the direction change of the valve/retainer/locks and also the spring mass. I don't have the answers, just theories in my head.
Chris Matheny
OldRusty is offline   Reply With Quote
Old 03-18-2012, 04:55 PM   #19
Chad Speier
Chad Speier's Avatar
I'd like to find a spring with 100 on the seat and 1500 open.
VFactor NATION
SRH Speier Racing Heads
785.623.0963
Chad Speier is offline   Reply With Quote
Old 03-18-2012, 05:05 PM   #20
scott foxwell
I aree. Two things have to happen...the lifter has to stay under control over the nose, and the valve can't bounce off the seat. Any more spring pressure than it takes to accomplish those two things I think could be considered parasitic.
Custom cams
423 391 7774
Old 03-18-2012, 05:06 PM   #21
OldRusty
OldRusty's Avatar
Quote:
Just increase installed height til you have your 100# seat, I don't think the results would end well.
Chris Matheny
Old 03-18-2012, 05:28 PM   #22
Chris Uratchko
Moderator
Chris Uratchko's Avatar
One problem is that there is no magical design. Everything discussed here is subject to the design of the whole system in terms of component weights, geometry, and rpm ....... just to name a few.
We can't say this way is better than that way as a mandate.... because for what application, design of system, and rpm?
Very complicated issue.
Chris Uratchko is offline   Reply With Quote
Old 03-18-2012, 05:36 PM   #23
Lobes
The nose of the cam is not where the "high pressure" is....unless it's not running.
But, that being said, I think we could all agree that the principle job of the valve spring is to precisly control the relationship between the lifter and the lobe. (whether the lifter is always on the lobe or not) So, anything that can be done to lower the reaction force on the lifter shoul make it possible to use "lighter" valve springs.
Lobes is offline   Reply With Quote
Old 03-18-2012, 05:37 PM   #24
Chris Uratchko
Moderator
I think the term 'high ratio' is subjective. Why would 1.5 be considered low and 1.9 be considered high? Why isn't 1.8 or 1.9 considered moderate? Because General Motors only came with 1.7 on a bbc in 1965?
I don't think we should get caught up in a number like that and calling it high, or low.
If I want a particular lift at the valve per deg.... you may not get there but with a particular ratio of multiplication.... it just is what it is.
Old 03-18-2012, 05:40 PM   #25
Chris Uratchko
Moderator
Quote:
But, that being said, I think we could all agree that the principle job of the valve spring is to precisly control the relationship between the lifter and the lobe. (whether the lifter is always on the lobe or not) So, anything that can be done to lower the reaction force on the lifter shoul make it possible to use "lighter" valve springs. Thoughts?
All this stated, can we make a spring 'act' with higher pressures if one lobe has more acceleration than another?
In other words, with greater acceleration does the reaction force increase requiring less spring rate in the end? It's like circular reasoning
Old 03-18-2012, 05:47 PM   #26
scott foxwell
Well we know what excessive pressure/rate does to pushrods... It's probably safe to say most enignes have more than one "valve spring" per valve.
Custom cams
423 391 7774
Old 03-18-2012, 05:47 PM   #27
Lobes
With greater acceleration at the lifter you would need more spring to control the greater inertial forces produced. F=ma
Old 03-18-2012, 05:49 PM   #28
scott foxwell
If we could get the cam and lifter for a pushrod engine to do what we wanted the valve to do, would you rather see a 1:1 rocker, or still use some ratio?
Custom cams
423 391 7774
Old 03-18-2012, 05:51 PM   #29
scott foxwell
or more ratio
Custom cams
423 391 7774
Old 03-18-2012, 05:52 PM   #30
scott foxwell
this...
Custom cams
423 391 7774
