CO2 Bottle mounting, what position? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 03-13-2012, 04:15 PM   #1
WS6HUMMER
Spooled up
WS6HUMMER's Avatar
Default CO2 Bottle mounting, what position?
Bought a boost controller that uses C02, so I got a 2.5# bottle from Jegs but I don't know if it matters what position you would want to mount it. Is there a tube in C02 bottles like a nitrous bottle or is CO2 a gas?
99 WS6 T/A GT4788 stock LS1
Dynocom 15000 with retarder.
WS6HUMMER is offline   Reply With Quote
Old 03-14-2012, 08:41 AM   #2
B Verwold
Launchin
B Verwold's Avatar
Default Re: CO2 Bottle mounting, what position?
CO2 is a liquid that turns into a gas, I have mine mounted with the regulator straight up ............Hope this helps
Bob V.
B Verwold is offline   Reply With Quote
Old 03-14-2012, 09:10 AM   #3
gary federico
gary federico's Avatar
Garage
We use it as a gas and I dont think there is a syphon tube in these bottles. Anyway but upside down or regulator not lower than bottom of bottle.
gary federico is offline   Reply With Quote
Old 03-14-2012, 09:21 AM   #4
JimL
JimL's Avatar
Always mount bottle right side up. Regulators can't handle liquid.
JimL is offline   Reply With Quote
Old 03-14-2012, 09:32 AM   #5
B Verwold
Launchin
B Verwold's Avatar
Side note, First time you get the bottle filled take some towels with you............If you wait on it.
Bob V.
Old 03-14-2012, 10:08 AM   #6
WS6HUMMER
Spooled up
WS6HUMMER's Avatar
Thanks for the info, so I guess my plans to mount the bottle horizontal on the center bar of my main hoop wont work huh?
Old 03-14-2012, 11:01 AM   #7
mrdragster1970
T/S 368E
mrdragster1970's Avatar
That was my plan also???
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 03-14-2012, 11:31 AM   #8
BadNotch676
Member
Pullin gears
BadNotch676's Avatar
Is there anyone that sell a complete kit or do you have to make lines and everything yourself?
BadNotch676 is offline   Reply With Quote
Old 03-14-2012, 11:52 AM   #9
B Verwold
Launchin
B Verwold's Avatar
I don't know anything about a "boost controller" I use my air (co2) for the throttle stop. You might check with Biondo Racing they have all the air parts you should need...
And a 10 oz bottle usually last me all season..
Bob V.
Old 03-14-2012, 01:36 PM   #10
Seattle_Mike
Seattle_Mike's Avatar
Air systems typically use standard push lock fittings, the black plastic hose, etc. that you can buy pretty much any truck stop, NAPA, etc. It's all common industry stuff and easy to plumb. You can get the fittings in either plastic material or brass.
68 Camaro ProMod - 848ci - M&M 3 Speed
www.yvonnelucasracing.com
Seattle_Mike is offline   Reply With Quote
Old 03-14-2012, 01:46 PM   #11
B Verwold
Launchin
B Verwold's Avatar
Something else worth investing in is a auto shutoff solenoid .................saves forgetting to turn bottle off or on.
Bob V.
Old 03-14-2012, 02:06 PM   #12
WS6HUMMER
Spooled up
WS6HUMMER's Avatar
What about the angle of the bottle, can I mount it horizontal or will that be bad for the regulator?
Old 03-14-2012, 02:20 PM   #13
jevans
jevans's Avatar
I'm using C02 for my AMS Boost Controller. I purchased the Billet Cage Mounts and Carbon Fiber Wrapped Bottle from RJ Race Cars. I also have an Dedenbear Auto Shut-Off, I used Braided Hose to plumb the system.
The Auto Shut-Off is a good feature for a street car, no getting out to turn system on...
John
J E T Race Cars
" The difference is in the detail "
jevans is offline   Reply With Quote
Old 03-14-2012, 02:38 PM   #14
OboyMU
Spooled up
I had mine mounted horizontal and found that I was using the liquid and not the gas, the bottle was going down real fast, so I moved it in a vertical position and the bottle as lasted a lot longer. I would think you could do it kind of horizontal ( as pictured above) if the bottom is lower than the top. You don’t want to be using the liquid. I also like the idea of the auto shutoff solenoid. I keep forgetting to turn it off!
Mark
OboyMU is offline   Reply With Quote
Old 03-14-2012, 04:18 PM   #15
JShelton
What activates the auto shut off?
JShelton is offline   Reply With Quote
