Hoosier radials or M/T stiff wall slicks?? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Tires - Mickey Thompson Tires
Old 02-10-2012, 09:06 AM   #1
nosjunkie
Spooled up
Default Hoosier radials or M/T stiff wall slicks??
I am having no luck whatsoever on average tracks with the M/T drag radials.. So I am in the market for some new tires. I love the feel of a drag radial on top end, but also enjoy a wheels up launch with a slick. What should I buy this time? I am leaning towards the Hoosier drag radials or the M/T 26x10 stiff wall slicks. What do you all think? Thanks!
nosjunkie is offline   Reply With Quote
Old 02-10-2012, 11:45 AM   #2
onefast68
onefast68's Avatar
Default Re: Hoosier radials or M/T stiff wall slicks??
if you run on tracks that are NOT prepped very well, i would run slicks...
68 camaro..3300lbs........
big duke 632 with 2 kits ..
4.95 at 145.8 ................
onefast68 is offline   Reply With Quote
Old 02-10-2012, 01:05 PM   #3
nosjunkie
Spooled up
Quote:
Someone told me that the hoosier radials hook as good as slicks.. I just don't like fighting a slick going down the track.. A radial is more stable on top end.. Are the stiff wall slicks more stable than the standard ones? Just curious
Old 02-10-2012, 02:55 PM   #4
Jason Moulton
Moderator
Jason Moulton's Avatar
How wide is your wheel?
Thanks,
Jason Moulton
Visit our website for News, Product info, Tech Bulletins, Frequently Asked Questions, "BUY NOW" program. http://www.mickeythompsontires.com/
Jason Moulton is offline   Reply With Quote
Old 02-10-2012, 03:19 PM   #5
nosjunkie
Spooled up
Wheel is 15x10, 6.5 offset..
Old 02-11-2012, 08:37 AM   #6
mrbobby
Launchin
mrbobby's Avatar
i went with hoosiers from m/t and wont go back. went from 1.40 60ft to 1.35 with wheel standing action.
mrbobby is offline   Reply With Quote
Old 02-12-2012, 10:10 AM   #7
Steve Buckley
Member
Pullin gears
Steve Buckley's Avatar
I have used both and on a shitty track you better have the slicks because once you spin a dr its over! From my personal experience the slick can recover where the dr will blow tires again
Steve Buckley is offline   Reply With Quote
Old 02-12-2012, 10:47 AM   #8
Smitty275
Smitty275's Avatar
If you've got proper air in a slick it is not a fight going down track. If your weaving or otherwise having to constantly steer correct you most likely are short on air pressure. I also agree that a slick is more forgiving on a marginal track. A radial spins and it's gone, no recovery, race lost.
Smitty275 is offline   Reply With Quote
Old 02-12-2012, 01:44 PM   #9
z289sec
z289sec's Avatar
What kind of car, rear shock, and rear suspension? What kind of front suspension and shock?
If you can't get a wheels up launch with a radial, sounds like the car will need a lot more work before you could realize the benefits of running them.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 02-12-2012, 04:01 PM   #10
mrbobby
Launchin
mrbobby's Avatar
x2
Old 02-12-2012, 04:08 PM   #11
MUSTLX50
Spooled up
MUSTLX50's Avatar
You could try running inner tubes on the slicks and it will almost be like a radial up top. I agree also with z289sec, you should work on the suspension also, will benefit you in the long run greatly.
MUSTLX50 is offline   Reply With Quote
Old 02-12-2012, 04:59 PM   #12
Widow_Maker
Chupa Cabra
Widow_Maker's Avatar
Best bit of info yet.
I run a 275/60/15 Hoosier DR and have no problem cutting 1.2x 60's wheels up, wheels down doesn't matter.
That being said, I could probably switch to a M/T and run the same times with a little shock setting tweak, but I'd need a damn good track to do it.
RTCTTFMF!!!
5.14@137.49 (1.21 60') True Street 275 (3290# RW) SOLD
Smallwood Race Developement
Mcleansville, NC
864-723-2892
Widow_Maker is offline   Reply With Quote
Old 02-13-2012, 08:17 AM   #13
nosjunkie
Spooled up
S/S with single adjustable shocks on front and rear.
Old 02-13-2012, 08:20 AM   #14
nosjunkie
Spooled up
Quote:
Thanks,
Jason Moulton
What is your suggestion Jason? And what do you think would be the 60' difference switching from a standard 26 inch slick to a stiff wall same size?
Thanks!
Old 02-13-2012, 08:34 AM   #15
Jason Moulton
Moderator
Our results show different gains depending on the combination. The higher the horsepower and weight, the bigger the gain going to a stiff sidewall tire.
A 10" wide wheel and a stiff sidewall tire is a good combination. If your car is close to or over 3000 lbs, and you have more that 500 HP, I would go with the stiff sidewall tire.
Thanks,
Jason Moulton
Resources saved on this page: MySQL 0.99%
