cs 2 lenco - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Pro Modified
Pro Modified Talk about Pro-Mod racing with censorship...
Old 02-16-2012, 01:19 PM   #1
levers
levers's Avatar
Default cs 2 lenco
whats everyone useing for oil?
levers is offline   Reply With Quote
Old 02-16-2012, 01:43 PM   #2
Comax Racing
Comax Racing's Avatar
Default Re: cs 2 lenco
10W-30 motor oil as per Lenco.
Comax Racing is offline   Reply With Quote
Old 02-17-2012, 12:30 PM   #3
big black nova
Member
Pullin gears
big black nova's Avatar
10w-30
big black nova is offline   Reply With Quote
Old 02-17-2012, 03:21 PM   #4
greg hindman
greg hindman's Avatar
30wt
carbon fiber is like diamonds for men
greg hindman is offline   Reply With Quote
Old 02-17-2012, 04:18 PM   #5
overkill69
overkill69's Avatar
redline synthetic ATF, same as the bruno. Against Bruno and Lenco's advice but we've never had a problem.
overkill69 is offline   Reply With Quote
Old 02-17-2012, 04:59 PM   #6
Comax Racing
Quote:
I figured someone would say ATF, tried it once but the trans leaked because of the thinner fluid. Lenco tells me that the clutches they use don't like ATF.
Well I guess if its working for you great.
Old 02-17-2012, 05:00 PM   #7
littlemoney
littlemoney's Avatar
B&M Trick Shift for the lenco for us and Amsoil 20wt compressor oil for our quick drive and convertor
littlemoney is offline   Reply With Quote
Old 02-17-2012, 06:28 PM   #8
SMOKIN JOE
Launchin
SMOKIN JOE's Avatar
Question Re: cs 2 lenco
Quote:
Were can you buy the 20w compressor oil from? Auto Zone,Jegs,etc.???
SMOKIN JOE is offline   Reply With Quote
Old 02-17-2012, 07:06 PM   #9
T1MUG
Launchin
T1MUG's Avatar
CS1 - Dexron ATF in mine - no problems - always looks brand new inside when we strip it to check it over.
1.08 - 60ft
3.08 - 330ft
4.78 - 1/8th
7.48 / 181mph
T1MUG is offline   Reply With Quote
Old 02-18-2012, 02:56 AM   #10
littlemoney
Quote:
We buy it from amsoil, real easy to set yourself up as a dealer
Old 02-18-2012, 03:46 AM   #11
redvictor
from across the pond...
redvictor's Avatar
Garage
On Hutch's recommendation we use this stuff only in the Lenco. Parts and frictions look brand new.
http://www.mobil.com/Germany-English...l_ATF_SHC.aspx
Bruno has Redline lightweight.
Personally i would never use motor oil.
Gone from this place...
redvictor is offline   Reply With Quote
Old 02-18-2012, 09:08 AM   #12
buschmec
First round fodder...
buschmec's Avatar
mobil 1 synthetic 10w30........
Working to make her faster....
Thanks to Troy Balsters, Greg Buschmeyer , Rick Vineyard , John McDonough, Mike and Ty Chaney, David Rich, Joey Bryant, Chris and Jolene Bryant, and many others.
buschmec is offline   Reply With Quote
Old 02-18-2012, 10:06 PM   #13
littlemoney
when we ran the clutch, we used Valvoline 5w30 synthetic
Old 02-18-2012, 10:35 PM   #14
bigboyinsc
Launchin
bigboyinsc's Avatar
Here is a question I've always wondered, if Lenco says use 30wt motor oil in the lenco, do they want you to use the same 30wt in the lencodrive??? They share the same fluid!!!! So, should you use the Redline or ATF for both or what??? Kind of a contradiction, I think.
bigboyinsc is offline   Reply With Quote
Old 02-18-2012, 10:41 PM   #15
bigboyinsc
Launchin
bigboyinsc's Avatar
We run Redline LW ATF in the Bruno and Rossler. After this season, which we made probably 200+ runs, I changed fluid in one of the Bruno units 1 time. I have 1 unit that has the same fluid that I put in in MAY. Sold on this product.
