converting a 28-spline Detroit Locker to 31-spline: - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Rearends and Differentials - Mark Williams Enterprises
Old 02-27-2012, 10:54 PM   #1
Dakota Boy
Member
Pullin gears
Dakota Boy's Avatar
Default converting a 28-spline Detroit Locker to 31-spline:
Can it be done?
thanks
'58 T-bird
Dakota Boy is offline   Reply With Quote
Old 02-28-2012, 02:01 AM   #2
ordinary builder
Default Re: converting a 28-spline Detroit Locker to 31-spline:
depends on what center and when / year made...
a nine inch.??
only have to replace the "side /end gears"..
but only if the housing bore is the large / same as the availavble 31 spline units...
most 28 's are the same "center" for a 31...
there were some "odd" 9 inchers that had only 28 splines that also had an odd shoulder diamerter of the end gear.
normally you should also anyways replace to stiffer springs...
ordinary builder is offline   Reply With Quote
Old 02-28-2012, 08:11 AM   #3
Dakota Boy
Member
Pullin gears
Dakota Boy's Avatar
sorry; I didnt include enough detail in my first post.
rear end is a Ford 9".
Axle bearing housings are for the larger 3.15" O.D. bearing.
'58 T-bird
Old 02-28-2012, 10:49 AM   #4
PONYEATER
PONYEATER's Avatar
you should be able to replace the internals... but I do not know who would carry the 31 spline ones in stock.
Arron Spitzer
Yukon Gear & Axle
PONYEATER is offline   Reply With Quote
Old 02-28-2012, 02:58 PM   #5
ordinary builder
was told long ago that there was a guy in texas that purchased all that ford had at the time..
but I have an original unit....not for sale.
I do not know what original DAPCO has still available.
Resources saved on this page: MySQL 1.18%
