Oil turned into jelly.. anyone seen this before? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 02-22-2012, 05:56 PM   #1
84buicksb420
Burnout box
84buicksb420's Avatar
Garage
Default Oil turned into jelly.. anyone seen this before?
I'm running e-85 in a sbc and was doing a tare down after having the engine together for 3 years. No oil would come out of the pan. When I flipped it over on the stand after having the intake and heads off, goo started to come out. I pulled the pan and had jelly like goo everywhere. I've been running Brad Penn 10-30. Has anyone else seen this with BP oil before? (or others?)
I'm looking for an oil that will not do this with e-85.
The oil had about 200 miles on it then sat for 3 months before the tare down.
Thanks..
have a pic but can't get it to post...
84buicksb420 is offline   Reply With Quote
Old 02-22-2012, 06:15 PM   #2
JShelton
Default Re: Oil turned into jelly.. anyone seen this before?
I've ran e-85 for about a yr now and have never drained oil out of my car that looks like what your describing. Even after setting 3 mo. Just changed it before the last race after setting that long and it looked pretty much like the day I put it in (maybe a little darker)but looked like oil and not jelly! By the way if you haven't hit the newbie thread ya might want to go there and introduce yourself before all hell breaks loose. I run valvoline race 20-50.
JShelton is offline   Reply With Quote
Old 02-22-2012, 06:17 PM   #3
Matt Hill
On the roller...
Matt Hill's Avatar
The pic would be helpful. Moisture is my first guess, but I'd love to see it. What color is the goo?
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter.
-Ernest Hemingway
Matt Hill is offline   Reply With Quote
Old 02-22-2012, 06:23 PM   #4
Matt Hill
On the roller...
Matt Hill's Avatar
Is it black and more like tar? I'm really just curious now since jelly has me wondering if it's the normal broken-down oil?
-Ernest Hemingway
Old 02-22-2012, 06:29 PM   #5
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Moisture....how hot do you get the motor while running E85?
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
Old 02-22-2012, 06:30 PM   #6
hhott71
hhott71's Avatar
tare down?
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
The World's #1 Terrorist!
hhott71 is offline   Reply With Quote
Old 02-22-2012, 06:30 PM   #7
Dr. Evil
A.K.A. MEAN Matt
Dr. Evil's Avatar
I'm guessing you had a shit ton of water in your oil? Or alot of fuel?
I've allways ran Brad Penn 10W30 with alky and never had anything like that. Oil might smell like my fragrance additive or like alky but never any goo.
Come to think of it I had a cylinder filling up with water ( pin hole in cylinder wall ) and never had any goo build up. The Brad Penn oil wouldn't mix with it. Pull the drain plug and nothing but water until it was all gone, then oil would drain.
Maybe your E-85 mixes up with the Brad Penn?
Dr. Evil is offline   Reply With Quote
Old 02-22-2012, 06:31 PM   #8
84buicksb420
Burnout box
Garage
Quote:
It looked just like green jelly... crazy huh...
I've never seen oil do this before.
And yes I do need to hit up the newbie thread before it's too late.
What's the best way to post a pic?
Thanks.
Old 02-22-2012, 06:51 PM   #9
BACARTY
The Bullet Killer
BACARTY's Avatar
Ive seen what your describing but not anything in an engine.
Unkept, and too hot of bearings on oil bath style bearings would do this on larger trailers.
Reminded me a jello shot sitting in my hand that when i squeezed it would go threw the cracks of my hands
BACARTY is offline   Reply With Quote
Old 02-22-2012, 07:10 PM   #10
montys 55
montys 55's Avatar
I've seen it happen on a diesel heavy truck engine when the oil is not changed often enough but it can happen to any high compression engine . The fuel blow-by from the rings causes fuel to mix with the oil and "coke up" and it creates an oil that looks almost like asphalt.
montys 55 is offline   Reply With Quote
Old 02-22-2012, 07:16 PM   #11
84buicksb420
Burnout box
Garage
Would run around 180deg water temp..
Old 02-22-2012, 07:17 PM   #12
luv2xlr8
luv2xlr8's Avatar
if in fact it is from fuel or water in the oil i would strongly recommend you check ALL bearings in that motor. im surprised it didnt start knocking before it gelled up
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 02-22-2012, 07:28 PM   #13
68Bird
68Bird's Avatar
OMG....I thought I was the only one seeing green JELLY in the oil pan with the BP oil! I had an oil pump quit working on me while the engine was running last year....cleaned out the pan after replacing the pump thinking it was bad and there was a 1/4" thick layer of green jelly in the bottom. Tore pump apart and didn't find anything wrong with it. I think the layer of goo kept the pump from pumping. Never seen that before this last year and been running BP oil for 2-3 yrs now. I run Q16 fuel. Its either the fuel / oil mix or most likely condensation in the oil causing it. Been thinking about calling Brad Penn about it....or sending a sample off to have analyzed.
68Bird is offline   Reply With Quote
Old 02-22-2012, 07:31 PM   #14
84buicksb420
Burnout box
Garage
Here is the photo.
Hope this works.
Old 02-22-2012, 07:45 PM   #15
84buicksb420
Burnout box
Garage
Quote:
Trust me after I seen the jelly gooo I pulled it completely apart. The bearings didn't look very good but not as bad as I was expecting after seeing the oil. I feel pretty lucky to tell you the truth.
Some new bearings and a little cleaning it will be good as new.
The only reason I was opening up the engine was just to look for anything funny due to the e-85.
