Muncie - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service > Stick shift and clutch
Old 02-18-2012, 10:04 PM   #1
twomanynovas
Member
Pullin gears
twomanynovas's Avatar
Default Muncie
What is the usual cause for a Muncie to jump out of third gear upon decelleration?
"And the pin has been pulled.That 200 shot should solve your oil pressure problems. "
Monte 442
twomanynovas is offline   Reply With Quote
Old 02-19-2012, 09:08 AM   #2
jonestre.
Default Re: Muncie
Worn out. Seriously I used to have a list that had 20 different causes. #1 shifter loose---Trevor
jonestre. is offline   Reply With Quote
Old 02-19-2012, 06:33 PM   #3
twomanynovas
Member
Pullin gears
Default Re: Muncie
Actually it was just rebuilt. It was good for about 50 miles and then this started. I guess that is what I get for having someone else rebuild it for me. Sucks when I have to work out of town.
Monte 442
Old 02-20-2012, 09:58 AM   #4
jonestre.
Default Re: Muncie
Out of alignment, pilot bushing. Did you install it---Trevor
Old 02-20-2012, 12:53 PM   #5
Dr.Dan
Spooled up
Dr.Dan's Avatar
Default Re: Muncie
Did he replace all the syncros?
66 Chevelle, 385 sbc, th400, M9
81 Grand Prix, jerico DR4, HRS softloc clutch, waiting to be rebuilt into the next iteration
Dr.Dan is offline   Reply With Quote
Old 02-20-2012, 05:56 PM   #6
twomanynovas
Member
Pullin gears
Default Re: Muncie
I did pull the side cover when I recieved it to see if I got more than a "parts washer rebuild". Everything looked brand new. I had him use the AGM Super Case and an iron mid plate. I even sprang for the roller bearing side cover with lip seals.
I checked and adjusted the bell housing alignment with a checking tool because I also installed a scatter shield. On the plus side. it was not a customer's trans. This crap only happens to my stuff.
Monte 442
Old 02-21-2012, 10:14 AM   #7
left 4 dead
Member
Pullin gears
Default Re: Muncie
Quote:
Check the engaging teeth on 3rd gear and the shift sleeve/ slider...I use the torque lock shift sleeve/ slider that is available to prevent this.. Also the engaging teeth on 3rd gear must be sharp and not rounded off...
Turbo Terry Transmissions Inc
Chicago..Ill. since 1972
773.586.1065
left 4 dead is offline   Reply With Quote
Old 02-21-2012, 05:24 PM   #8
twomanynovas
Member
Pullin gears
Default Re: Muncie
Thanks LFD. Do you sell parts?
Monte 442
Old 02-21-2012, 06:21 PM   #9
left 4 dead
Member
Pullin gears
Default Re: Muncie
Yes i do...
I PMd you....
773.586.1065
Old 02-21-2012, 06:52 PM   #10
thesource
T5 & T56 building fool
thesource's Avatar
Default Re: Muncie
More than likely the sleeve and gear are tapered allowing it to jump out of gear.
PM me for T5-T56-T45-TR3650-TKO units and related parts.
thesource is offline   Reply With Quote
Old 02-21-2012, 08:37 PM   #11
jonestre.
Default Re: Muncie
If it has a different side cover and case it may not be engaging all the way. You may be able to just grind the detent lever---Trevor
Old 02-21-2012, 11:14 PM   #12
weedburner
Member
Pullin gears
Default Re: Muncie
If you have an extra case laying around, you can cut a large hole in the top and make a mockup case out of it. Really helps to see what the effects are when playing with the detents. You can also play with the shape of the detent's profile to hold the trans in a certain gear more firmly. I used to do it to circle track transmissions to keep them from jumping out of gear on rough tracks.
Shop Mule build page...
weedburner is offline   Reply With Quote
Resources saved on this page: MySQL 1.06%
