tko 600 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service > Stick shift and clutch
Old 02-22-2012, 07:36 PM   #1
66 nogo only 10.55 yet
Launchin
66 nogo only 10.55 yet's Avatar
Default tko 600
Got a chance to buy a tko 600 for cheap. It has no 3rd gear.The seller bought the car with the blowen trans so he dont know the story behind the damage.What could have gone wrong and what would be the worst case repair on the trans
66 nogo
66 nogo only 10.55 yet is offline   Reply With Quote
Old 02-22-2012, 07:47 PM   #2
nos347stroker
Spooled up
Default Re: tko 600
3rd gear,main shaft and cracked case in the front where the cluster bolts on, they crack from the 2upper bolts all the way up to the cover,some syncros . that would be about the worst if you lucky only 3rd gear will need a change. how cheap ?
nos347stroker is offline   Reply With Quote
Old 02-23-2012, 12:47 AM   #3
Launchin
Default Re: tko 600
can get it for $450
66 nogo
Old 02-23-2012, 08:10 AM   #4
nos347stroker
Spooled up
Default Re: tko 600
if its only 3rd and the case is good id buy it. open it and look inside to see whats wrong
Resources saved on this page: MySQL 1.19%
