Max effort 496 (Too much head?) - Page 2 - Yellow Bullet Forums
Old 02-25-2012, 12:37 AM   #16
slow87GT
Default Re: Max effort 496 (Too much head?)
what would happen if the head was a little on the big side?
slow87GT is offline   Reply With Quote
Old 02-25-2012, 02:35 AM   #17
russ67chevelle
^spray it!^
russ67chevelle is offline   Reply With Quote
Old 02-25-2012, 04:05 AM   #18
HardonParts
Chinese buffet destroyer
HardonParts's Avatar
IVO 60.0
EVO 70.5
108 LSA
Dyno2003 predicts FWHP: 975HP@ 7500 and 760TQ@6000
A 20% drivetrain loss would be 770~ to the tire and 600 TQ.
Scott, should I try revising the cam a little more?[/QUOTE]
Id say your desktop dyno is a little happy. The baddest 496 I ever saw had more head more cam and was on Q16. Made 880 something on a well known dyno. Not saying it can't be done but I sure don't see it. My builds sorta close to yours with more compression 748 roller cam max ported dart 320heads and Id be happy with 750hp before nitrous.
1978 Chevy Malibu BBC, Nitrous, 25.5 X275 Drag Radial
Motor City Outlaws c.c
HardonParts is offline   Reply With Quote
Old 02-25-2012, 07:58 AM   #19
Elkyman
Elkyman's Avatar
Quote:
It would be a little less power output at lower rpm's but take off like crazy above 7000 rpm's. Big block's to love rpm in a light vehicle, and hardly works the engine. For a heavy chassis, you need the torque down low to get the weight moving and some good hp to keep it going once the weight is overcome, and it is a balancing act for sure. Many many guys have done this too so it is doable.
New best et
8.70 @ 154+ mph
60ft. 1.23 on rear tires
8 second club member finally
WWW.Fuelab.com
ULTRADYNE CAMS TTF...
Elkyman is offline   Reply With Quote
Old 02-25-2012, 10:44 AM   #20
LilJohn
LilJohn's Avatar
After helping out Pep with his 383, I think an Engine on E85 needs a bigger csa intake port.than an engine on gasoline.
I wouldnt put a head on this thing smaller than 320.
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is online now   Reply With Quote
Old 02-25-2012, 12:50 PM   #21
SStrokerAce
SStrokerAce's Avatar
Quote:
I agree... there are 496s that will make 950+ but they are pretty killer setups to do so.
Prof Gordon Blair “Those engine developers who grossly exaggerate their engine’s power as evidence of their genius!” ARE IDIOTS
SStrokerAce is offline   Reply With Quote
Old 02-25-2012, 01:12 PM   #22
ZXrider
Spooled up
I don't have alot of experience with BBC but is it not possible to make 2.0 hp per cubic inch? I see alot of 498/505 claiming 750 to 850 which puts it at around 1.5 to 1.7 hp per cubic in! Sounds like pump gas street motors to me.
ZXrider is offline   Reply With Quote
Old 02-25-2012, 01:46 PM   #23
scott foxwell
scott foxwell's Avatar
Why?
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 02-25-2012, 02:17 PM   #24
G-String
Member
Pullin gears
G-String's Avatar
Mine makes 890ish,DART 355 CNC.If thats Not a Big Head,what is,.............?
Later
G
G-String is offline   Reply With Quote
Old 02-25-2012, 02:28 PM   #25
scott foxwell
Quote:
Later
G
Well there you have it.
Custom cams
423 391 7774
Old 02-26-2012, 01:53 AM   #26
Outlaw Nova
Outlaw Nova's Avatar
Quote:
Originally Posted by scott foxwell View Post
Why?
I'm takin a wild guess here but maybe there's a considerable more amount of fuel with e85 vs gas.
Was helpin a guy with a dirt track late model and he had a alcohol an a gas motor built real similar but The engine builder did two totally diff port jobs and the alch motor had a slightly larger port vs the gas I remember the cams were slightly diff as well and this was a big time roundy round builder...they made close to the same power tho.
Outlaw Nova is offline   Reply With Quote
Old 02-26-2012, 09:31 AM   #27
Elkyman
Elkyman's Avatar
Quote:
Define a street Engine!!! and there is truth to power numbers too
New best et
8.70 @ 154+ mph
WWW.Fuelab.com
Old 02-26-2012, 10:31 AM   #28
excelerater1
Senor Frog
excelerater1's Avatar
I have a Dart 355 on our 496 nitrous motor.......
also added a 1150 dom and a big fat daddy nitrous jet
wish me luck
excelerater1 is offline   Reply With Quote
Old 02-26-2012, 10:39 AM   #29
nastychevelle
Member
Pullin gears
No such thing as too big of a head. Just not enough RPM.
67 Chevelle: TT LSX build in progress
Custom Racing Turbo's
Wagon Wheel peformance
DIYAUTOTUNE
Cam Motion
Sanders Induction
Fuel Injector Development
nastychevelle is offline   Reply With Quote
Old 02-26-2012, 10:58 AM   #30
Scott McMullen
Let the Clutch Out
Scott McMullen's Avatar
Quote:
Originally Posted by John Wilson View Post
This is just for the OP's reference. The 496 currently in my 67 is 10.8:1 with ported GM 781's and a mild solid roller. It makes pk hp from 6800-7000. On it's first and only full pass with my foot down the entire 1320 it went 9.56 at ~+3615Lbs. I kept the timing dialed down while I get a feel for the suspension tune-up.
Just offering up what can be done with a "small" head.
How much portwork was done to your 781's?
Scott McMullen is offline   Reply With Quote
Resources saved on this page: MySQL 2.06%
