406 Dyno Results - Yellow Bullet Forums
Old 03-06-2012, 05:21 PM   #1
Double D
Spooled up
Default 406 Dyno Results
Well the results are in.
406 SBC, AFR 210 heads, 13.2 compression, Holley Strip Dominator intake topped with a 1" HVH super sucker spacer, Cam Motion cam (Duration @.050 263/273, Lift .708/.646, LSA 110), 950 HP E85 carb, 1 3/4 headers.
Peak TQ with 1 7/8 headers was 544. Peak HP was 596.
Peak TQ with 1 3/4 headers was 538. Peak HP was 592.
Average TQ and HP was more with the 1 3/4 headers.
Thanks to all who provided opinions/advice on my questions. We'll see what it will do at the track now.
Double D is offline   Reply With Quote
Old 03-06-2012, 05:41 PM   #2
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Default Re: 406 Dyno Results
Maybe I'm off....but that thing sounds down on power with the parts you have.
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
Old 03-06-2012, 06:19 PM   #3
bowtize
bowtize's Avatar
Quote:
x2
bowtize is offline   Reply With Quote
Old 03-06-2012, 06:43 PM   #4
CamKing
CamKing's Avatar
Something's way off. Are those the CNC ported 210 heads, or the street version?
Mike Jones
Jones Cam Designs
Denver, NC 28037 704-489-2449
http://jonescams.com
jonescams@bellsouth.net
CamKing is offline   Reply With Quote
Old 03-06-2012, 06:45 PM   #5
Hotrod 36
Member
Pullin gears
Hotrod 36's Avatar
Is that a solid roller cam?
Hotrod 36 is offline   Reply With Quote
Old 03-06-2012, 07:19 PM   #6
CamKing
CamKing's Avatar
Was that on a chassis dyno?
Mike Jones
Jones Cam Designs
Old 03-06-2012, 07:33 PM   #7
Monte442
Monte442's Avatar
AFR heads usually don't require a 10 degree split,unless you plan on spraying it.
Monte442 is offline   Reply With Quote
Old 03-06-2012, 07:43 PM   #8
67RS502
Member
Pullin gears
what rpm was peak power?
needs bigger heads or head work for 600hp... 2.1" P-rod pinch is choking it.
67 camaro
pumpgas
420 - 641hp BretBauerHRcam 1.39, 9.79 @ 137.5
383 - 490hp 224/224HRcam 1.56, 10.77 @ 124.6
502 - 626hp 252/263HRcam 049s 1.44, 10.08 @ 132.7
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline   Reply With Quote
Old 03-06-2012, 07:46 PM   #9
67RS502
Member
Pullin gears
Quote:
they would if youre tryin to get some rpm
but then the intake port is going into choke anyway
67 camaro
pumpgas
62 Nova cruiser
224/224 HR cam
1.57 10.97 @ 121.2
Old 03-06-2012, 07:46 PM   #10
Double D
Spooled up
The heads are the race ready CNC versions, not the competition versions.
The cam is a solid roller cam.
Dyno was a Superflow engine dyno.
The numbers are corrected to sea level. Our elevation is 2537'. Not sure that matters.
Old 03-06-2012, 07:58 PM   #11
Double D
Spooled up
Peak power was at 6500, peak torque at 5000. I wasn't in a position financially to purchase different heads, so I had to use what I had. I knew different heads would have performed better.
We started the pulls at 4000 and went to 7000. I did find it interesting that with the 1 7/8 headers, the torque curve would start low, and climb really rapidly then trail off after 5000. With the 1 3/4 headers, the torque curve started much higher and trailed off after 5000.
Also, I'm sure it could use a bigger carb, but again, money is an issue. When I started this build, I wanted it to make more torque than my 383, and about the same power. I wasn't out to kill it or make a bunch more power.
My 383 in it's original form made 588 HP and 504 TQ. A couple years after it was dynoed, I updated the heads to the Eliminator versions of the same head, started running E85 and went from an APD 750 carb to an E85 950 carb. I have no idea as to how much the newer version heads were worth regarding power/torque.
Old 03-06-2012, 08:00 PM   #12
1989GTA
I agree with that. The heads are to small for what you are doing. I would say you have those AFR 210 heads maxed out. The good news is you can have them opened up.
1989GTA is offline   Reply With Quote
Old 03-06-2012, 08:36 PM   #13
Tims88
thread killer
Tims88's Avatar
The small cross section parts are a double hinderance because of the E85.
Tims88 is online now   Reply With Quote
Old 03-06-2012, 11:16 PM   #14
Hotrod 36
Member
Pullin gears
Hotrod 36's Avatar
Were the collectors the same size and length on both headers? reason I as is I just dyno'd my 406 with 2 sets of headers both 1 3/4" primary but one set had a longer collector and made more torque down low and the set with the shorter collector made the same peak numbers but the torque started at a higher rpm.
Old 03-07-2012, 12:07 AM   #15
1977Nova
Just a Mean Ol' Phucker
1977Nova's Avatar
That seems a good 50-60 hp off, at least......I made 582 at 6700 with a LOT less cam, and Pro-Filer 210 heads.
Dale
1977Nova is offline   Reply With Quote
