degree on driveshaft to pinon angle - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 02-25-2012, 07:19 PM   #1
badanglia
Pre-Staged
Default degree on driveshaft to pinon angle
changing 4 link position, the drive shaft is 2 degrees up to the yoke, the pinion yoke is 0 degree. To get the 2 degree pinion angle, do i leave alone, or set the pinion 2 degree down, thanks
badanglia is offline   Reply With Quote
Old 02-25-2012, 07:37 PM   #2
Hutch
Moderator
Hutch's Avatar
Default Re: degree on driveshaft to pinon angle
You want to obtain a realtionship between your pinion angle and crankshaft angle, not the driveshaft. If you make them both the same , that will be very close to where you want to be at ride height.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 02-25-2012, 07:43 PM   #3
welderboy
I'm no expert but my driveshaft is at 2* and put my pinion yoke at 2* down and i haven't had any trouble .
welderboy is offline   Reply With Quote
Old 02-25-2012, 08:18 PM   #4
coyote52
coyote52's Avatar
you have to know the degree of tailshaft/driveshaft, then make the degree of pinion/ driveshaft the same but opposit up or down angle this "times "your u-joints. you then add your pinion angle . example..... if your tail shaft is level and your driveshaft runs uphill toward your pinion at 2* then driveshaft needs to go down hill 2* from the pinion. after doing this you then turn the pinion down whatever degrees you choose
coyote52 is offline   Reply With Quote
Old 02-25-2012, 09:29 PM   #5
badanglia
Pre-Staged
motor is 2 degrees up which the driveshaft is also, at ride height the pinion is at 0 degree , driveshaft same as crankshaft is up 2 degree, so to get 2 degree down at pinion, do i leave alone or tilt pinion down 2 degree
Old 02-25-2012, 11:04 PM   #6
ArtQ
Burnout box
ArtQ's Avatar
If crankshaft/tailshaft is 2 deg up and pinion is 0 deg. Your pinion is 2 deg down in relation . So it's set where you want it.
ArtQ is offline   Reply With Quote
Old 02-25-2012, 11:12 PM   #7
TheNovaMan
TheNovaMan's Avatar
Quote:
I'm not sure how to visualize that, but here's a good graphic describing the possible relationships:
BTW, coyote nailed it: the reason we bother with driveline geometry is to time the u-joints with one another.
~Pete
I know enough to know that I don't know enough.
Yes, I'm biased and will bash anything that is non-American, non-Christian, etc.
Quote:
Originally Posted by ten5nova View Post
I know you're the Cragar king
You got that right!
TheNovaMan is offline   Reply With Quote
Old 02-26-2012, 07:28 AM   #8
jonestre.
You want the pinion angle set so that the rear u joint is as close to straight as possible under load. Timing of the joints is set when shaft is welded. ---Trevor
jonestre. is offline   Reply With Quote
Old 02-26-2012, 10:33 AM   #9
coyote52
coyote52's Avatar
when doing your pinion angles as long as you have the houseing at ride height you could turn your car on its' side or up-side to adjust pinion angles. it all is figured on tailshaft / pinion and the angle the driveshaft go's from one to the other. I understand what jonestre is speaking of ....he's right about that also, but....you need the u-joint at the front working at the same degree as the u-joint at the back, also considered "timeing". you then start adding any pinion angle if needed. by no means I am disagreeing with what jonestre stated....thats very important.
Old 02-26-2012, 10:45 AM   #10
lsXtra
lsXtra's Avatar
Simply stated........."pinion parallel with crankshaft under load"..........everything else will take care of itself.
lsXtra is offline   Reply With Quote
Old 02-26-2012, 11:03 AM   #11
coyote52
coyote52's Avatar
Quote:
exactly right
Old 02-26-2012, 02:03 PM   #12
badanglia
Pre-Staged
i understand what you are saying,but with the info i gave , do i leave it alone, 2 degree positive drivehaft, 0 degree pinion ? motor crankshaft is 2 degree up going at rear end
Old 02-26-2012, 02:32 PM   #13
TheNovaMan
TheNovaMan's Avatar
If the centerline of the crank points 2 up toward the rear end, then the pinion centerline needs to point 2 down toward the front under load. Because you have a four link, set the static pinion angle at 3-4 down.
~Pete
You got that right!
Old 02-26-2012, 03:05 PM   #14
Hutch
Moderator
Hutch's Avatar
I personally think a 2 degree difference in a 4 link car is not necessary. I doubt if there would ever be that much deflection to compensate for. If it were to happen it would not be for a long period of time , thats why I mentioned just making it the same as the crankshaft angle for ease of understanding.
Hutch
www.hutchtrans.com
519-453-4318
Old 02-26-2012, 03:28 PM   #15
EWC
Member
Pullin gears
Not sure I agree with the crank and the pinion being at the same degree . I also think you need to be sure what type of car he has . Chassis car usually has the pinion close to the height of the crank or higher . Other cars may have the stock floor and not as low which means a higher crank centerline . Obviously the u joints are in place to allow for suspension movement/misalignment or you have an IRS . Also need to think about an auto or stick car as there will be more deflection with the stick . An extreme example would be a 4x4 with the pinion and crank at the same angles but 2 feet apart in height . Personally I would set the pinion angle at 2 degrees on the 4 link and try it .
EWC is online now   Reply With Quote
