electrial schematic for 66 Chevelle - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical - Hyperaktive Performance Solutions
Old 02-01-2012, 11:49 AM   #1
Bobalos
Bobalos's Avatar
Default electrial schematic for 66 Chevelle
do any of you guys have an electrical schematic of the steering column (or the entire car) for a 66 Chevelle?
someone who owned this Chevelle before me put a painless harness in the car & did not connect up the harness to the column properly.
a schematic of the column (or the entire car) would be VERY helpful.
thanks
Bob
You are who you are, when nobody is looking.
Bobalos is offline   Reply With Quote
Old 02-01-2012, 12:47 PM   #2
tsanchez
tsanchez's Avatar
Default Re: electrial schematic for 66 Chevelle
http://www.painlessperformance.com/Manuals/10202.pdf
Should be close
tsanchez is offline   Reply With Quote
Old 02-01-2012, 12:58 PM   #3
Mi.5.0Fred
Mi.5.0Fred's Avatar
I bought one for a 67 from NPD under $10 I think. If I see it in the garage today I will post up later.
No one wants the Lead Trophy, but everyone wants the Titanium Hall Pass.
I have gone through the traps upside down and on fire, but I have never seen Elvis at 1000 feet.
Mi.5.0Fred is offline   Reply With Quote
Old 02-01-2012, 01:48 PM   #4
Bobalos
Bobalos's Avatar
Sanchez, short version, is I have that manual. it helps, but does not get me there, cause something is broke & I need the schematic of the column to figure it out. thanks.
Fred, thanks. that would be helpful. as I mentioned the biggest problem is in the column. If you have the print for the turn signal switch stuff, that would be great.
thanks again guys.
Bob
Old 02-01-2012, 02:38 PM   #5
tsanchez
tsanchez's Avatar
Is it a 7 wire switch or 8, this is the color of the 7 gm switch
BLACK - RIGHT REAR
SKY BLUE - RIGHT FRONT
DARK BLUE - LEFT REAR
GREEN - LEFT FRONT
ORANGE - STOP SWITCH
RED - FLASHER L
YELLOW - FLASHER P
And the other universal 8 pin
White - Brake Feed
Green - Right rear turn signal and break
Yellow - Left rear turn signal and brake
Purple - Turn Feed
Brown - 4 Way Feed
Dark Blue - Right front turn signal and indicator
Light Blue - Left front turn signal and indicator
Black - Ground for horn relay
Old 02-01-2012, 03:07 PM   #6
tsanchez
tsanchez's Avatar
They do stll an adapter for the round con to univ 8 pin, the painless will be the 8 univ
Old 02-01-2012, 03:10 PM   #7
tsanchez
tsanchez's Avatar
http://www.yearone.com/yodnn/TechFAQ...7/Default.aspx
Better to identify
Old 02-01-2012, 04:33 PM   #8
Bobalos
Bobalos's Avatar
great info, thanks again.
bob
Resources saved on this page: MySQL 2.25%
