CARPET!!! - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Auto Body and Paint
Old 03-14-2012, 08:11 AM   #1
DCC Motorsports
Burnout box
DCC Motorsports's Avatar
Smile CARPET!!!
I know this is a little off topic but don't where else to ask. Whats the best way to cut factory replacement carpet to fit around roll bars? any info would be appreciated!
DCC Motorsports is offline   Reply With Quote
Old 03-14-2012, 09:54 AM   #2
bruce69camaro
jus sayin pot stirrer...
bruce69camaro's Avatar
Default Re: CARPET!!!
I just used a new razor for each time I cut a new hole.
I marked the hole with a yellow or white piece of chaulk the kids had lying around.
Then I cut a line towards the edge of the carpet, slid the carpet around the bar and just worked my way around it with the blade.
My homeland security
Those who think they know it all, have no way of finding out they don't.........
bruce69camaro is online now   Reply With Quote
Old 03-15-2012, 08:12 AM   #3
DCC Motorsports
Burnout box
thanks for the info!!!!!
Old 03-15-2012, 08:18 AM   #4
bruce69camaro
If you need me to try and explain it better, let me know.
I couldn't find the correct wording, but it's pretty easy, just take you time and use sharp blades.
You can use a carpet tape to hold down the pieces of carpet that you cut, to slide the bar through or if it's at the edge by the door, you can use the door sill plates to hold them down.
Old 03-15-2012, 10:01 AM   #5
stage20
id tell you, but you will probably cut yourself. buy a real deal carpet knife and SQUARE corner blades. treat it right, its not a standard razor knife. it will cut you to the bone and you wont know it. use a new blade for each cut. makes them real clean. one tip is to spray some spray paint on the floor of the car in the color of your carpet. black carpet, spray some flat black on the floorpan. carpet miscut just a tad you cant see it.
TJ
88 iroc-z/28 408 LSx
all the good stuff.
05 2500HD 6.0L
one hauls, one hauls @$$!
CHP May 2011 feature
http://www.chevyhiperformance.com/fe...aro/index.html
stage20 is offline   Reply With Quote
Resources saved on this page: MySQL 1.15%
