6.0 Fuel injectors - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Diesel Power
Old 03-06-2012, 07:11 PM   #1
1QuickBird
1QuickBird's Avatar
Default 6.0 Fuel injectors
Today I changed the oil in my truck, and for the first couple minutes it ran afterwards it had a dead miss in it. And it did not go away with engine RPM. Which sucks because with 68k on an 06 I was not expecting to do injectors yet.
That being said, I was planning on doing EGR delete, 6.4 banjo bolts, oil cooler, and a couple other little things as soon as the weather is good enough to ride to work everyday. What kind of injectors should I look at getting? Stock or aftermarket? Who has the best price?
Thanks guys
WWW.LEGENDRACINGENT.COM
https://www.facebook.com/LREhorsepower
Midwest Muscle Car Specialists
High Performance engine builders
Induction Solutions Midwest dealer
1QuickBird is offline   Reply With Quote
Old 03-06-2012, 08:31 PM   #2
BenC
Member
Pullin gears
BenC's Avatar
Default Re: 6.0 Fuel injectors
Try the Rev-X oil additive first. Its kinda pricey but nowhere near the cost of injectors. Tons of guys have used it to clear up injector"stiction" issues with it. Worth a try before doing the full monty on injectors.
Quote:
Originally Posted by MaxFlow View Post
Of course, I'm too tupid to post my comments here.
BenC is offline   Reply With Quote
Old 03-10-2012, 10:31 AM   #3
Big Angry Hillbilly
Big Angry Hillbilly's Avatar
Rev-X is like putting a bandaid on a shotgun wound.
www.fanclutch.com, Superior Turbo and Injection, Detroit. Call their parts department, talk to Larry. Tell him I sent you.
Couple pieces of shit I beat up on, one's a truck, one's a car.
"Measure with yardstick, cut with torch." -Speaker's identity hidden for their protection
Quote:
Originally Posted by Blaine B. View Post
We need to show the world the bullet we put in CF.
Big Angry Hillbilly is offline   Reply With Quote
Old 03-10-2012, 02:14 PM   #4
Blue Oval Guy
Member
Pullin gears
Blue Oval Guy's Avatar
What kind of oil and oil filter did you use?
Quote:
Not neccessarily. If you have stiction issues and not a serious mechanical or electrical isssue on a 6.0 injector Rev-X can free them up and keep them alive for many thousands of more miles.
I had a similar issue to the OP at 80k miles on my 06'. Dead miss and real cranky cold starts. I dosed with Rev-X and my truck intantly ran like new again. There are many many more guys out there with similar experiences. After 25k more miles and one more dosing, my truck is still happy.
I am 100% anti-snake oil but this stuff works.
If you have scarred the plunger and barrel or have an electrical issue in the spool valve, obviously nothing but new sticks is going to help that.
Blue Oval Guy is offline   Reply With Quote
Old 03-10-2012, 02:17 PM   #5
Kwikford
What oil filter did you use?
Incorrect oil filter can led to low oil pressure to injectors = hard starting and missed.
Kwikford is offline   Reply With Quote
Old 03-10-2012, 02:27 PM   #6
Blue Oval Guy
Member
Pullin gears
Exactly. Motocraft or nothing. The aftermarket filters are shorter and don't always push the plunger all the way down. You also run the risk of oil bypassing the filter since they dont always seal all the way, or at all sometimes. If that happens, bye bye injectors. These things run rediculously tight tolerances. ANY trash will fubar them.
Old 03-10-2012, 03:50 PM   #7
LEAVNON3RD
ive seen first hand being powerstroke certd on 6.0 and 6.4 engines that NOT using a motor craft filter on these engines will cost you big later on down the road. since the patented their filter the aftermarkets miss closing that bypass 100%, we did a test with wix filters they seemed to be the closest to motorcraft but they still bled off a few thousand gallons of unfiltered oil to the engine betwene services and also as mentioned above gthe bled the qt form the oil filter housing. its dry starting the vehicle everytime u fire it up. i work on a fleet with 200 6.0's, we saw a extreme failure rate injectors due to dirty oil eating orings in the oil rails and brand tubes which starves the injectors for oil and the combo the injectors shuttle valves beings scuffed and sticking, and the cups in the injectors also scuffing and sticking. in some extreme cases the injectors shuttle valve would get hung open and it would drip fuel in the cylinder, blow the tip off the injectors and send that motor south lol.
6.0 injectors have seen revisions since its intorduction but still are far from reliable. if you had a miss after changing your oil kepe an eye on it because you might be heading down a road that can empty your pockets fast.
JA performance race engines
K&B transmissions
MARKOW racecars
OAB racing
LEAVNON3RD is offline   Reply With Quote
Old 03-10-2012, 03:59 PM   #8
LEAVNON3RD
i forgot to mention:
if your doing a egr delete u might want to look into also getting a new oil cooler. the coolant gets trashed form the egr cooler and will clog up the oil cooler. oil temp will also effect injectors believe it or not. if you do the oil cooler itll be a good time to inspect the screen that runs acorss the valley to the high pressure pump, more time then not the screens are broken through form debris and chunks of carbon. its not necessary but id look into it if you plan on keeping your 6.0 for the long haul
K&B transmissions
MARKOW racecars
OAB racing
Old 03-10-2012, 05:54 PM   #9
KeithC
KeithC's Avatar
Wix filters makes motorcraft filters and napa filters, which i have been using since my truck was new with no issues.
KeithC is offline   Reply With Quote
Old 03-10-2012, 06:07 PM   #10
KeithC
KeithC's Avatar
Quote:
Well i was wrong motorcraft is made by puralator and wix makes napa filters.
Old 03-10-2012, 07:42 PM   #11
mobeydick
Quote:
Call it what it is Snake oil!
*note disclaimer* I hate Hypocrites, Liars, Druggies/Drunks and Thieves. I am also considered an ahole in general. I am ok with it, so don't bother pointing it out, I already know. I guess I need to add this also. If you quote me and I don't respond after the second time, I most likely have you on my Ignore list. (503 as of 7/8/16) I wouldn't mind you adding me to yours!
mobeydick is offline   Reply With Quote
Old 03-10-2012, 07:49 PM   #12
540IROC
Member
Pullin gears
540IROC's Avatar
I use International filters in my truck. VT365 oil filter and VT275 fuel filters. Ford decided to use the V6 fuel filter housing system on the 6.0.
540IROC is offline   Reply With Quote
Old 03-10-2012, 08:38 PM   #13
1QuickBird
1QuickBird's Avatar
Wix filters.
And oil cooler is planned with EGR delete..
Old 03-10-2012, 10:40 PM   #14
Big Angry Hillbilly
I was under the understanding Racor built the filters for Ford.
Also cert'd on 7.3/6.0/6.4/6.7, glad to be out of the dealer world, tired of getting fucked on warranty times.
Once you get stiction, you risk scoring the spool valve and having it hang or stick again, typically at the most inopportune time. Had one blow an injector top off, fill the crankcase with fuel and run away while I was driving it. Keyed the ignition off when the tach was at 4300, and the rpm kept climbing till it stopped. That was a neat experience
Common rail (6.4, 6.7) seem to be less problematic with injectors, the 6.4 likes to eat HPFP's though, but clean filters and fuel are KEY in the common rail stuff, as is with ANY diesel, but that 6.4 sure is particular.
Old 03-10-2012, 11:07 PM   #15
a1speed
a1speed's Avatar
Pretty sure they [Motocraft] are Racor.
a1speed is offline   Reply With Quote
