Return line? - Yellow Bullet Forums
Old 02-22-2012, 05:28 PM   #1
bski224
Launchin
Default Return line?
Where does return line from regulator go? On top of cell or one of the two fittings on the sump?
1972 Procharged Z28
bski224 is offline   Reply With Quote
Old 02-22-2012, 05:32 PM   #2
OB1
YB.com Approved Vendor
OB1's Avatar
Default Re: Return line?
on top of the cell........
You never want to return next to the outlet.
OB1 is offline   Reply With Quote
Old 02-22-2012, 05:41 PM   #3
bski224
Launchin
Why the hell do they put 2 fittings by outlet.
1972 Procharged Z28
Old 02-22-2012, 05:44 PM   #4
tsanchez
tsanchez's Avatar
Two pumps
tsanchez is offline   Reply With Quote
Old 02-22-2012, 05:45 PM   #5
OB1
OB1's Avatar
You can also use 2 outlets to Y into a larger pump....
Old 02-22-2012, 05:48 PM   #6
bski224
Launchin
Oh thanks ob1 by the way i will be calling you for my setup!!
1972 Procharged Z28
Old 02-22-2012, 05:49 PM   #7
OB1
OB1's Avatar
Quote:
Cool.....look forward to hearing from you.
Old 02-22-2012, 06:37 PM   #8
72much
Launchin
72much's Avatar
Garage
On your return line going into the top of the tank you run to run a tube down close to the bottom inside the tank to control aeration. If you ever look inside your tank with the fuel returning inside just splashing around. You will see what I mean.
http://www.cardomain.com/ride/763439
http://www.youtube.com/watch?v=i_2KlG2mkmk
http://www.youtube.com/watch?v=aJduCg3jWKs&feature=plcp
sbc 357 on E85 - CSUs
F1R ft braking / 3625lbs with driver
5.73 @122.45 mph in street tune
72much is offline   Reply With Quote
Resources saved on this page: MySQL 1.09%
